    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 10-25-2016, 08:48 AM   #1921
Eli
Eli's Avatar
With the TLR wheels you're not going to get the proper feel of the truck so keep that in mind.
Eli Westrup - SDRC Raceway - B6D - SC5M - B64D ALL FOR SALE!
Eli is offline   Reply With Quote
Old 10-25-2016, 11:12 AM   #1922
Originally Posted by Eli View Post
Which body is everyone preferring to run on indoor clay? Recently got a sc5m and looking forward to wheeling it. Last SC I had was an sc10 with the jc illuzion hi flow body on it but I am seeing there is a new Proline flo-tek fusion precut body out that looks to be the newest design out there and leaning towards it.
Anyone with experience with the two bodies?
Just the JC Hi-Flow. Never feel like I am fighting parachuting and has been very durable - with some mesh/shoe goo reinforcing @ mounting locations and wheel wells only.
hsp-sandiego is offline   Reply With Quote
Old 10-25-2016, 11:23 AM   #1923
aeRayls's Avatar
The Jconcepts HF2!
aeRayls is offline   Reply With Quote
Old 10-25-2016, 11:45 AM   #1924
mxnickj's Avatar
Trader Rating: 51 (100%+)
Does the kit come with wheels at all?
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 10-25-2016, 11:46 AM   #1925
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
no
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-25-2016, 12:32 PM   #1926
Eli
Eli's Avatar
Originally Posted by aeRayls View Post
The Jconcepts HF2!
Thanks guys, I didn't even see there was a new one. Looks like that will be the one I get.
Old 10-25-2016, 12:56 PM   #1927
JsK
JsK's Avatar
The precut losi 22 2.0 body is my favorite.
https://www.amainhobbies.com/team-lo...230006/p363228
JsK is offline   Reply With Quote
Old 10-26-2016, 11:09 AM   #1928
sduffy77's Avatar
Trader Rating: 17 (100%+)
Thanks Duffy I think I will try the TLR wheels first and just see how it feels. I sold my nitro buggy so I have some cash to play with and want to try the SC5M and see if its really better than my 22SCT.
Let me know when you'll be up to practice and you can try mine so you can see the difference.
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 10-26-2016, 12:51 PM   #1929
mxnickj's Avatar
I am hoping to order it Friday, then get it built as soon as it gets here so hopefully by next weekend for the first points race. I'm just going to order a set of wheels and tires for it I guess, that way I know what I'm really dealing with.
Nick Johnson
AE SC5M - AE B6D
Old 10-31-2016, 04:45 AM   #1930
AlexeyLLIMEJIb's Avatar
I use Pro-Line Flo-Tek on both of my SC (Blitz and SC5M) and its perfect!
Also I try JConcepts HF2 Lightweight - with my skill and style driving - after first race these body have a lot of cracks on rear of cabin.
I want to try JConcepts HF2 or HF1.
Pro-Line Flo-Tek Fusion too expensive, IMHO.
Hey guys, looking at picking up a SC5M soon since my 22SCT 2.0 is getting pretty worn and tired and there in no info of anything new coming out soon so I'm going to make the switch. I'm new to AE cars and did my research a little bit and seems like the two main things to get with the truck are the 3 gear trans and aluminum hexes. Anything else I should get with the truck right away?
Also, will my TLR wheels work on this truck?
That's I using while assembling SC5M:
AS71009 - Front Arms Hard
AS1105 - Green Slime
AS91461 - Gear Diff Kit
-> AS91462 - Gear Diff Gear/Cover
- >AS91463 - Gear Diff Rebuild
-> AS91465 - Gear Diff Outdrive
-> AS4675 - Screws, 2.5x0.45x6 in FHCS
AS4670 - Screws, M3x0.5x8
AS91493 - FT Low Friction X-Ring
AS71014 - Clamping Wheel Hex 8.5mm
AS91637 - 12mm Front Shock Springs, 54mm, gray, 4.45 lb/in
AS91607 - 3 Gear Gearbox
AS91602 - 3 Gear Motor Plate, Black
-> AS91603 - 3 Gear Motor Plate, Blue
AS91604 - 3 Gear Cover
That's I bought in few months:
AS91365 - Brass Bulkhead, 25 deg, +45g
AS91525 - Brass Arm Mount (D), +15g
AS91389 - Arm Mount Inserts (D)
AS91523 - Brass Arm Mount (C), +20g
AS91385 - Arm Mount Inserts
With TLR wheels (0mm offset) would be wider then SC5M (+3mm offset). And you can don't meet regulations of your races.
AlexeyLLIMEJIb is offline   Reply With Quote
Old 10-31-2016, 06:52 AM   #1931
mxnickj's Avatar
I ordered the kit with all the 3 gear parts, the brass c-block, clamping hexes, and the x-rings for the shocks. Should be a good start I think. Hoping to get it all built and ready for this coming weekend.
Side note, are the Kashima shocks a real improvement or just for bling more than anything? I know in the motocross and mountain bike world kashima coating suspension components makes a noticeable change but wasn't sure just how much it would help on the RC side of things.
Nick Johnson
AE SC5M - AE B6D
Old 10-31-2016, 01:33 PM   #1932
carbons2k's Avatar
Trader Rating: 21 (92%+)
Any talks of anSC6m coming out? I really want a short course but if its coming soon, Ill hold out on getting the 5
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 10-31-2016, 01:46 PM   #1933
Eli
Eli's Avatar
I wouldn't hold your breathe, pretty sure they are trying to get a new 4 wheel buggy out first, SC is probably not in the works anytime soon but I could be wrong.
Old 10-31-2016, 11:53 PM   #1934
Does anyone know if the B6 Laydown transmission fits in the Sc5 with only a little modifications? I have not tested myself but I heard the C and D mounts fit right in, and if thats true you would only have to drill a couple holes then figure something out for the rear tower to use the bumpers.. Anyways let me know if you guys have seen or done anything like this!
Mxer210 is offline   Reply With Quote
Old 11-01-2016, 12:33 AM   #1935
JsK
JsK's Avatar
2 guys at our track run the YZ2 3 gear laydown in theres. The B6 box i have not seen yet.
