    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 11-02-2015, 05:17 PM   #1021
Suspended
Trader Rating: 61 (100%+)
Originally Posted by mxturd View Post
Is it true that a little longer of power wire to your battery can be harmful, just read something on another site about it. My wires from the esc to battery are about 6 or 7 inches, gives me a little room as I don't want them to be tight
Not even remotely true.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 11-04-2015, 07:34 AM   #1022
dirt42fan's Avatar
Trader Rating: 135 (100%+)
Anyone else having problem with this truck nosediving? It wants to nosedive, ALOT and I cannot seem to stop it. 17.5 blinky, 3 gear, No drag brake, stock set up. 2 small pads behind battery and i have even tried it all the way back. I even tried the grey springs in the rear and no help.
any good advice would be appreciated.
thanks
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Old 11-04-2015, 08:02 AM   #1023
Jim Hustins's Avatar
thanks
Others have posted that they are. I have zero issues using the kit springs. I will post my setup to see if it helps. It has to be something like a ride height issue.
I owe it all to Papa Lou.
Team Driver: Pro-Line, Maclan Racing, Xpert Servos, RC Soup, MIP, ARC
http://www.prolineracing.com/blog/team/jim-hustins/
http://www.youtube.com/user/jjlove1217?feature=mhee
https://www.facebook.com/jim.hustins.rc.racer
Jim Hustins is offline   Reply With Quote
Old 11-04-2015, 08:12 AM   #1024
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Mine jumps fine. maybe our jumps are built better
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-04-2015, 08:16 AM   #1025
Trader Rating: 137 (100%+)
It's entirely possible. We had one jump at LRH that had a very slight lip at the top, and SC's could not hit it right, they ended up redoing it removing the lip, and they jump fine now.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 11-04-2015, 08:17 AM   #1026
thanks
Grey in the rear? Thats gonna make it worse.
Old 11-04-2015, 08:46 AM   #1027
Trader Rating: 81 (100%+)
thanks
Gray spring in front and 1 weight up on the oil mostly fixed my problem. Also keeping on the throttle at the launch point then letting off.
dpcardoza is offline   Reply With Quote
Old 11-04-2015, 08:52 AM   #1028
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
You might be undergeared too. Not enough wheel speed will a lot of times bring the nose down. I haven't had a problem with this either, then again I run a 7.5. Howeverm, I also almost always make an attitude adjustment in the air, either with steering or throttle/brake. Usually they are really subtle.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 11-04-2015, 09:19 AM   #1029
The sc5m is very very sensitive to breaking in the air. It will front flip. I drive of the face on power and have no issues. But some jumps and some layouts require modification to have I drive the jump. I dont feel their is anything "wrong" with the sc5m in the way it jumps.
Old 11-04-2015, 11:12 AM   #1030
Trader Rating: 44 (100%+)
question will 22sct rims fit? I only ask because I have a set left over from the 1.0 22sct and that's an extra set of rims I could be running if they'll work
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 11-04-2015, 11:39 AM   #1031
shadowracer24's Avatar
Yep they'll work fine. Use them on mine and have no issues.
shadowracer24 is offline   Reply With Quote
Old 11-04-2015, 03:04 PM   #1032
Jpdanger's Avatar
Is there an easy to glue SC tires? What a PITA!
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 11-04-2015, 05:00 PM   #1033
thanks
I just got mine together last week and it's not nosediving at all. 17.5 blinky, 3 gear, light drag brake, shorty packs with large spacer in front, all stock setup save for one extra spacer on each shock shaft and ride height around 27mm on panther slicks.
mhyde52 is offline   Reply With Quote
Old 11-04-2015, 05:06 PM   #1034
My sc5m is my first sct, and second modern RC vehicle. I mounted two sets last week, and found them easier than 2wd buggy tires. I did a set of Proline Ions and a set of Panther slicks, both on DE Borrego wheels. The Proline were really easy, seemed like a little stiffer tire and snapped right into place every time. No rubber bands on either type.
Old 11-04-2015, 07:49 PM   #1035
I have found the DE Borrego wheels really easy to glue.
islandscott is offline   Reply With Quote
