    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree34Likes
Old 06-30-2016, 09:06 PM   #1711
Originally Posted by man1ac View Post
Had another run with my SC5M, the guys fixed some broken clay (dry, wet, dry, extreme wet and extreme dry really messed it up). So we got sections which have good grip, like flat dried clay (good grip at my measures ) and loose stuff which makes it even hart to drive straight.
The SC5M didnt handle that well, kinda back to my problem loosing the rear when entering fast corners. I didnt want to do any tuning, cause my money is on the B5M and B6 someday. But at the moment I am just loosing confidence in the truck and think of selling it
Current setup is:
>front shocks 35wt and grey spring
>rear shocks 30wt and green spring
>ball diff just opened a notch, any more closed and its shut for good
> Hole Shots front and rear, standard plastic rims
> shorty at rear position
So its either sell it or make it the way I like it.
Thinking of adding brass c and d, increase rear toe to 3,5 (which wont help me just for acceleration?) Any more suggestions? I even think of trying to switch to gear diff with 5k...
@ Ray: you suggested 1.7 and 37,5wt for rear?
What C-block you running?
I switched to the 3-1 for outdoors from the 3-2 when running indoors.
SC5M, SC10.2 FT
HPI WR8 flux,HPI Bullet flux
RC10 T4.2 FT
SC10 4x4
RC10T Team Truck,RC10
Fastz28 is offline   Reply With Quote
Old 06-30-2016, 10:30 PM   #1712
Havent changed anything here, so it's like in the manual...
man1ac is offline   Reply With Quote
Old 06-30-2016, 11:19 PM   #1713
I have a pretty much bone stock per manual truck. I do have a few super secrets though.
This was my first run with the truck. I had beat the snot out of the SC10.2 truck for the last 2 years. It had always been loose in the rear. So I developed some habits to get it to run well. I was using the break and throttle well for the old truck. It was causing issues tonight with the SC5m.
I took it easy for the first 10 laps or so. Sounded like slipper was slipping. So tightened slipper, still sounded like skipper was slipping, cranked it down, no change. Checked diff. Loosened, tightened all the way backed out not a full 1/4 turn. Still slipped, loosened, tightened, back out about 1/8th. no slip and drove better. Had a lot better launch. Did not pull to either side.
I had trouble flying. I was all over the throttle and the brake like I had to in the SC10.2. This one you just do pretty much nothing and it fly's just fine. As I drove it more I was getting better at letting it do its thing and leave it alone in the air.
This thing slams into the corner and rockets through it. So much better than the SC10.2 I had. I have the sway bars front and rear. They keep this thing flat through the turns. I have the stock springs, 32.5 front and rear. I did buy the FRP shock pistons. I think they help a lot with the suspension It just soaks the big jumps, glides over the small stuff.
When my brother had the SC10 RTR, he had trouble keeping up with my SC10.2, he upgraded the the SC5M. Then I had trouble keeping up with his SC5M. Now, tonight he had trouble keeping up with my SC5M and my Super secrets.
When I built the kit, I bought the ceramic diff balls, FRP 1.5, 1.6 valved shock pistons, sway bars front and rear. I think those were well worth the money. The truck was hooked up and flying tonight.
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 07-01-2016, 03:25 PM   #1714
The manual calls for the 3-2.
I am using the 3-1 and my setup is based off of Cavalieri's Off-Road Shootout setup sheet.
https://www.teamassociated.com/cars_...anuals_setups/
SC5M, SC10.2 FT
RC10 T4.2 FT
SC10 4x4
Old 07-02-2016, 12:22 AM   #1715
Since I glued my inserts that sucks
Old 07-02-2016, 03:46 AM   #1716
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
He's talking about the C block, not the front trailing inserts.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 07-02-2016, 09:27 AM   #1717
On the setup sheet its called the "Arm Mount."
SC5M, SC10.2 FT
RC10 T4.2 FT
SC10 4x4
Old 07-02-2016, 08:25 PM   #1718
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
those running a gear diff on high traction surfaces, what oil are you using (and please list the surface, e.g. clay, astro, carpet, etc). when i ran a ball diff, i ran it tight. i just put a gear diff in and started with 7000, but it feels too loose (just spinning it, haven't actually run it yet). feels way looser than my ball diff was.
thanks!
RC*PHREAK is offline   Reply With Quote
Old 07-04-2016, 01:36 AM   #1719
Hasi's Avatar
My manual calls for the 3-1.. was there a running change?
I installed the 3-1 like my manual said.
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
Old 07-04-2016, 02:28 AM   #1720
Hi guys,
Do some of you encountered problems with ball diff screw ? When I built my kit the first time, I broke it before screwing it completely. A friend had the same problem and a fellow pilot broke 2 of these screws during a race this weekend...
We all had no problem with our SC10 ball diff so we are thinking there might be a problem with the material of the screws ?
lanac is offline   Reply With Quote
Old 07-04-2016, 05:57 AM   #1721
I had one snap on me when I built my B5m, but that's the only one I've had happen. My T5m and SC5m went together with no issues. Could have just been a bad batch.
boucher is offline   Reply With Quote
Old 07-04-2016, 10:57 PM   #1722
You are correct. On my initial build I used the 3-2 for indoors. My mistake.
SC5M, SC10.2 FT
RC10 T4.2 FT
SC10 4x4
Old 07-05-2016, 12:22 AM   #1723
Hasi's Avatar
No worries, you're welcome. We all make mistakes sometime
Originally Posted by lanac View Post
Hi guys,
Didn't have any problem with it, neither at my SC5m nor at my B5r.
Did you compress the ball diff spring severeal times before installing the screw like the manual said?
Old 07-05-2016, 12:32 AM   #1724
Yes we followed the instructions and it's not our first diff build... Weird :s
Old 07-05-2016, 02:07 AM   #1725
RC*PHREAK's Avatar
Hi guys,
when i had a 22SCT, my thrust bearing washers completely disintegrated and others had the same issue along with snapping diff bolts and the solution was to buy associated parts. once i did that, i never had any issues. weird that you and your friends have seen failures with the AE stuff.
