    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 11-05-2015, 03:30 AM   #1036
Hasi's Avatar
Originally Posted by jpcopeland1 View Post
I think you would be hacking the crap out of the B5M body to make it fit. May not be worth it.
Originally Posted by Dino_D View Post
I actually use the outerwears for the SC10 2x4. Its not the exact fit but it works. Or you can use the SC10 4x4. Remeber the fit isn't exact, but it does do a good job of keeping most of the dust and dirt out.
I wanted to buy the Traxxas Slash 4x4 outwear, as it definitely has more room to spare and having the zipper open up the middle doesn't require me to peel the velco off everytime for a battery change.
Thanks to both of you.
Will have a look for that outerwears stuff.
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage, Tamiya Mercedes Arocs 8x4
Hasi is offline   Reply With Quote
Old 11-05-2015, 06:22 AM   #1037
vfrninja's Avatar
Anyone else having problem with this truck nosediving? It wants to nosedive, ALOT and I cannot seem to stop it. 17.5 blinky, 3 gear, No drag brake, stock set up. 2 small pads behind battery and i have even tried it all the way back. I even tried the grey springs in the rear and no help.
any good advice would be appreciated.
thanks
Grey in the rear? Thats gonna make it worse.
Need to go to grey front truck springs, or greens in the rear. I run 35wt oil up front too. Mine liked to jump a little nose down too until I put in the three gear trans. Now it jumps and flys amazing. You can also take some stroke length or "droop" out of the rear.
vfrninja is offline   Reply With Quote
Old 11-05-2015, 07:17 AM   #1038
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
3 tracks, stock springs first track, gray front-stock rear last two tracks.
Gray spring only mod, square battery, SC5m has never jumped nose down OR up!!!
BUT have raced a SC10GT-E for two years.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 11-08-2015, 08:49 PM   #1039
kbish76's Avatar
Default Yokomo dif
Does anyone know or has anyone tried to mate a yokomo diff case with its motor plate to the sc5m chassis? I know that yokomo and associated use to share a lot of similar parts back in the day. I'm asking because I will be switching to a carpet track and the yok has that lay down diff which would help a lot.
-Thanks
kbish76 is offline   Reply With Quote
Old 11-08-2015, 10:53 PM   #1040
Trader Rating: 478 (100%+)
Is it possible that all the nose diving is due to driving styles?
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-09-2015, 06:50 AM   #1041
-Thanks
You can put the reds laydown in it to change the weight bias and lower cg might be worth looking into to have a lower cg with a truck
Felix v.
Ae sc10.2, xray t4 2016 usgt,wrc f-one 016, Tamiya m05 mini
Expensive is not always faster
Scionara05 is offline   Reply With Quote
Old 11-09-2015, 07:47 AM   #1042
kbish76's Avatar
Isn't the red diff like $100? Where as the yok is $6 for the case, $30 for the gears, and $6 for the motor plate. A much more easier pill to swallow.
Old 11-09-2015, 07:56 AM   #1043
kbish76's Avatar
Agreed. When I first tried the sc5m from a sc10.2, it did the same thing. Then I reliesed that I need to be hitting the face of the jump with the same power all the way up it and not "gun it" up the face. When's it's in the air you have to keep the rear wheels spinning forward a little. A mid motor can get its nose down a lot easier than a rear motor. As I have switched my sc5m back to a 3 gear to help on a loose track, this principle still applies. Only difference is that now with a 3 gear it tends to nose up a little more easier in the air.
Old 11-09-2015, 10:10 AM   #1044
Tim W.'s Avatar
I can't be the only one out there running this thing on a carpet off road track. Anyone else out there? I want some second opinions on a set up!
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
Old 11-09-2015, 11:18 AM   #1045
kbish76's Avatar
Default Carpet
I will be switching to carpet next month. And was told be a factory driver that I should be getting hard arms front and rear. Gear diff w/3000-5000 wt.. Already have the brass c but add the brass front kick up 25g.. And possible rear sway bar. Also looking to add a lipo plate 25g.
Old 11-09-2015, 11:34 AM   #1046
Tim W.'s Avatar
Whats the part number to the sway bar kit? I think I'm going to do the gear diff next!
Old 11-09-2015, 12:00 PM   #1047
https://www.teamassociated.com/parts...l_bar_kit_b5m/
Scottysspeedsho is offline   Reply With Quote
Old 11-09-2015, 07:26 PM   #1048
What is the heaviest front shock oil anyone is using? My truck jumps great but noses dives in high speed corners. I have 37.5 w/asc white springs now. I'm going to go extreme and try 80wt tmrw. Anyone else try it?
Polock is offline   Reply With Quote
Old 11-09-2015, 10:44 PM   #1049
Cridd's Avatar
Trader Rating: 16 (100%+)
Might try rebuilding the shocks and go up in spring.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 11-10-2015, 02:20 AM   #1050
thanks
So I run 1.6 pistons in the front with 40 wt. oil and no nose diving for me at all. You could just try 37.5 if you want to keep some steering or if your track is low to medium traction. Use the Grey front springs and white rear. and probably 30-32.5 wt in the rear also with 1.6 pistons
Mxer210 is offline   Reply With Quote
