    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 08-09-2015, 12:11 PM   #481
NeedsHobbyMoney's Avatar
Is the avid slipper going to fit on this, because I tried last night with no luck. I didn't take that much time messing with it, because I only had an hour left to build it before the race on Friday. Just seemed like it would go on the top shaft even with it's cut sides.
Team Associated
T5M | B44.2 Schelle Shorty | SC5M | RC8B3e | RC8B3
TEKIN | Airtronics | Savox | Avid | MIP
NeedsHobbyMoney is offline   Reply With Quote
Old 08-09-2015, 12:26 PM   #482
GeorgePravata's Avatar
Trader Rating: 107 (100%+)
Yes it fits I put my on last night
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 08-09-2015, 01:14 PM   #483
Loving this truck. 1st time out with it today and I qualified 3rd . Finished 2nd in the A-main also led a few laps. Outdoor clay/dirt mix light dust . The only thing I've change from the box setup is I'm running the aluminum bulkhead, brass C and D blocks with the 3.5/ 1 inserts. Proline holeshots. I also dropped almost 2 seconds off my previous fast times. I used to run a scx-60cf .
Newbie Rc Guy is offline   Reply With Quote
Old 08-09-2015, 04:57 PM   #484
Trader Rating: 42 (100%+)
So was Cav & Revkin running the SC5M or 10.2 at the Nationals?
Bartman42 is offline   Reply With Quote
Old 08-09-2015, 05:12 PM   #485
aeRayls's Avatar
SC5M
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 08-09-2015, 05:17 PM   #486
Originally Posted by aeRayls View Post
SC5M
Looked good... Cav is kicking a$$
Old 08-09-2015, 06:40 PM   #487
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
anyone using a sway bar?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 08-09-2015, 07:04 PM   #488
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
it fits. the qc on some of the AE topshafts, requires a little finesse to get the drive plated on.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-09-2015, 07:35 PM   #489
Holeshot114's Avatar
Anyone having a problem with front end diving off big jumps?
Holeshot114 is offline   Reply With Quote
Old 08-10-2015, 04:08 AM   #490
I had the same issue when I 1st got my T5m. I just adjusted my throttle control off jumps. My Sc5m even reacts differently that my x factory .
Old 08-10-2015, 05:54 AM   #491
mes
You may want to try the 3-gear transmission or a heavier battery. My T5M jumps much smoother with the 3-gear, now all I have to do is adjust my driving a little. If you are running on low-grip, try to stiffen up your front suspension a bit.
mes is offline   Reply With Quote
Old 08-10-2015, 07:36 AM   #492
Originally Posted by ScottKelly911 View Post
Man, you need to turn that timing on the can up! 17.5 with no timing is like Molasses. You'll be surprised how much it wakes it up with a lot of timing! I don't use a Tekin motor, but to find the sweet spot on that motor, go to the Tekin thread and I'm sure Randy Pike or others that run the Tekin motor will be happy to help you find it!
You was right. Took me about an hour of reading it, but found a post by Randy. Tekin Redline Gen2 2wd buggy 30 on the timing and 2wd sct 20-25. I'll give that a try tonight as a starting point.
DrewF is offline   Reply With Quote
Old 08-10-2015, 10:46 AM   #493
motopat's Avatar
what kind of issues would I have running SCTE wheels on this truck. I have a set of new Typos which are the tires to run at my track. they are just broken in and I am not running my SCTE anymore.
motopat is offline   Reply With Quote
Old 08-10-2015, 10:52 AM   #494
Different Offset. And tlr parts make your car slower
Old 08-10-2015, 01:04 PM   #495
motopat's Avatar
LOL, I get that but in a pinch could I use these without any negative side effects until I can new one. I kinda blew my budget buying the kit and the electronics.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
