    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 08-04-2015, 02:59 AM   #361
I am sure it has been covered on here but can someone post a Jconcepts part number of the correct wheel for this truck? I unexpectedly have one of these trucks coming my way today or tomorrow. Also do people plan on running the stock body or switching to a flow type body? My track is low grip so I will start with the stock body.
Schumacher K1 Aero, Custom Works SE4
cwalsh is offline   Reply With Quote
Old 08-04-2015, 04:44 AM   #362
celt's Avatar
Default I don't have a kit yet but...
I would guess it's under weight out of the box?
2098grams
Curious to see some stock, out of the box weights
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 08-04-2015, 05:17 AM   #363
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Kit Proline body works well with all the cutouts. They also make a nice F-11 wheel that's avail in reg or +3 offset to match...America .
http://prolineracing.com/short-cours...t-truck-wheels
kwiksi is offline   Reply With Quote
Old 08-04-2015, 08:18 AM   #364
NeedsHobbyMoney's Avatar
Anyone Plan on using the EVO SC body?
Team Associated
T5M | B44.2 Schelle Shorty | SC5M | RC8B3e | RC8B3
TEKIN | Airtronics | Savox | Avid | MIP
NeedsHobbyMoney is offline   Reply With Quote
Old 08-04-2015, 08:22 AM   #365
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Socket View Post
your track is enforcing that rule...
Are they, "fing stupid" then?
ROAR is enforcing that rule. SRS has nothing to do with it. It is a ROAR rule and it is AE's fault that the truck is not legal for the 17.5 class. It's not like this just appeared somewhere....its been in the book for years.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-04-2015, 08:55 AM   #366
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
This seems like the slowest it has ever taken AE to put up a manual online. I was just curious and wanted to preview the build and check a few things out...but no online manual
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-04-2015, 09:47 AM   #367
Do any of you guys that got the kits have the part numbers for the new springs?
Newbie Rc Guy is offline   Reply With Quote
Old 08-04-2015, 09:52 AM   #368
mes
+3mm Hazards are #3344W/B/Y, 0mm offset are #3352W/B/Y. If you want to bring the truck to maximum ROAR width, take the +3mm wheels, if you prefer a narrower car, take the 0mm offset wheels. If you are running on really low grip, you may want to try wide wheels in the front and narrow ones in the rear.
mes is offline   Reply With Quote
Old 08-04-2015, 11:06 AM   #369
Ok, SC Gurus. The truck will be here tomorrow. I plan to paint the body this week. Nothing fancy, but I would still like the paint to last longer than 2-3 weekends. The last time I had an SC, the wheels rubbed the wheel wells on compression. And quickly rubbed away the paint. I am looking to try and keep the paint looking decent as long as possible. A buddy of mine uses plastic dip spray on the inside and that does seem to keep the bodies from cracking as much. But is also heavier. And I am not sure I want the tires compressing and binding up on a rubber under coat. The simplest thing, is to put stickers over the rub spots, so you cant see them , lol.
Also, any tricks to make the body last longer without using 10lbs of drywall tape and shoe goo? I was thinking about not cutting out vents as a way to make the body more durable. And cut away the rear sections above the bumper to lower the chance of the bumper cracking the body.
Old 08-04-2015, 11:11 AM   #370
Super Moderator
I always took a dremel to the cutouts to make sure to remove any sharp edges. Rounded corners are less likely to split. Also once its mounted try and flex the bumpers/body and see if anything rubs/hits and remove material from the body until it doesn't.
Old 08-04-2015, 11:13 AM   #371
Dstreelm's Avatar
Back when i had my first SC (Losi 22 SCT) i tried the whole drywall tape and shoegoo thing but the thing just felt so heavy and slow.
I have had good luck repairing/reinforcing bodies with simple black gorilla tape, Gorilla glue's version of duct tape. I use it on the underside of my T5m body under the mounting holes. The adhesive is super strong and the top surface is slippery...I plan on using that on the wheel arches
Dstreelm is offline   Reply With Quote
Old 08-04-2015, 11:13 AM   #372
Yeah, I use a dremel on my wings the same way. In the past for SC, I used a body reamer on the corners of the cutouts and then played connect the dots with the sissors.
Old 08-04-2015, 11:15 AM   #373
ok, I tried duct tape in the past, but not gorilla tape.
This the stuff?
http://www.walmart.com/ip/Gorilla-Ta...0-yds/23760411
Old 08-04-2015, 11:48 AM   #374
Dstreelm's Avatar
This the stuff?
Yup thats it, Ive used that stuff and the narrower tape which is easier to fit around certain curves
Old 08-04-2015, 12:10 PM   #375
celt's Avatar
It's just the nature of running ShortCourse...they eat bodies, I've not seen a reasonable way around it.
Stan Garvin
