    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 01-05-2016, 12:38 PM   #1246
cbass722's Avatar
Originally Posted by cbass722 View Post
I just got the MIP 3 gear trans and the MIP top shaft and the bearings don't seem right. I think I'm doing something wrong. I should be able the stuff out of the 4 gear stock trans
Yep had to put the bigger bearings in
cbass722 is offline   Reply With Quote
Old 01-05-2016, 11:41 PM   #1247
Unhappy
Got my kit in today. Started putting it together and hit a couple of snags. The nut for the long diff thrust bolt has no threads in it. Then when I was working on the front spindles I found I got 5 of the #3 steering block inserts and only 3 of the #2-4 inserts. I guess I'll be calling AE in the morning.
65BAJA is offline   Reply With Quote
Old 01-06-2016, 12:12 AM   #1248
ScottKelly911's Avatar
oh cool, you got the new threadless diff bolt!
Associated B6D w/laydown, Hobbywing Just Stock/Schuur Speed 17.5 Race Car
Associated SC5m 2wd Shortcourse truck Tekin RS Pro/Reedy Sonic 8.5 Race Truck
Tekno SCT410, Tekin Pro4hd 3000kv on 3s Mostly for fun
Associated B5M, Hobbywing Just Stock/Reedy 8.5 Mod Just for fun
Home track OCRC & Home away from home SCVRC
ScottKelly911 is offline   Reply With Quote
Old 01-06-2016, 06:25 AM   #1249
sduffy77's Avatar
Trader Rating: 17 (100%+)
Yeah I ran into several issues with my build as well. I contact AE support and they're sending me the parts I need. Luckily I ordered two kits with extra parts so I was able to race this past weekend.
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 01-06-2016, 08:08 AM   #1250
Originally Posted by bds81175 View Post
A lot of it depends on the design of the jump too. I usually attempt to stay on the throttle just a bit when the tires leave the jump face and then use a touch of brakes to bring the nose down to downside the landing. If you are wide open throttle for too long in the air, it will be tough to correct it with the brakes. While in the air, throttle brings the nose up, brakes bring the nose down.
im going to try a little drag brake. I use the throttle mostly on my t5m and b5m but the sc5m seems a lot slower at reacting.
Originally Posted by islandscott View Post
If it's only on big jumps, is your body parachuting? Do you have vent holes cut out? If anything, the truck seems to nose down jump for me.
everything is cut open
Originally Posted by sduffy77 View Post
if you're going nose up on the big jumps maybe you need to let off the throttle a little sooner.
if I let off the throttle sooner I don't make the landing .
bo duke is offline   Reply With Quote
Old 01-06-2016, 08:48 AM   #1251
sduffy77's Avatar
is your slipper too loose? Do you need more motor?
Old 01-06-2016, 10:53 AM   #1252
jstump's Avatar
Send a message via Yahoo to jstump
Default Sc5m Xfactory Chassis
Is anyone using it? Thoughts on it? Any running video?
Team AE RC10SC5M / RCConcept 120Esc/5.5/Savox/Proline/AirTronics MT4
Team AE B5M Lite/RCConcept 120Esc/5.5/Savox/Proline/AirTronics MT4
Tekno EB48.3 1/8 ebuggy, hobbywing esc, RCConcepts motor, Savox, Proline, Airtronics MT4
Tekno 410.3 4wd Sct, Hobbywing esc, Smc 4500 motor, Savox, Proline, Airtronics MT4
jstump is offline   Reply With Quote
Old 01-06-2016, 12:35 PM   #1253
JFuel11's Avatar
Trader Rating: 152 (100%+)
Thoughts on those who have tested Square Pack vs Shorty Pack Recently?
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 01-06-2016, 12:51 PM   #1254
I am using the Plan B carbon chassis with a inline shorty and it made a huge difference in how the truck handles its alot more nimble and jumps way better.
Scottysspeedsho is offline   Reply With Quote
Old 01-06-2016, 03:31 PM   #1255
the slipper is good and I'm running 8.5.
Old 01-07-2016, 05:54 PM   #1256
sduffy77's Avatar
Does anyone have or know where to find a spring chart that lists all the latest AE springs, part numbers, colors, and rates?
Old 01-07-2016, 06:32 PM   #1257
SnotRkt's Avatar
Is the only place to get those Plan B chassis on Facebook? I was looking for a site but couldn't find one...
AE RC10B6, TD DEST210R
SnotRkt is offline   Reply With Quote
Old 01-07-2016, 06:36 PM   #1258
1M
1M's Avatar
Trader Rating: 35 (100%+)
If you are looking for a carbon fiber chassis, check out Team GFRP on face book.
1M is offline   Reply With Quote
Old 01-08-2016, 07:28 AM   #1259
jtodd57's Avatar
Thumbs up
The parts listing breakdown in the back of the SC5M instruction manual, I believe is the most current.
Jeff Todd-Jackson, MI
Fantom Motors & Killer Voltz Batteries
Pro-Line Racing
Team Associated B6D
Salvas MudBoss oval spec racer
jtodd57 is offline   Reply With Quote
Old 01-08-2016, 07:52 AM   #1260
I ran my SC5m for the first time tonight, seems to go well, just need new tyres tho as I have the wrong ones for low to medium grip dirt/clay.
Speaking of what would be some setup tips for low to medium grip dirt/clay to help reduce sharp low speed turn in and possible loose rear end that will slide out under power. Think I may need to loosen the diff a little. BUt mostly want to know a couple tricks for next week.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
