    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 11-22-2015, 09:21 AM   #1111
im looking for a little tuning advice. on my local track its high grip clay and im im getting a lot of front end diving and wheel chatter up front and a little push. im at 30mm in the front and 28 rear for ride height . I have the grey spring up front and white rear and 32.5 shock oil. should I be using a higher shock oil?
bo duke is offline   Reply With Quote
Old 11-22-2015, 01:49 PM   #1112
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Higher weight oil in the front will help. I believe I am at 37.5 now.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 11-22-2015, 02:01 PM   #1113
that's what I was thinking . anything else you would do?
Old 11-22-2015, 03:53 PM   #1114
Moderator
bds81175's Avatar
I've raised my roll center in front (no washers under the inner ball stud and short link). Are you running the 3 gear yet? That helps reduce some of the movement front to rear on and off the throttle and brakes. I should be looking at this from a different perspective: diving and chatter are symptoms, not the performance problem. What part of the track is the truck not performing in properly that is causing you to lose lap time?
Tekno RC
Old 11-22-2015, 05:24 PM   #1115
Mostly on really tight corners I notice it . The rest of the track It feels good other than diving a little more than I'm used to. No 3 gear Trans either.
Old 11-23-2015, 07:43 AM   #1116
jakeb's Avatar
Quick question...
What's the handling change or ride characteristic of running 0 offset wheels vs the +3 offset wheels? Are there any 'yes definitely run 0 wheels' in certain cases?
Thanks!
Jake
jakeb is offline   Reply With Quote
Old 11-23-2015, 11:07 AM   #1117
vfrninja's Avatar
If it's really high bite lower your ride height . This does wonders for the truck. Also the 3 gear really helps. I'm at 35wt up front with the 1.5 pistons.
vfrninja is offline   Reply With Quote
Old 11-23-2015, 11:30 AM   #1118
Trader Rating: 478 (100%+)
Originally Posted by jakeb View Post
Quick question...
Thanks!
Jake
You will reduce your track width by 6mm. I'm not sure about the physics of it other than you're making the truck more top heavy by raising the roll center. Its not necessarily the worst thing that you could do but my truck feels better wider and I don't think it needs any additional steering. If traction is low and you can afford to raise the roll center it might not be that bad. I dunno. I'd just stick with the +3s.
I read up. What I found is that wider track will tend to reduce the load transfer to the outside when cornering, which in general will increase cornering power since you'll be able to get more traction from the inside tires. So once again, increasing the track will tend to reduce understeer.....so making the car narrower will increase understeer. Contrary to what I thought it might actually reduce steering. Last, by narrowing the truck you will also change the balance front to rear as you change the ratio of width & length.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-23-2015, 11:53 AM   #1119
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
When using the "middle" hole on the rear arms, can the arms be used interchangeably?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-24-2015, 02:19 AM   #1120
Any changes to the rear with your setup?
Old 11-24-2015, 03:47 PM   #1121
Cridd's Avatar
Trader Rating: 16 (100%+)
AE if your out there, let's see some set ups on the AE site, SDRC, OCRC, Stock Nats, anything greatly appreciated.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 11-24-2015, 03:51 PM   #1122
they are on their webpage
Also, cav said he pretty much always runs the same setup with small roll center changes. He most tunes with tires and just drives the car. The pros spend more time cleaning cars, than tuning them
Old 11-25-2015, 06:14 AM   #1123
vfrninja's Avatar
I'm running 3x1.4 pistons with 32.5wt. Not sure it's needed though. I just wanted it close to my sc10, which is still a bit faster.
Old 11-26-2015, 04:38 PM   #1124
the only setup sheets I see on the associated website are both from Cavalieri.
and there basically the same. it would be nice to see what some other people are doing. I need help getting this truck to hook up. the back end is squirrely as hell
walter white is offline   Reply With Quote
Old 11-26-2015, 07:06 PM   #1125
Moderator
bds81175's Avatar
3.5 rear toe with the brass hinge pin brace, stiffer front spring and oil...otherwise, the correct tires for the track. I'm running a short wheelbase with the 3 gear and I can put down power like crazy. Brick pack all the way back. I'm running on relatively good grip indoor clay. I have a new set of Panther Rattlers on that have great grip but are wearing quicker than the MC Electrons that I had previously.
Tekno RC
