    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 12-02-2016, 11:08 AM   #2041
What body does everyone prefer? Does any body help better with parachuting? What are you using / doing to help reinforce the body? What areas are prone to cracking and need to address?
tylem28 is offline   Reply With Quote
Old 12-02-2016, 12:12 PM   #2042
Default Jconcepts HF 2 body
JC High Flow 2 is the best SCT body i have driven. Shoe Goo'ing Drywall Mesh in the key areas - wheel wheels and Mounting points. hope that helps.
hsp-sandiego is offline   Reply With Quote
Old 12-03-2016, 06:42 AM   #2043
mxnickj's Avatar
Trader Rating: 51 (100%+)
Originally Posted by sduffy77 View Post
Yeah I have some 3x1.4 I was thinking about trying. I'm currently running Cav's 2016 ROAR-Nats setup.
Some things I might change:
  • 3-1 toe/anti-squat
  • 1.4x3 pistons in rear
  • Kyosho X-gear White spring in rear
  • -1 camber front/rear
i went to the 3-1 toe setting and that seemed to be a step in the right direction
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 12-05-2016, 12:47 PM   #2044
jonski's Avatar
Trader Rating: 233 (99%+)
Anyone use Pro-Line 6269-00 sway bar kit to make a sway bar for the SC5M? If so, please post pics. Thanks
jonski is offline   Reply With Quote
Old 12-08-2016, 05:25 AM   #2045
Which turnbuckles are best to go with over stock? Lunsford or Factory Team? What length are turnbuckles?
Old 12-08-2016, 07:05 AM   #2046
Azzkikin's Avatar
I made mine from the SC10 4x4 kit. I was looking into the Pro-Line one, but choose to go with something I could modify a little more to sneak in between the small gap of the buggy shock tower and shocks.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 12-08-2016, 08:42 AM   #2047
I have the gold SMC link here
have bent two. I would go lunsford since they are so long.
Old 12-08-2016, 07:11 PM   #2048
jonski's Avatar
Do tell me more!
Old 12-08-2016, 07:12 PM   #2049
jonski's Avatar
Got my front sway bar mounted up. Need to make a thinner bar still.
Old 12-09-2016, 06:29 AM   #2050
Azzkikin's Avatar
I'll get some pics of mine tonight.
Does yours rub the tie rods when turn lock to lock?
Old 12-09-2016, 09:30 AM   #2051
Default Body roll
Any setup tips to help prevent body roll? Current setup is Cavs nationals setup. Middle hole postions on front/rear shock towers. Using gray springs, 1.5 shock up front and 1.6 in back. Using 3 limiters on rear and 1 on the front.
Old 12-09-2016, 01:44 PM   #2052
Also just installed the Schelle aluminum rear hub set on my Sc5m. On my B5m the stock ball stud 6mm work perfect but the ball stub on the SC5M are 10mm. I will replace with 6mm but wanted to confirm before doing so. The instructions are just for the B5M.
Old 12-09-2016, 02:55 PM   #2053
Azzkikin's Avatar
Do tell me more!
Here's the 4x4 sway bar[/URL][/URL][/URL]
Now i just switched to the std tower and shocks, but the same install applies for both buggy tower and std tower.
Old 12-09-2016, 03:27 PM   #2054
jonski's Avatar
Just barely hits the linkage at full lock. Yours looks good.
Old 12-09-2016, 03:35 PM   #2055
Here's mine. Used some left over traxxas links with a custom bar and mounts. Huge difference in handling
Slammed80 is offline   Reply With Quote
