    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree23Likes
Old 09-02-2015, 03:29 PM   #766
Trader Rating: 36 (100%+)
Originally Posted by maddysdaddy View Post
word of warning--
6mm hexes plus 71013 doesn't work with all wheels. Wheel nut hits shoulder of axle and stops before it's snug against the wheel. 7mm hex (watch with +3 wheels ) or a spacer/shim between the wheel/nut, or open up the back of your front nuts to fit over the shoulder if you keep the 6mm hex.
AE wheel is the biggest gap:
washer between nut and wheel:
Can you put a washer on the inside of the stud,before you put it through the hub?
mxturd is offline   Reply With Quote
Old 09-02-2015, 04:42 PM   #767
Trader Rating: 40 (100%+)
Didn't try, but I kinda doubt it. The hole in the axle might be slightly inside the bearing that way.
AE is already aware of this--they're working on it. New axles for SC being drawn up...
AE!
maddysdaddy is offline   Reply With Quote
Old 09-02-2015, 06:33 PM   #768
weyant's Avatar
Got to finally check the new sc5m out this weekend at our local track. It seemed very smooth to jump and turned well. The guy that had it always fast at our track, him and I trade paint a lot for the wins. I ran my normal setup on my sc10.2. Lap time for him seemed very similar to his normal and the fast lap was mine for that day. He took tq by a small margin over me and we battled back and forth for half the race. I was about a turn ahead of him when his truck broke. So I did take the win. To me the truck is very nice on the track but if your like me and can't get the new truck right away don't get to crazy....my sc10.2 held up to the sc5m just fine. That being said I will be getting one at some point.
weyant is offline   Reply With Quote
Old 09-02-2015, 06:39 PM   #769
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
weyant, I would agree. On low to medium to medium/high I think we can get the 5M to run as fast as the 10.2. I fully anticipate that once I get inside on a prepped high bite track I believe that my lap times will be faster with the 5M. To me it is also more fun to drive. I don't like the feel of the pendulum affect of the rear motor and I enjoy smoothing into the throttle and carrying corner speed as much as possible.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 09-02-2015, 06:43 PM   #770
weyant's Avatar
I agree indoor that truck may be a bit of a handful to keep up with lol. As for my sc10.2 it handles like its on rails....I've been running it for a long time and got it dialed......5m could be good to have indoor. I'll wait to see before I buy it lol
Old 09-04-2015, 05:36 AM   #771
ray_munday's Avatar
Had the chance to run my SC5M on an outdoor track here recently and it was very impressive. Surprisingly, the f/r weight bias using brass C block and battery rear was exactly the same as my SC10.2! It was definitely easier to drive fast than the SC10.2 but did nose down very quickly if you touched the brakes.
I found moving the battery forward on a medium grip surface helped a lot with the jumping and the truck still had plenty of forward grip, as well as being easier to drive with even better corner speed.
I went 5wt up in front oil from the kit setup, and I also experimented by adapting a JC front swaybar and using a B5M rear swaybar which helped in the high speed sweepers. I think the kit front spring is a bit soft for faster tracks, so Id like to install the new Grey front when its available.
Ray
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 09-04-2015, 07:01 AM   #772
Anyone have trouble with the jconcepts +3 wheels going on in the front. I have to jam mine on the stock hex.
atvracer9m is offline   Reply With Quote
Old 09-04-2015, 10:08 AM   #773
My were also tight.
Scottysspeedsho is offline   Reply With Quote
Old 09-04-2015, 10:35 AM   #774
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
use a body reamer and try to open the hole a little. I have to do that with some wheels.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 09-04-2015, 12:58 PM   #775
Do you guys vent your tires indoors? I always have, but I thought I just saw something on another post saying it is not needed
Old 09-04-2015, 01:14 PM   #776
Jmuck69's Avatar
I always vent when using closed cell foams, in or out.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 09-04-2015, 01:15 PM   #777
I vent in the wheels. We sauce, so I dont vent the rubber.
Old 09-04-2015, 03:18 PM   #778
Moderator
bds81175's Avatar
I always vent the tire, even when I sauce. I don't always sauce. But when I do, I don't apply enough to weep into the vent holes. In fact, I have taken to saucing just the tops of the treads and keeping the sauce away from the carcass. Then again, I may be crazy....
Tekno RC
Old 09-04-2015, 04:04 PM   #779
New springs should be available now. My new gray springs for the front and maybe the rear came in today.
Ringer1 is offline   Reply With Quote
Old 09-04-2015, 04:27 PM   #780
Moderator
bds81175's Avatar
I'm running the old orange springs in the front with the 12mm spring cups. Work great.
Tekno RC
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
MaX-D
