    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree35Likes
Old 08-18-2016, 08:10 AM   #1816
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Mine have never leaked. Where are yours leaking from and what is your build method?
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 08-18-2016, 11:18 AM   #1817
Originally Posted by blvdbuzzard View Post
I may be doing something wrong here, but this is my 3rd set of big bores that leak like a stuck pig. I have tried cranking on them like the Hulk, just enough to snug up the tops and just about everything in between. Do they just leak or am I doing it wrong?
Buzz.
I am not a fan of AE's plastic shock caps - The FT aluminum shock caps are a very nice upgrade.
hsp-sandiego is offline   Reply With Quote
Old 08-18-2016, 11:24 AM   #1818
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I have never used the alum caps and never had an issue.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-18-2016, 11:39 AM   #1819
Build is per the videos on the tube when i built my SC10.2.
https://www.youtube.com/watch?v=JAg0Q0ORdj4
I wet the o-rings and shaft before I put them in. They are leaking from the top. It looks like they are leaking a bunch by the amount of dirt on them. But is is a drop or two at most when I take them apart to clean and check oil level
I can understand my brothers leaking as he just tossed them together. So it must be something I am doing wrong.
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 08-18-2016, 11:45 AM   #1820
Buzz.
leaking from the top? did you strip out the bleeder screw or not get the caps on tight?
Old 08-18-2016, 11:48 AM   #1821
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I use the plastic caps on every car AE that I've ever owned (it's a lot...ask Wildcat)...none of them have leaked from the top.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-18-2016, 02:00 PM   #1822
Not stripped, They thread on easy, no damage I can see to the threads. I will check the bleeder screws again. The did not look like any damage or striping of the treads. Might not be tight enough? I would like to see them stay clean. I thought I had them this time. I went 2 or 3 trips and they stayed clean and dry.
I will take them apart again this weekend. clean and refill. I will look close at the o rings and grooves. Might be just a spec of dirt.
Buzz.
Old 08-19-2016, 08:43 AM   #1823
It was a good night for running and racing. Truck is well balanced and the new motor ESC worked very well. Has a little bit more power, well about 20% more power and a lot smoother. You can "feel" the way the truck runs with the sensored setup is smoother.
Had a friend run with us too. His first time so spent a little time with him about track etiquette. Get out of the way, slower is faster. Don't try to run with the fast guys, you only get in the way and cause crashes. Couple times had to tell him to move to the side, hitting the throttle and spinning into them is NOT the way to do it. No matter how fast you go, if you are not in control you can not go fast.
Now I need to get the parts to do the tree gear on it. Not sure what else as it is running very well. Did a 24.01 lap yesterday. Not as fast as the buggies but fast enough for me.
Buzz.
Old 08-19-2016, 09:07 AM   #1824
Suspended
Trader Rating: 61 (100%+)
Buzz.
Buzz are you sure they're weeping oil, or is it just a film left frim bleeding them that's attracting dirt?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-19-2016, 10:20 AM   #1825
Anyone using the Jconcepts Spring Steel CVA kit? Not sure I quite understand the benefits , although they look really nice.
Going to pull the Schelle hubs from my b5 and get on the sc5m, can get these reasonably priced on ebay right now, along with a diff rebuild while i am in there.
Old 08-19-2016, 11:28 AM   #1826
Matt Trimmings is
Old 08-19-2016, 11:40 AM   #1827
Super Moderator
Attachment 1382143
They are nice. Main reason they were made is they are supposedly less susceptible to rust...so if you race in high humidity environment (Florida) they should last longer than stock. Plus they look cool.
Old 08-19-2016, 11:45 AM   #1828
Cool, thanks Matt. Really nice quality. Rust is not a issue, may just spring for them.
Old 08-21-2016, 08:48 AM   #1829
I checked them, cleaned them and they stayed clean. I do clean them after I build them. May have been left over but it looked like it was getting worse and worse as the weeks went by. Could be my imagination too? I am an old fart after all.
I do have to paint a new lid for it. Mine is falling apart at the seams.
Buzz.
Old 08-21-2016, 06:16 PM   #1830
Trader Rating: 488 (100%+)
Attachment 1382143
The spring steel is a better quality steel than the stock stuff. It should last longer and be less susceptible to bending.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
