    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 01-15-2016, 06:12 AM   #1276
sduffy77's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Scooter79rs View Post
I'd say hard packed and dry.
Originally Posted by Newbie Rc Guy View Post
I've had good luck with holeshots when it was damp, then gridiron 2's or square fuzzies when it dries out . Depending on the amount of dust .
My summer track is a hard packed clay/dirt mix. During the day when it's dry we run holeshot M4s then when the sun goes down the traction comes up we run electron M4s.
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 01-15-2016, 08:02 AM   #1277
sduffy77's Avatar
So I'm trying to run Cavs setup and it says he's using the 6mm wheel hex up front. I got the clamping axles however when I try to put the wheel on the threads don't go far enough to snug the wheel tight.
Has anyone run into this issue and if so how did you get around it?
Old 01-15-2016, 08:23 AM   #1278
I have the same issue with the front 6mm hexes. I just run a washer under the wheel nut.
islandscott is offline   Reply With Quote
Old 01-15-2016, 08:27 AM   #1279
sduffy77's Avatar
Well I found earlier in this tread it was discussed and AE customer support said it will be a running change and to contact them for replacement.
Old 01-15-2016, 09:18 AM   #1280
Fyrmed2's Avatar
If you don't want to wait you can just shim the back side of the axle.
Hobby Town USA - Lake in the Hills
Timewarp Raceway
IAFF Local 2392
Fyrmed2 is offline   Reply With Quote
Old 01-15-2016, 11:52 AM   #1281
ryan432greening's Avatar
Is there any way to build this kit and use stick packs? I'm not interested in purchasing 3 or more shorty's just for this one truck.
I mainly run dirt oval and we use stick packs for this. Also, stick packs in my SCT410.3.
B-Main Racing
TLR 22 3.0, 22-4 2.0, 8ight-E 4.0, 8ight 4.0
GFRP M1
ryan432greening is offline   Reply With Quote
Old 01-15-2016, 12:09 PM   #1282
Jpdanger's Avatar
Three shortys? Many people use one or two packs all day long.
You can make a stick pack fit by cutting the brace between the battery hold down screw posts.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 01-15-2016, 12:27 PM   #1283
sduffy77's Avatar
Exclamation
Brilliant! I'll try that tonight
Old 01-15-2016, 01:09 PM   #1284
Anyone tried this with success on not losing too much handling?
B-Main Racing
GFRP M1
Old 01-15-2016, 01:14 PM   #1285
Originally Posted by Jmuck69 View Post
The coating makes the shock shaft last longer(wear) vs chrome which ads smoothness. It's a trade off. I prefer the smoothness of the chrome.
Actually Kashima coating is more durable AND smoother. The hard anodizing process fills more holes in the surface of the body. Think of it like grits of sandpaper. 400 grit is much smoother than 80 grit. That's how Kashima works. It's a harder, smoother surface for moving parts to glide on.
B-Main Racing
GFRP M1
Old 01-15-2016, 01:15 PM   #1286
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Just buy 1 shorty (or a brick pack)...I have not seen or read about someone using a full stick pack. You will be fine with 1 pack.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-15-2016, 01:17 PM   #1287
Super Moderator
Pretty sure he was talking about shock shafts. There are no Kashima coated shafts..only bodies. The shafts are either chrome or ti-nitride coated. Chrome is smoother but the ti nitride will last longer.
Annnnd that was 7 months ago...
Old 01-15-2016, 01:31 PM   #1288
I took it as he was comparing the standard ano bodies to the Kashima coated ones. And excuuuuuse me for just reading through the thread now.
B-Main Racing
GFRP M1
Old 01-15-2016, 03:58 PM   #1289
1M
1M's Avatar
Trader Rating: 35 (100%+)
Like others have said, cut in between the battery post, I put a carbon fiber plate across the antenna mounts. Notched out to hold the front of the battery.
1M is offline   Reply With Quote
Old 01-15-2016, 04:16 PM   #1290
Jmuck69's Avatar
I was refering to the Ti nitride coating on the shaft (gold color) vs. the chrome.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
