    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree24Likes
Old 09-21-2015, 06:45 PM   #841
Originally Posted by celt View Post
Best "out of the box" experience I've had in a good long time...
Not even a question. starting to get a lot of looks and questions from others now. Wish I didn't have to tell them what I'm running! But it's obvious the truck reacts much differently from every other truck on the track.
slow1000rider03 is offline   Reply With Quote
Old 09-21-2015, 06:48 PM   #842
Default Pro line body
Just wanted to add that in the past I have found pro lines bodies very thin and not to my liking but I feel this pro line body included in the kit is absolutely the go to body for this kit. Fits the truck well, flys well and has plenty of room for cutting out vents and I have had zero tire rub at stock body post height and with 3+mm offset wheels. I know this is the last thing some people look at in a kit as do I, but it's nice to not have to buy another body to run after I just spend enough on the initial build.
Old 09-21-2015, 07:24 PM   #843
Suspended
Trader Rating: 440 (99%+)
I got to see one of these run over the weekend. Track is hard packed and dusty. It was the only mm truck there and it was flat out dialed. Really was handling noticeably better than all the other trucks. I may have to pick one up to go with my new b5m.
MattP is offline   Reply With Quote
Old 09-21-2015, 07:57 PM   #844
Trader Rating: 40 (100%+)
Originally Posted by QDRHRSE View Post
Although I modified the heck out of my truck at the point in build, the one thing that I don't have and have never heard of is push with the SC5M. I bet the 10k is way too much. Go to 3 or 5k and stock springs. That's hard to believe. clearly something is not right. There's so much traction at OCRC there's no way you should any push....are you on the right tires?
Went back last week with 5K in the diff, it was waay better. Also grabbed a shorty pack, felt very nimble again.
3 gear went in yesterday, as well as a bunch of Ti screws. 😎
Report to follow soon...
AE!
maddysdaddy is offline   Reply With Quote
Old 09-21-2015, 08:16 PM   #845
71schaeffer's Avatar
Trader Rating: 8 (90%+)
Hey guys, for next upcoming season for dirt oval i was wanted to get ahold of one of these kits. Does it comes with front hexes like the proline pro 2? I have so many new wheels and tires for that car that i dont want to just sell them. Also do you have to run shorty or square packs? Since it's dirt oval i was wanting to look for a battery with long runtimes in the 7000 range such as my bricks. Thanks!
Hobbytown USA Gladstone,MO / StickyKicks RC / Fantom Racing / Clints Creations
71schaeffer is offline   Reply With Quote
Old 09-22-2015, 03:15 AM   #846
I am running a shorty pack but from reading through these posts I see a lot of people are happy with the square pack so you should be able to find something with good run times.
Old 09-22-2015, 11:36 AM   #847
Suspended
Where in VA are you located? Just curious what tracks you run on.
Old 09-22-2015, 01:22 PM   #848
Trader Rating: 81 (100%+)
Doors the kit come with the new updated Springs or are they the older version?
dpcardoza is offline   Reply With Quote
Old 09-22-2015, 01:24 PM   #849
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Springs are the NEW version
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 09-25-2015, 07:21 AM   #850
celt's Avatar
Originally Posted by Wildcat1971 View Post
An update:
Have a few of these wheels now...these are the absolute best I've used to date. Light, strong, true and look as good as any other. Really like the 1mm CA shelf around both sides of the gluing surface. The hex molded into the wheel doesn't bind or fit too tight like the AKA's.
Nice find Wildcat1971, few run these wheels, at least around here...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is online now   Reply With Quote
Old 09-25-2015, 06:22 PM   #851
i am just about finished building mine, but i think i am doing something wrong. Is the front wheel hub and bearings just snap into place?
the build has been super fun and amazingly easy and i cant wait to drive it.
rekim is offline   Reply With Quote
Old 09-25-2015, 07:29 PM   #852
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Bearings on the outside and plastic inserts on the inside with the crush tube in between the bearings. Then you tighten the screw down on the back side of the axle.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 09-26-2015, 04:29 AM   #853
but what holds the whole steering block inserts into in place on the steering block other than pressure?
when i have my front wheel on, i can pull the whole setup off, bearings included with a bit of pressure. i dont think i did it right
Old 09-26-2015, 05:09 AM   #854
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
I'll just leave this here.
http://www.redrc.net/2015/09/exotek-...m-servo-horns/
kwiksi is offline   Reply With Quote
Old 09-26-2015, 06:19 AM   #855
8ight-e's Avatar
Trader Rating: 57 (100%+)
Anyone bothered to find a way to run durango wheels? Honestly I've been considering one of these, but I have way too many 15mm wheels at this point.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
