    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 12-15-2016, 05:25 PM   #2086
mxnickj's Avatar
Trader Rating: 51 (100%+)
Originally Posted by QDRHRSE View Post
2 things. If you're barking the diff its already shot [usually]. Are you sure its not the slipper? Sometimes the slipper doesn't hold up with a lot of motor and if you are are actually running an 8.0 (delta wind) and not an 8.5T you're motor is immensely torquey.
What is the actual difference between the .0 and the .5 motors? I see reedy has a few of the .0 motors as well as the .5 motors
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 12-15-2016, 05:44 PM   #2087
Im pretty sure its the diff but I could be wrong. I can try tightening up the slipper. Yes its a 8.0T Fantom. Its only a month or so old and raced 6-7 times.
Any downsides to switching to a gear diff? What parts would be needed?
tylem28 is offline   Reply With Quote
Old 12-15-2016, 06:34 PM   #2088
Trader Rating: 478 (100%+)
My truck was crap with a gear diff.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 12-15-2016, 06:49 PM   #2089
The way they physically wind the stator is different. They seem to be a little slower but have smooth power and gobs or torque.
Old 12-16-2016, 07:56 AM   #2090
Originally Posted by 1967Typhoon View Post
My first mod will be to run a full stick pack right down the middle. It looks like it will fit just fine. Maybe esc on the waterfall.
Gotta say this truck looks killer.
Heyb1967Thypoon, how did it work the Inline setup with a full 2s stick pack across the chassis? I kind of want to do the same with my truck but I want to ask first
TotopoRC is offline   Reply With Quote
Old 12-16-2016, 07:36 PM   #2091
I tightened up the diff a little more and it seems like the noise is gone. Maybe it was still just a little loose.
Old 12-18-2016, 03:37 PM   #2092
I have one shock that seems to be leaking shock fluid from the top. I noticed the O-ring sticks out a little once tighten down. Should I replace just the O-ring or replace the shock cap and O-ring both?
Also is anyone running the MIP "Super Diff"? Specs below. Just curious if anyone saw any noticeable difference?
This is the MIP Bi-Metal "Super Diff" Differential Kit for the Team Associated B5 and B6 series vehicles. Ball differentials are essential to any racer’s program, and as of late MIP has shied away from the conventional steel pin drive differential design; but no longer ladies and gentleman, because MIP has a ball differential that is anything but conventional.
Featuring their two piece bi-metal outdrive design that’s comprised of both 7075–T6 aluminum and high grade heat tempered, the MIP Super Diff will automatically shed 30% off of your OEM rotating mass; this equates to quicker acceleration, perfect for any motor/car combination!
MIP is also including both Tungsten Carbide diff balls and MIP’s rebuildable machined aluminum T-Nut (MIP15010)! Though small, both of these upgrades will give you a longer lasting smooth differential, a wider range of adjustability, and of course making sure it stays in its set position longer. Overall you will ditch 30% of your rotating mass while keep the same driving characteristics you are used to. Say “NO” to a heavy inefficient differential, and say “YES” to MIP’s Bi-Metal differential for your stock, super-stock, or modified vehicle. Always Made 100% in the USA!
Features:
Tungsten Carbide Diff Balls
Machined Aluminum T-Nut
Two Piece Bi-Metal Diff components
Direct Stock Diff replacement
Hard Polished Drive Rings
Bearing Steel “Grooved” Thrust Washer
7075-T6 Hard Anodized Alum Drive Hubs
100% Quality made in the USA!
Includes:
(2) MIP Confetti Sticker
(14) 3/32” Tungsten Carbide Diff Ball
(2) MIP Modified Diff Ring
(7) 1/16” Bearing Chrome Steel Ball
(1) #2 Washer Hardened
(1) Diff Lube & Grease Cup
(1) x 9/32” Diff Spring
(1) 2-56 x .925 Diff Screw Shoulder
(1) 0.236 MIP Thrust Retainer
(2) 5mm x 8mm x 2.5mm Bearing
(1) 0.250 MIP T-Nut Housing
(1) 0.250 MIP T-Nut Insert
(1) MIP Bi-Metal Outdrive Cup Male
(1) MIP Bi-Metal Outdrive Cup Female
(2) MIP Bi-Metal Outdrive Hub
Requires:
(1) Stock Diff Gear to complete (ASC91419)
(1) 2.0mm Allen Key (recommended MIP9008 MIP Hex Driver Wrench 2.0mm)
Support Products:
MIP15010: MIP Machined T-Nut, .250 Bore
MIP16015: MIP Super Diff, Bi-Metal Outdrives, “Pin Drive”, M&F, All AE 6/5 Series Vehicles
MIP16061: MIP Super Diff, Bi-Metal Hub, All AE 6/5 Series Vehicles
MIP16065: MIP Super Diff, Bi-Metal Rebuild Kit w/Carbide Diff Balls
MIP99061: HW-Bearing, 5x8x2.5mm (2)
MIP99099: HW-Diff T-Nut Insert (2)
MIP99107: HW-Bearing, 3/32” Tungsten Carbide Ball (14)
MIP99108: HW-Bearing, 3/32” Ch. Steel Ball (14)
Old 12-18-2016, 09:16 PM   #2093
Schelle sells a version of that but uses their ceramic caged thrust and carbide balls. I's say that its marginally better.
Old 12-19-2016, 09:11 AM   #2094
Truck is easiest to drive with a shorty all the way back or @ 5mm forward. keeping weight low is always good - personally, i wouldn't run the esc on the waterfall.
hsp-sandiego is offline   Reply With Quote
Old 12-19-2016, 03:03 PM   #2095
Trader Rating: 74 (100%+)
Default What's going on with the front bumper?
I decided to convert my T5M to an SC5M for my son to race on carpet. The front bumper is back ordered everywhere from what I can tell. I'm usually pretty good at hunting down hard to find parts, but the SC5M front bumper is MIA. Why is this part in particular hard to find? Are people breaking them a lot?
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 12-19-2016, 03:09 PM   #2096
mxnickj's Avatar
can someone with the AE rear swaybar tell me what the measurement of the links should be to start with?
Old 12-19-2016, 03:25 PM   #2097
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
They do break pretty easily. I've broken mine but just used my thinker-thingy and fixed it.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 12-19-2016, 03:42 PM   #2098
At this point I would take a broken front bumper so that I had a chance to use my thinker thingy, but since I'm converting from a T5M I need a new bumper
XRAY 17 XB4
Yokomo YZ-2 CA
Old 12-20-2016, 05:26 AM   #2099
mxnickj's Avatar
My front bumper never "broke" but the first run out with the truck it nose-dived off a jump and it pulled the head of the screws though the mounting holes. All I had to do was put a washer on the screws and its been good ever since. Maybe I've just been lucky
Nick Johnson
AE SC5M - AE B6D
Old 12-20-2016, 05:41 AM   #2100
Moderator
bds81175's Avatar
That's exactly what mine did. I've seen many others with the same damage. Wease doesn't have one to break at this point though. Anyone have an extra for him?
Tekno RC
