    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 01-24-2017, 05:21 AM   #2176
jonski's Avatar
Trader Rating: 233 (99%+)
Originally Posted by tylem28 View Post
What would you say was the most notable difference after adding the front swaybar?
Reduced most of the body roll coming off of a fast straight heading into a sweeper. I am able to carry more speed without lifting the inside wheels off the ground.
jonski is offline   Reply With Quote
Old 01-24-2017, 05:23 AM   #2177
jonski's Avatar
Originally Posted by Braxamus View Post
Yes it is for racing only. And I'll be racing shorty batteries instead of square packs because I already have them.
I only run shorties...I race against a guy who runs square packs for the weight. I tried both and like the way mine felt with the shorties. I could see on a loose track where a square pack would help, but I run indoor med/high bite track. Also run 17.5, so don't want the weight.
Old 01-24-2017, 05:48 AM   #2178
Azzkikin's Avatar
I run my shorties inline and it has also limited body roll by keeping it centered.
I agree, a front sway bar is a great upgrade and makes a huge difference.
When diving into any turn and decelerating, it keeps that back end from lifting the inside wheel. Prevents body roll keeping the weight more evenly spread across all tires so as not to break traction.
I run front and rear sway bars and a very soft spring. Soaks up the rumbles and keeps the truck level.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 01-24-2017, 06:31 AM   #2179
Braxamus's Avatar
I will be racing Mod with a 8.5 what is a good battery location for the shorty ?
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 01-24-2017, 06:47 AM   #2180
Azzkikin's Avatar
Try forward to start.
Old 01-24-2017, 01:32 PM   #2181
czrlaker's Avatar
Trader Rating: 23 (100%+)
What's the best DIY front rollbar install in your guys experience? Link?
czrlaker is online now   Reply With Quote
Old 01-24-2017, 07:13 PM   #2182
jonski's Avatar
I use this one http://www3.towerhobbies.com/cgi-bin...FR24wAodELIJJw
Had to drill new mounting holes. The bar that came with was pretty thick, so I picked up a couple different thickness of piano wire and bend new bars. I mounted the linkage to the bottom shock screw.
Old 01-24-2017, 09:16 PM   #2183
czrlaker's Avatar
Thanks for the reply. I will try that for sure. I run on carpet, and had problems with a 60 degree turn @ the end of a straight away. I just finished installing a shapeways laydown in it. I bet with the front sway bar it will make an even bigger difference.
charvel74 likes this.
Old 01-25-2017, 06:44 AM   #2184
Azzkikin's Avatar
I used the SC10 4x4 front sway bar kit. And run the second heaviest wire that comes with the kit. I have since switched to the WallieBuilds kit.
Old 01-25-2017, 01:21 PM   #2185
Braxamus's Avatar
Is there a direct install with no mods for the sway bar? If so whats the part # please
Team Raw Speed
Old 01-26-2017, 07:06 AM   #2186
Azzkikin's Avatar
Your direct install no mods would have been the Walliebuilds SC5M Front Anti- Roll Bar Kit Version 1. It came with arms and top plate already drilled out for the sway bar. But they no longer make it. You may find some running around for sale still.
The Walliebuilds SC5M Front Anti- Roll Bar Kit Version 2, is cheaper but you don't get the arms or top plate. So you have to do some mods.
Old 01-26-2017, 12:00 PM   #2187
czrlaker's Avatar
Nice, I wonder why AE never made this an option?
Old 01-26-2017, 10:29 PM   #2188
cliffhanger's Avatar
Losi 22SCT 3.0 is released i wonder if SC6D is next?
Losi 22T 3.0 is being released by end of February so AE might follow suit.
With first releasing the SC6D and then T6?
All i can think off get the new SC out ASAP need one!!!
DESC210R ● DEX210 ● DEST210R
Team DE Racing
cliffhanger is offline   Reply With Quote
Old 01-29-2017, 04:07 PM   #2189
jonski's Avatar
Looking to gain some more punch out of my truck. Anyone feel the stock slipper is soft compared to a Schelle or Avid? Running 17.5 medium grip indoor clay.
Old 01-29-2017, 07:19 PM   #2190
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Quick question for you guys.
What shock cap bushing do you use with the FT Aluminum shock caps?
Not a trick question, trying to mount BB on my son's SC10.
Thanks!
Rich Panganiban is offline   Reply With Quote
