    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 11-10-2015, 06:44 PM   #1066
Gpeters66's Avatar
Originally Posted by Jim Hustins View Post
According to AE, same # as T5m #71013
https://www.teamassociated.com/parts...xles_clamping/
Those are the axles I have right now and I have to use a washer on the axle or I cant tighten down the wheels
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 11-10-2015, 06:46 PM   #1067
So I went and practiced today and the only things I did was I rebuilt the fronts using the 37.5 and it ran awesome. It is a new layout and the first time in this new layout so maybe it was just the last track I wasn't set up for. It was a long banked corner I was lifting the front wheel on and there's none on this layout. Must say I do love the new REEDY Mach 3 though. oh and I used my square pack and not a shorty. Loved the handling.
Polock is offline   Reply With Quote
Old 11-10-2015, 11:53 PM   #1068
Trader Rating: 40 (100%+)
I had the same issue and contacted AE. They are aware of the problem, currently working on a running change to the part to cut another mm or two of threads into the axles...
Keep running the washers for now? I'm using the stock axles instead of the clamps.
AE!
maddysdaddy is offline   Reply With Quote
Old 11-11-2015, 06:29 AM   #1069
I'm new to this sport so be kind.
I built one of these for a first kit and taken it to an indoor clay track for a few practice sessions. I set it up the way it was recommended in the manual. Running a 17.5 stock setn with JConcepts gold tires. Two observations:
1: I'm fish tailing around a 90 degree turn after a long straight away. Am I entering the turn too fast or do I need to adjust the setup?
2: The front tires are building up clay much faster than the rears. Am I landing too hard on the front?
John Sargent is offline   Reply With Quote
Old 11-11-2015, 10:34 AM   #1070
I have the same issue. I had quickly put the axles on the other day and had not noticed the nut was bottoming out. This is very frustrating as AE already had to replace two sets of axles for me because of bad threads. I contacted them and they will send me out a new set, but only after they tried to tell me the 6mm clamping hexes are only meant to narrow the rear, and not use on the front.
islandscott is offline   Reply With Quote
Old 11-11-2015, 07:26 PM   #1071
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
John Sargent, you've got a PM
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 11-11-2015, 07:28 PM   #1072
Trader Rating: 478 (100%+)
I'm not sure about problem 1. If its not a set up issue perhaps your on the throttle too hard or maybe you're letting off the throttle too much. Not sure about that one. Lots of variables....if you're using gold compound, what kind of inserts are you using?
Your second problem is normal. The rear tires are under power and throw the clay while the fronts just roll along and collect it as they go. When you jump and you blip the throttle you largely clean the rears off but the fronts don't "spin" quite like the rears.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-12-2015, 06:59 AM   #1073
Thanks for your reply. I'm using the inserts that came with the gold tires.
Now I understand why the fronts crud up. I'm pretty sure it is my throttle technique causing the tail spins. Perhaps I'll get better with more practice.
Old 11-12-2015, 09:31 AM   #1074
JayL's Avatar
Has anyone tried the JConcepts Ti ones? Do they have more thread and no need for washer?
http://www.amainhobbies.com/rc-cars-...o2440t/p448444
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 11-12-2015, 01:21 PM   #1075
Cridd's Avatar
Trader Rating: 16 (100%+)
I use them on all my 5 series cars and no washers, they are great.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 11-12-2015, 02:20 PM   #1076
Fyrmed2's Avatar
Yes washers needed if your running +3 JCONCEPTS wheels.
Hobby Town USA - Lake in the Hills
Timewarp Raceway
IAFF Local 2392
Fyrmed2 is offline   Reply With Quote
Old 11-14-2015, 02:27 PM   #1077
cbass722's Avatar
Does anyone know if the mip puck system on the sc10 will work on sc5. Im switching my old sc10 to run mod and im gunna run blinky with the sc5.
cbass722 is offline   Reply With Quote
Old 11-14-2015, 07:24 PM   #1078
cbass722's Avatar
What a good ride height for a high grip track
... FT SC10.2
.... SC5M
..... B44.3
...... BBA RACING
Old 11-15-2015, 12:33 PM   #1079
The MIP Puck system for the SC10 will not work on the SC5M
Dyechainsaw10 is offline   Reply With Quote
Old 11-15-2015, 04:14 PM   #1080
Fyrmed2's Avatar
Try 28 front 27 rear. Stock is 30 front 28 rear.
Timewarp Raceway
IAFF Local 2392
