    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 02-19-2016, 10:32 AM   #1381
Gigasipke's Avatar
Originally Posted by hsp-sandiego View Post
My 3 gear SC5m is hooked up - Question: what ride height are you running with in your setup? If traction rolling is a issue, it may be too high.
Ride height is around 24-22. It has the truck greys front and rear, 50/45 oil and 1.6 2 hole front and rear.
My son can push the truck as hard as he wants and short of having a horrible line and crossing the groove it doesn't traction roll with the 4 gear.
I was thinking about it more and one difference his truck has over everyone else are the tires. His has ghosted clay Barcodes where as mostly everyone else runs Proline Primes or some other slicks.
Our outdoor season is coming up quickly so I am not going to experiment with the 3 gear anymore but just thought it was weird how it acted differently on the SC5M compared to the T5M and our B5M's.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 02-21-2016, 07:02 AM   #1382
I've only traction rolled because one corner exit/entry into another at my track puts the truck facing sideways down a steep slope in order to punch it onto the main straight. Only rolled if I tapped the brakes. But it could also be my roll centers as I've changed them from kit setup.
I've changed the front springs, roll centers, rear shock angle, front toe out from the kits. The kit setup seems to be more setup for the US point and shoot style of the US tracks.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 02-21-2016, 12:56 PM   #1383
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Have any pictures of the track you race on?
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 02-22-2016, 08:01 AM   #1384
Well, the track just got ripped up this week, if everything goes well. The track will be ready to race on a new layout and clay this Friday. Hoping that my setup will work on it well enough as a starting point. It's good enough that it's actually drivable for me. Kit had too much front grip bias and not enough turn in at low speed. Track has a mix of low and high speed corners.
Been a little busy with the upgrade. Not sure how it will go with a 10.5. Only one way to find out.
I've also done something a little different with my wiring by running the sensor wire under the batteries.
Old 02-22-2016, 08:09 AM   #1385
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
your A wire looks like it has too much stress on it
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-22-2016, 08:42 AM   #1386
It's fine, I do my wire lengths without a pinion on and the motor as far away possible from the ESC. There is actually some slack in it.
Old 02-22-2016, 09:21 AM   #1387
Did you solder it at an angle? I thought it was kinked, but looking again, looks like it was soldered at an angle.
Old 02-22-2016, 10:53 AM   #1388
jstump's Avatar
Send a message via Yahoo to jstump
Originally Posted by Cautrell05 View Post
I'm pretty happy with mine. Best handling short course I have driven yet.
Nick
What chassis and other non AE parts are those?
Team AE RC10SC5M / RCConcept 120Esc/5.5/Savox/Proline/AirTronics MT4
Team AE B5M Lite/RCConcept 120Esc/5.5/Savox/Proline/AirTronics MT4
Tekno EB48.3 1/8 ebuggy, hobbywing esc, RCConcepts motor, Savox, Proline, Airtronics MT4
Tekno 410.3 4wd Sct, Hobbywing esc, Smc 4500 motor, Savox, Proline, Airtronics MT4
jstump is offline   Reply With Quote
Old 02-23-2016, 06:10 AM   #1389
Ive searched the thread, does anyone have a good setup for a medium to low grip, bumpy dirt indoor setup? Ive got a problem with pushing into corner and losing the rear on exit. I am using Cav's Roar setup, but our track is far from a smooth national track.
GNCC407 is offline   Reply With Quote
Old 02-23-2016, 07:31 AM   #1390
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Gear or ball diff?
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 02-23-2016, 08:37 AM   #1391
sduffy77's Avatar
Trader Rating: 17 (100%+)
Originally Posted by bds81175 View Post
Gear or ball diff?
Yeah Cav's setup wont work in those conditions. You'll want to use softer springs, lower shock weight, raise the ride height, play around with the droop to control the weight transfer. Ideally you'll want a ball diff.
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 02-23-2016, 08:47 AM   #1392
Ball diff with 3 gear.
Old 02-24-2016, 01:22 AM   #1393
Yep, they are on an angle, the Xerun brushless has easily removable plugs to the poles, so if the motor blows no soldering is required to swap the motor.
Old 02-24-2016, 06:13 PM   #1394
I recently bought a sc5m, and trying to figure out what wheels to buy. Specifically knowing what wheel hex wheels i need. I was looking at the JC Concepts F-11's they say they have 12mm hexes? But i am going thru this forum and am seeing 8mm and 6.5mm hexes? What should I be looking for?
Lvxlr8n is offline   Reply With Quote
Old 02-24-2016, 07:08 PM   #1395
12mm is what you're looking for. It's the diameter of the hex adapter on your axles. 8mm and 6.5mm is the thickness of that adapter which affects width of the wheelbase.
I have both 0mm and 3mm offset wheels and they both seem to work. A wider wheelbase should result in a more stable truck, but I do not know of other considerations. I personally have not had functional issues with the 0mm offset wheels I share with an SC10 4x4.
epounds is offline   Reply With Quote
