    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 09-04-2015, 05:20 PM   #781
Gpeters66's Avatar
Originally Posted by Ringer1 View Post
New springs should be available now. My new gray springs for the front and maybe the rear came in today.
Do you have the part #'s for the grey fronts and the white rears?
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 09-04-2015, 05:42 PM   #782
Default Springs
Sure, 91637 gray front and 91641 gray rear. Tryin the fronts for sure first. Rears I'll wait on. Ordered them from the local hobby shop almost two weeks ago. I've looked today on sites and haven't seen them in stock yet, weird. Part numbers are located in page 22 of the manual also, bottom left of page.
Ringer1 is offline   Reply With Quote
Old 09-04-2015, 06:28 PM   #783
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by bds81175 View Post
I always vent the tire, even when I sauce. I don't always sauce. But when I do, I don't apply enough to weep into the vent holes. In fact, I have taken to saucing just the tops of the treads and keeping the sauce away from the carcass. Then again, I may be crazy....
we have no tread, lol
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-04-2015, 10:48 PM   #784
Trader Rating: 478 (100%+)
I ran Kyosho Yellow front SC springs and they worked pretty well. After comparing springs I'm convinced that the new AE springs are made by the same company as the Kyoshos. They are identical....even wound in the same direction.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 09-05-2015, 05:48 AM   #785
Gpeters66's Avatar
Thanks for the info
Old 09-05-2015, 11:56 AM   #786
pastaman's Avatar
Running box stock setup with Proline Prime supersoft slick tires (pretty much what everyone else is running) on a medium/high traction clay/dirt mixture that grooves in as the night goes on. Truck is great everywhere except at the end of the straight there is a high-speed sweeper and my truck wants to roll over every time. Only way to avoid it is to slow way down, and I'm losing time to other trucks that are able to really whip it in there.
Normally, I would probably throw some sway bars on the truck but I don't see that there are any for SC5M yet. Has anyone else had this issue, and do you have any other suggestions? Minimum ride height at this track is 28mm. Thanks
Joe Postula
- AE B5M / SC5M
- Racing at The Track Raceway in Gaithersburg, MD
pastaman is offline   Reply With Quote
Old 09-05-2015, 03:25 PM   #787
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
If your traction rolling then you need to stiffen up your suspension.
kwiksi is offline   Reply With Quote
Old 09-05-2015, 03:45 PM   #788
Gpeters66's Avatar
On Cav's 2 setup sheets I noticed he isn't using the aluminum steering rack....anyone running one?
Old 09-05-2015, 06:19 PM   #789
I run the aluminum rack just because SC is a rough class and there seems to be a lot bumping an grinding...I run one on my T5M too. I'm not Cav. I hit stuff occasionally.
Old 09-05-2015, 08:20 PM   #790
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Got my SC5M Friday by 7pm was on the street in front of the house doing a bit of testing.
As I was to be racing ON ROAD today, planed to do a on road test with the SC5M. Down the front straight for the second lap sounded like the trans went!! :-(
Checked everything from axle pins to opening the trans, found the magnet is loose on the motor armature. Had put a Reedy 3300/AE esc in just for today. Today was to be the last race for the SC10GT-E. Now has a Speed Passion GT2.1 and Speed Passion 10.5 mounted.
? to do a 3 gear trans, what trans cases do you need?
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 09-05-2015, 08:59 PM   #791
ray_munday's Avatar
I found the front felt a bit soft in the high speed sweepers at our track so i adapted a jc sc10 front bar and used a b5m rear bar. I usef the 1.6mm front bar with the pivots 26mm out from the inner pivot point. Green b5m bar on the rear. Truck was very easy to drive hard with these installed.
I havent had a chance to test the stiffer grey front springs yet.
Offical Team Associated SC5M Thread-11892187_10154717548456959_1274334700423520740_n.jpg   Offical Team Associated SC5M Thread-11947531_10154717548446959_4396076532600975715_n.jpg
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 09-05-2015, 09:02 PM   #792
Trader Rating: 91 (100%+)
i agree 100%
redracerd is offline   Reply With Quote
Old 09-06-2015, 06:48 PM   #793
BLKXJ96's Avatar
Ran my Sc5m for the first time this weekend, the grey front springs made a huge difference, along with an oil change to the shocks. Still tends to step out a little in the corners on exit. I almost want to try a blue spring up front. other than that, this truck rips!!
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 09-06-2015, 07:15 PM   #794
2nd race with my sc5 outdoors today. Qualified #2 but took the top spot in the A main. Two races total. Took the win both times. All of this on a outdoor dusty dry track. Anyone thinking they can't run outdoors with this truck needs to think again. A little brass in the rear gives the rear traction I needed.
slow1000rider03 is offline   Reply With Quote
Old 09-06-2015, 07:16 PM   #795
Using the jconcepts one on mine. Very nicely done.
