Team Associated SC5M Thread
#2596
I've looked back a ways.... but I can't seem to find it. Putting a laydown diff in and asking what "C" block is used? I tried a couple I had and diff hits it. Or do I need to put shims under diff.? Thanks guys!!!!!
#2597
shimming is now the commonly accepted/easiest solution to my knowledge.. there used to be other tricks that would not raise CG, but the parts are no longer available..
#2598
laydown diff kits require the B6 C and D blocks don't they? ..
T5M and SC5M 4mm Carbon Fiber Rear Shock Tower B6 LD Transmission Conversion | Vision Racing
see the instructions link
#2599
No..
I have a pair of SC5m's using B6 laydowns that are using the sc5m C & D blocks as well as the stock shock tower. Buying that overpriced tower and other parts is totally unnecessary.
It's not the best picture but the only one I have handy. We simply made a brace to go from the tranny to the tower and trimmed the tab off that would mount to the B6 camber link brace.
It cost us the total of the b6 laydown kit with idler + motor plate which I paid about $30 for and a little material to fab an upper brace.
#2600
Worked on it a little last night. Trimmed the C Block. Yea if you run the CF tower. Moves mounting holes for body. Just building this one to compare the two. My other one is a X factory chassis with 3 gear. If I like it I'll mod. that chassis also.
#2601
The schell extended topshaft kit (discontinued) let you clear the C block and centered the motor up better.. it's a shame they stopped making it...
#2603
Get the cheaper SC10 one like I did, available on eBay at least for cheap: Associated 9827 SC10 Complete Gear Diff (New in Package) | eBay
#2605
Yeah, I didn't realize it either until I read about it here, I posted my experience about it the first test mount in the previous page - had some slight hitch in the fit, but more likely than not a brand new one (which as said I already ordered) will fix that issue, if not otherwise then with a light filing.
#2606
Any idea on when the new sc6dm is coming out? Or maybe a sc5.1m .Got the itch to get a new vehicle .
#2607
#2609
#2610
the extended topshaft is still available while supplies last: B5M Motor Centering V2 Topshaft Set
I'd heard they were getting discontinued..
PS: Reading your sig you'd be in a position to know better lol..
