    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree24Likes
Old 12-07-2015, 02:20 PM   #1156
Gigasipke's Avatar
Picked up an SC5M for my son to replace his 6 year old SC10. Well there might be a part on it that is 6 years old but most has been replaced through the years.
Since we already have, 1 B5, 3 B5M's and 1 T5M, the build went pretty well. It was missing 2 Flat head screws for the bulkhead. The only semi-major issue was the one of the HD CVA Axles (71019) wasn't machined right and the outside bearing would not slide on all of the way. Instead of waiting on the build I dremeled it down until the bearing would fit. It seems to be centered properly, at least I hope so.
Yeah and also the 2 HD ballstuds (91049) had the threads machined wrong. As they bottomed out in the Aluminum Rear Ball Stud Mount (91520) they kept spinning. Luckily I had a couple spares 12mm ones in my tool box and they worked fine as replacements.
We run Slicks on Ozite carpet so I couldn't find a setup, although I set it up close to my T5M. Will probably need to play with roll center and camber to get it right. I love the 5 series vehicles, only an SC10 and B4.1 left.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 12-07-2015, 05:51 PM   #1157
Trader Rating: 42 (100%+)
C Mount insert question. When using the inserts with L & R on them, does the R go on the right when the mount is on the chassis or when holding the mount and looking at the R? The mount numbers face the front of the car when mount is installed. If I install R on the right while holding the mount and looking at it and then install on the chassis it's on the left rear side??
Bartman42 is offline   Reply With Quote
Old 12-08-2015, 12:12 AM   #1158
aeRayls's Avatar
Install them on the side of the chassis that it's marked.
aeRayls is offline   Reply With Quote
Old 12-08-2015, 04:14 AM   #1159
For clarification, you are saying the R goes on the side that the right rear tire is on?
Old 12-08-2015, 09:04 AM   #1160
aeRayls's Avatar
Correct
Old 12-08-2015, 09:23 AM   #1161
jtodd57's Avatar
what size flat sensor wire should I order for my SC5M to run under battery with a 3gear transmission?
Jeff Todd-Jackson, MI
Fantom Motors & Killer Voltz Batteries
Pro-Line Racing
Team Associated B6D
Salvas MudBoss oval spec racer
jtodd57 is offline   Reply With Quote
Old 12-08-2015, 09:36 AM   #1162
I used a 200mm sensor wire to go under the battery.
RyanH is offline   Reply With Quote
Old 12-09-2015, 04:52 AM   #1163
My kit is built. Hands down, the nicest build ever. No missing parts, no defects and nicely laid out. The new ball cups are the cats a$$.
A special thanks to Amain to fix USPS screw up. On Nov 23rd an order was placed with Amain and on Dec 5th I received a box that had a chevy 5.3 water pump. Yes, a freaking water pump. Amain reshipped my order with one day delivery from CA to IN and ate the $63 shipping charge. Now that’s customer service!!
Also thanks to AErayls for clarifying the C mount inserts
Old 12-09-2015, 11:24 AM   #1164
SC Shaun's Avatar
Send a message via Skype™ to SC Shaun
Could someone tell me what your running weight is? The site does not have any information.
Just a overall weight without body would be fantastic.
SC Shaun is offline   Reply With Quote
Old 12-10-2015, 08:40 PM   #1165
Cridd's Avatar
Trader Rating: 16 (100%+)
I can't remember thinking like 1750 plus or minus depending on Ti
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-11-2015, 06:39 PM   #1166
Build is complete. I was torn between 3 gear and 4, decided on 4. Going to be testing on Sunday at club race.
Old 12-11-2015, 08:32 PM   #1167
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
If you are racing indoors on anything more than medium grip, try the 3 gear. I really like how it feels. It makes the truck more neutral under braking and acceleration.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 12-12-2015, 06:25 AM   #1168
I'm running on large indoor med/high bite. I planned on building 3 gear but I got to drive one that was built per kit. It felt so balanced that I had to try the kit build first. I have all the stuff for 3 gear and will give it a try in the near future for comparison.
Old 12-12-2015, 10:08 PM   #1169
MNiceGuy's Avatar
Ran my new SC5M for the first time last night. Super impressed so far!
A couple things I'm confused on:
1. I am running the Fox/Kashima shocks. What is the proper aluminum cap for these?
2. I have machined, tapered pistons along with the Ti-Nitride coated shafts. When I mount the piston to the shaft the piston can move around even with the screw all the way down. Assuming this is simple as finding a tiny shim?
3. My shock bodies, front to rear, are slightly different colored. It's almost as if the Kashima coating on the fronts is thinner than the rear; causing them to be a slightly lighter tint. Is this common?
MNiceGuy is offline   Reply With Quote
Old 12-13-2015, 08:04 AM   #1170
Cridd's Avatar
They come with a small washer/shim to go on with piston. Should of been in package.
Pretty normal.
Chris
B6D / T5M / SC5M
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
