    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree24Likes
Old 03-15-2016, 06:46 AM   #1426
Hi All,
I'm new to the forum. I'm after some setup help with my SC5m running in the UK on high grip astro turf. Really struggling to find setup sheets for astro or carpet. Im struggling with lots of body roll resulting in grip roll. I had added stiffer front springs (AE Grey), raised front and rear roll centres, and laid the front shocks down as much as possible (inside hole on the tower, and outside hole on the suspension arm).
Any help would be much appreciated.
David
david85williams is offline   Reply With Quote
Old 03-16-2016, 10:40 AM   #1427
JAE
Trader Rating: 28 (100%+)
Anyone running slicks on these? Looking at high grip clay at SCVRC, and potentially to run them at OCRC. How do slicks perform and do you need to change your setup/ride height?
JAE
JAE is offline   Reply With Quote
Old 03-16-2016, 11:29 AM   #1428
I have run slicks at Outback on mine. They were awesome. I didn't change my ride height , but probably would have went faster and been more predictable if I had.
afm223 is offline   Reply With Quote
Old 03-16-2016, 02:09 PM   #1429
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Originally Posted by david85williams View Post
Hi All,
David
Decrease droop by adding more limiters under the piston.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 03-16-2016, 03:37 PM   #1430
AccessRacer's Avatar
Does anyone have a good outdoor 1/8th scale loose track setup?
AccessRacer is offline   Reply With Quote
Old 03-16-2016, 06:33 PM   #1431
I just received my used sc5m roller in the mail today. This thing is clean. It has some hop-ups already installed...light-weight gearing, 3 gear tranny, aluminum rear hubs, aluminum bellcrank, titanium turnbuckles. I started looking at possible layout configurations.
Thus far, I have two questions (more to follow...lol:
1) I plan on using my HW sct pro as my esc. I typically have seen this esc used in 4x4 sct. Any reason why this won't work in a 2wd sct?
2) Does anyone know if the Savox 1258 servo will fit in the sc5m? Is anyone running this servo? If so, how do you have it mounted? I can't seem to figure out how to fit it in there with the steering bellcrank linkage.
TIA
Patt
freezeframe007 is offline   Reply With Quote
Old 03-16-2016, 06:36 PM   #1432
It also has this little blue aluminum bar/bracket protruding from the tranny on the opposite side of the slipper (motor side). I have no idea what this is for. Never seen this on any vehicle to date.
Old 03-16-2016, 06:41 PM   #1433
Moderator
bds81175's Avatar
I run the 1258 in mine. No servo spacers. THe SCT Pro will work just fine. What motor are you planning on running? I'm guessing at the bar/bracket thing (throw a picture up) but maybe a fan mount??
Tekno RC
Old 03-16-2016, 07:01 PM   #1434
Ok...I got the bar/bracket thing sorted out. It is a fan bracket...lol. Never seen one of those before.
Bds81175...
Can you post a photo of the 1258 installed? I just don't see how I can fit it in there...
Old 03-16-2016, 07:29 PM   #1435
I have a Red VX 8.5 I was going to put in it. I plan on running in a open mod class. This motor has timing adjustment which isn't necessary in mod I guess. I also have several non-timing Tenshock x211 motors to include a 7.5 and 10.5.
Old 03-17-2016, 02:13 AM   #1436
Thanks for the reply. I shall try adding limiters as suggested. Sounds like a good suggestion.
Old 03-17-2016, 02:52 AM   #1437
ScottKelly911's Avatar
Primes will work at SCVRC on a race night, but on practice days, you're better off with Proline Electrons due to less frequent watering. At OCRC, slicks don't work, you can run either Proline Electrons or Jconcepts Dirt Webs there, they both work well.
Associated B6D w/laydown, Hobbywing Just Stock/Schuur Speed 17.5 Race Car
Associated SC5m 2wd Shortcourse truck Tekin RS Pro/Reedy Sonic 8.5 Race Truck
Tekno SCT410, Tekin Pro4hd 3000kv on 3s Mostly for fun
Associated B5M, Hobbywing Just Stock/Reedy 8.5 Mod Just for fun
Home track OCRC & Home away from home SCVRC
ScottKelly911 is offline   Reply With Quote
Old 03-17-2016, 03:47 AM   #1438
Hi All,
David
I've been running on similar surface. I was running 4 limiters in all 4 shocks, 45 wt grey truck Springs and a front sway bar up front from a sc10, no shims on front shock tower. 40 wt with white truck Springs in the the rear. 4mm shims on rear aluminum hubs, no shims in the center. Slam the truck to the ground. I was running worn dboot nanobytes on front and a fresh pair on the rear in A compound.
Newbie Rc Guy is offline   Reply With Quote
Old 03-17-2016, 06:04 AM   #1439
Hey guys, trying to figure out if I have a defective plastic ball diff gear that came in my SC5M kit. On my gear, only one side of all the ball pockets have a 'ridge' on them that the balls have to snap past to be seated. On the opposite side, no 'ridge' and the balls freely drop into their pockets. Is that the way it was originally designed or are there supposed to be ridges on both sides of the pockets and/or no ridges on both sides?
Phugazi is offline   Reply With Quote
Old 03-17-2016, 08:14 PM   #1440
UPDATE:
I notice that this build has the blue aluminum bellcrank steering linkage. Don't think this was stock...I could be wrong. Assuming this is not stock, I wonder if this is why I can't fit my Savox 1258 black addition servo (not enough clearance). I am not sure if the original user had a low profile installed or not.
Has anyone successfully installed the Savox 1258 in the sc5m with the aluminum bellcrank system? If so, pics would be awesome!
If this was a buggy, I wouldn't have an issue going with the 1251. I would have plenty of room. But, it is a hair slower and 30oz weaker than the 1258.
I watched a stock build video and they install the airtronics 94661 which has equal or better specs. In the video, it looked like the rack parts were plastic. Unfortunately, the airtronics has the exact same size specs as the 1258.
I am at an impass with this build at this point.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
