    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 10-20-2015, 10:35 AM   #961
Originally Posted by 1967Typhoon View Post
Honest opinions for a racer on a budget:
Is the SC5M worth the cost over a dialed in SC10.2? I'm on medium bite tight indoor track with many 180's and the 10.2 is doing fine. I'm after a "set it and forget" all-purpose setup. Is the SC5M really going to be better in this regard than the SC10.2? Please only respond if you have experience with both trucks. Thank you!
I have only raced the sc5m once so far. But for me is felt a lot smoother all around. Is it faster? i don't know yet but i think once I get used to it a little bit it will be a better over all truck.
Rass79 is offline   Reply With Quote
Old 10-20-2015, 09:04 PM   #962
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default I would say yes
I have ran my SC5m on a smaller 40x80 indoor track that I would consider Medium Grip at best and I feel it is faster than my SC10.2. I TQ and win at our club level with my SC10.2 and had no problem winning with the SC5m. I don't know if I can tell you it was faster but it felt faster and for me it feels much closer to my B5m in the way it drives, jumps and lands now. Plus we have a small sweeper that I can drive through so much harder then I ever could with the rear motor truck. I am still tuning on the SC5m but I have no plans of looking back. I was also running the 3gear trans in it and loved the truck all around with that setup.
I don't think you can go wrong but it may depend on how comfortable you are with a mm vehicle over a rm vehicle.
Let me know if I can help in any way.
Alan
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 10-21-2015, 01:48 PM   #963
TomErickson's Avatar
I just built my new SC5M and tested it on a loose track. What springs are people going to from the kit springs? I am really happy with the truck out of the box. I upgraded to clamping hexes all around. Brass C plate, Ti turnbuckles and an aluminum front hinge pin brace. I also swapped out the 4 gear for the 3 gear tranny.
I am running a Novak Pulse V2 Vulcan 7.5t powerplant with a Reedy saddle pack. So far so good.
---Thanks to my Sponsors: Novak R/C, and Nankin Hobbies ----
TomErickson is offline   Reply With Quote
Old 10-22-2015, 10:50 AM   #964
It's my understanding that you can use any of the big bore springs. You might need to change your cups to get the right height you want.
Old 10-22-2015, 06:19 PM   #965
JFuel11's Avatar
Default Gray Front
I am running 35 Weight and Gray Truck Springs in front, 30 Weight with White Trucks Springs in back and the truck is amazing. Love the 3 gear trans as well. If you are on really loose conditions you may want to consider going back the the 4 gear if you need a little more traction right when you are picking up the throttle out of the corners.
I am running the Bras C Plate and a 30 Gram SMC Battery Weight in the back of the truck and it is very good on Low to Medium Conditions.
Good Luck!
Sponsors:
Old 10-22-2015, 06:39 PM   #966
Trader Rating: 478 (100%+)
On wet dirt I'm running an MIP 3 gear, green truck springs, brass c mount, and a square pack. I was running the same exact settings on high traction bluegroove with grey fr/rr truck springs (Kyosho yellow fr and the stock rears till I got the truck greys). I'll lower the shock oil tomorrow....I've been short on time. The truck is pretty good but not as good as the SC6 was right out of the box. Personally, I think its a little too light. That being said, I'm a believer in the new B5 series and I'm sure that I can get it right. Its not like I'm finishing last....2nd last weekend.
I don't think the truck is really any "faster" than any other but I like it none the less. Cars aren't faster per se, people are faster, track time makes people faster. I don't want to insult anybody but its kinda of dumb thinking that a new rig is going to make you faster. So, just to reiterate, set up, practice, and good choice of tires make you faster....and some people are lucky enough to be naturally more coordinated (not me).
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 10-22-2015, 07:27 PM   #967
robbieg's Avatar
Trader Rating: 26 (100%+)
oops. the search does work.
robbieg is offline   Reply With Quote
Old 10-22-2015, 09:26 PM   #968
Trader Rating: 24 (100%+)
I apologize for asking what has probably been discussed many times, but what gearing are you guys using for 17.5T?
The supplied 78t spur gear doesn't provide room for a pinion higher than 27t. Probably why the manual recommends that pinion size...
The motor is a brand new Reedy 540-M3 Spec, stock timing. Indoor clay track.
Any help would be appreciated.
newob is offline   Reply With Quote
Old 10-22-2015, 10:50 PM   #969
78/26 should be about right. If your motor is a short stack you may want to start with a 25 pinion.
Old 10-22-2015, 11:17 PM   #970
Ok, will give her a go! Thanks for the quick reply.
Old 10-23-2015, 03:17 AM   #971
ALLSPEED's Avatar
To the guy's running the 3 gear tranny. Are you all running 17.5 motors? Is anyone running that tranny in the modded class?
Kyosho evolva M3 EVO O.S. .21xzr? Xray NT1 murnan modded nova,Xray T3,AE T5, sc5m, b44.3,Tekno sc
Mugen 1/8 off road.Tekin esc's, smc batts, team powers motors a winning combination
ALLSPEED is offline   Reply With Quote
Old 10-23-2015, 06:47 AM   #972
Gpeters66's Avatar
I run mod with mine 7.5t and I really like the way it runs. Now I've never ran mine with a 4 gear tranny so I don't know the difference. I used Cav's setup because they always work well for me and he runs a 3 gear.
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 10-23-2015, 01:56 PM   #973
ALLSPEED's Avatar
OK I'll install it and try it out. See what happens.
Also has anyone tried the gear different in this vehicle? I'm having trouble with the ball and thinking of switching it out. I just want to know the opinions of those who tried it already.
Old 10-25-2015, 11:35 AM   #974
I dnt know if this was asked yet the setup sheets dont metion it at least from what ive seen the shim on the rear arms where is everyone putting them the manual says towards the front of the arm but what will it do if i put it at the rear of the arm
Felix v.
Ae sc10.2, xray t4 2016 usgt,wrc f-one 016, Tamiya m05 mini
Expensive is not always faster
Scionara05 is offline   Reply With Quote
Old 10-27-2015, 05:59 AM   #975
I finished my kit and took it to the track for testing yesterday. Somehow, I had messed up the ball diff and the thing had zero traction. Many thanks to Mike at Hobby Town Lake In The Hills for diagnosing and repairing the car.
It ran great.
John Sargent is offline   Reply With Quote
