    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 10-02-2015, 06:41 AM   #886
celt's Avatar
Default droop...simple definition, many ways to measure.
Droop is the amount of down travel a suspension arm has.
Measuring droop for our purposes is probably best defined on the existing setup sheets:
Shock Stroke
Tekno uses the similar measurement, eyelet to eyelet shock length. With off-road having so much more droop than on-road, it's difficult to just set the chassis flat on a tweak board, that won't work. That's why mfg's make 10/20/30mm blocks to measure droop.
Easy to define, many valid ways to measure it. Both ends of the discussion have to agree on method.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 10-02-2015, 09:46 PM   #887
Trader Rating: 40 (100%+)
3 Gear 3 Gear 3 Gear!!
It flies sooo level with the 3 gear tranny. No nose down tendencies at all. Cornering felt great too, just seemed very flat.
I unfortunately had a brand new battery take a dump on me. pulled it off the track after 7ish minutes, to temp check, battery was good. Turned esc back on after a short break, but it was blinking Lipo cutoff. Shouldn't have been. Threw it on the charger, only 4.3V?!?! Perhaps something shorted internally on the battery? Even in NiCd settings to bring it back up, charger was showing error and wouldn't charge it. I will mess with it more soon, but I tossed in my saddle pack and turned some 3 gear fast laps....
AE!
maddysdaddy is offline   Reply With Quote
Old 10-03-2015, 05:34 AM   #888
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Originally Posted by HBRob View Post
23-25 is buggy ride height. Make sure you are looking at a SC5M setup sheet.
Cav's ROAR setup have 25 front and 23 rear
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 10-03-2015, 05:36 AM   #889
Super Moderator
tmail55's Avatar
Originally Posted by tmail55 View Post
Polock, do you have the correct spring cups (5mm) on your shocks?
To get 28 had to use 0mm cups.
Old 10-04-2015, 07:03 AM   #890
Trader Rating: 478 (100%+)
You are playing with fire.....or you will be. Chuck that f'd up battery in the trash!
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 10-04-2015, 10:40 AM   #891
Yeah there is no bringing these back with nicad settings. These are not batteries but instead bags of chemicals that can blow up in your face.
Roken is offline   Reply With Quote
Old 10-04-2015, 06:34 PM   #892
Gpeters66's Avatar
Raced Mine at the track Saturday and my SC5m was really great. My track is hard packed dirt with med to high traction. I used Cav's setup from the Nat's and it worked very well. I hadn't raced since July so I was a little rusty but warmed up to this truck really fast. Great buy for me.
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 10-04-2015, 08:55 PM   #893
HBRob's Avatar
Send a message via Skype™ to HBRob
I'm running 27r 29f at ocrc on clay. Cavs setup is likely due to the ultra high traction at roar
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 10-05-2015, 05:32 PM   #894
1M
1M's Avatar
Trader Rating: 35 (100%+)
Kit build instruction, 4 trailing axle. What would one experience changing to 2?
What is the difference in the rear hub inserts? 0* .5* and 1*
1M is offline   Reply With Quote
Old 10-05-2015, 05:37 PM   #895
1/4milecrazy's Avatar
More steering, kind of twitchy. Harder to drive.
Read the back of you owners manual, it explains it all in there. You have to make ackerman changes with trail changes. I run 2mm on my T5M, and my SC5M, but not on my B5M.
0, 0.5 and 1 degree inserts, again, in your owners manual.
1/4milecrazy is offline   Reply With Quote
Old 10-05-2015, 07:05 PM   #896
Default Which 13.5 motor?
Just picked up a SC5M, and my question is which 13.5 motor to go with. I'm looking at the Reedy M3 line, but am unsure whether to go with the standard 2S Spec or the Short Stack 1S Spec. My local track is twisty, small, indoor, high traction, and clay.
Reedy Sonic 540-M3 Motor 13.5 Spec
vs
Reedy Sonic 540-M3 Motor SS 13.5 1S Spec
Thank you in advance.
mwjcyber is offline   Reply With Quote
Old 10-06-2015, 05:56 PM   #897
Trader Rating: 81 (100%+)
vs
I've not ran the reedy SS but I do know that my trinity SS didn't like the weight. It screams in my buggy but never could get it right in a truck.
dpcardoza is offline   Reply With Quote
Old 10-06-2015, 06:04 PM   #898
Got a question for setup guru's. Basically team the kit setup except 37.5/32.5 shock oil, gray spring in front, 29/27 ride height on a flowing high bite clay, 14-15 sec lap time. I've got a pretty bad on power push, especially coming out of a couple of 180 switch backs. What would be the first change to make? I like to slow before the turn and roll through but the only way I could get it to work was man the brake on the turn with slows momentum. No Bueno when running 17.5 blinky.
Old 10-06-2015, 06:38 PM   #899
a1
battery position?
a1 is offline   Reply With Quote
Old 10-06-2015, 06:46 PM   #900
Originally Posted by a1 View Post
battery position?
I thin foam behind the battery
