    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 01-14-2017, 04:23 PM   #2161
Big_Show's Avatar
Ran my 1st race with the SC5M last night. Qualified 3 finished 3rd. Had a bad push but also at the touch of throttle the rear end would kick out. Made adjustments and got the rear end not to kick out so bad, still had the push. Today I was looking it over and the diff was way to tight. When I would turn one tire the other tire and motor would turn same direction. I think that was probably biggest part of the problem. What do you guys think?
RC10B6D/RC10T5M/RC10SC5M
Big_Show is offline   Reply With Quote
Old 01-14-2017, 04:26 PM   #2162
czrlaker's Avatar
Trader Rating: 23 (100%+)
Can't be right if turning the same direction. Just wondering what you are running on?
czrlaker is offline   Reply With Quote
Old 01-15-2017, 11:46 AM   #2163
Big_Show's Avatar
Very slick hard packed dirt. I loosened the diff up just around a 1/16th of a turn and it freed the diff up.
Old 01-15-2017, 11:56 AM   #2164
Any word on the SC6D? I believe it will be called that just guessing.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 01-16-2017, 06:06 PM   #2165
Default Adjustments
I got to run my sc5m for the first time this weekend. I have a couple of questions. What's the internal transmission gear ratio? Is it 2.62? Also i got my suspension feeling pretty good, but i could use a little more turn inwhat could i adjust to get me a little more?
phinsfan76 is offline   Reply With Quote
Old 01-16-2017, 08:11 PM   #2166
bubbaslash's Avatar
2.60
Sleeper Slash 2wd HCG VXL
Chuckworks Slice Super B
Chuckworks Slice A6 gone oval
TLR/Exotek chassis 22SCT 2.0 MM
X Factory SCX-61 prototype
bubbaslash is offline   Reply With Quote
Old 01-16-2017, 08:16 PM   #2167
bubbaslash's Avatar
I don't run an SC5M, but if you need a slight increase in turn-in, you may want to try lowering the front roll center a little bit. Looks like you could add an extra washer under the tower ball studs (for the camber links) to accomplish this.
Old 01-18-2017, 03:27 AM   #2168
Braxamus's Avatar
thinking of getting one of these and switching from my T5M should I go ahead and buy one or wait for the new one if there is one on the way.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 01-18-2017, 05:14 AM   #2169
There are quite a few T5M spare parts that will fit the SC5M....if you have a lot of spares already might be worth getting it now.
asr524 is offline   Reply With Quote
Old 01-18-2017, 09:42 AM   #2170
Braxamus's Avatar
Right I know there is a lot of similar parts, but I hate to waste the money now for the SC if in a few months there is going to be a 6 series.
Team Raw Speed
Old 01-19-2017, 02:10 AM   #2171
thinking of switching from TLR to AE SC5M. does anyone know how big of a difference the B6 was from the B5 ? only asking because the same changes will more then likely be made to the new SCT.
TLR 22T 2.0
Dirtraycer is offline   Reply With Quote
Old 01-23-2017, 12:53 PM   #2172
Braxamus's Avatar
When I switch and get one of these are there any needed upgrades that are necessary I don't care about bling just needed parts to improve durability, performance.
Team Raw Speed
Old 01-23-2017, 12:56 PM   #2173
jonski's Avatar
Trader Rating: 233 (99%+)
If you are going to be racing it, I strongly suggest a front swaybar. Either make your own like I did or buy the Wallie Builds one.
charvel74 likes this.
jonski is offline   Reply With Quote
Old 01-23-2017, 08:17 PM   #2174
What would you say was the most notable difference after adding the front swaybar?
tylem28 is offline   Reply With Quote
Old 01-24-2017, 02:44 AM   #2175
Braxamus's Avatar
Yes it is for racing only. And I'll be racing shorty batteries instead of square packs because I already have them.
Team Raw Speed
