    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree24Likes
Old 09-19-2016, 11:32 AM   #1876
I've been going off from this setup for my current build. Will be racing an indoor pretty decent bite track. Do you guys think it will be an ok baseline or should I go with something else? https://www.teamassociated.com/pdf/c...i_Shootout.pdf
cecce12 is offline   Reply With Quote
Old 09-19-2016, 12:32 PM   #1877
Something else - Hotrod is a medium size Outdoor SoCal Track.
I am running for the most part this setup, although lower ride height - 27/25mm (will be trying lower.) Camber more like 1.5* all corners and a 8.5/21T pinion, Schelle Nova Slipper. Shorty all the way back, no added weight. Truck is alot of fun.
hsp-sandiego is offline   Reply With Quote
Old 09-20-2016, 04:56 PM   #1878
Another question, I want to switch my truck over from the 4 gear to the 3 gear trans. Will all my internals work or will I need a different top shaft? I know I'll need to buy the case, new motorplate and is there anything else?
Old 09-20-2016, 05:46 PM   #1879
aeRayls's Avatar
Case, plate, gear cover
aeRayls is offline   Reply With Quote
Old 09-23-2016, 08:12 AM   #1880
Anyone have an experience with a cut chassis cradle?
Where to cut it and what it does?
Pictures?
atvracer9m is offline   Reply With Quote
Old 09-23-2016, 08:59 AM   #1881
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Pictures?
Info is just a few clicks away...
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-23-2016, 09:34 AM   #1882
Thank You I just wanted to see if people didn't cut by the water fall
Old 09-23-2016, 09:46 AM   #1883
Super Moderator
I have always cut it all.
Old 09-29-2016, 03:30 PM   #1884
cliffhanger's Avatar
Does anyone know if there is a 15mm hex conversion so i can use durango rims?
Also can this kit run as rear motor if i ever wanted to do so?
DESC210R ● DEX210 ● DEST210R
Team DE Racing
cliffhanger is offline   Reply With Quote
Old 09-29-2016, 03:35 PM   #1885
Super Moderator
Ive never seen or heard of anything....that's the problem when companies like Durango want to do oddball stuff.
Old 09-29-2016, 07:18 PM   #1886
bubbaslash's Avatar
With the 4-gear trans and either a sideways shorty or saddle packs, you should have plenty of forward bite unless you are running a VERY low grip track. This is the dominant 2wd SCT at our home track, which has bite that can range from low to high depending on the temperature.
Sleeper Slash 2wd HCG VXL...What a hoot!
Chuckworks Slice Super B...Retired
Chuckworks Slice A6...Gone oval
TLR/Exotek chassis 22SCT 2.0 MM...For sale
X Factory SCX-61 prototype...The secret weapon!
bubbaslash is offline   Reply With Quote
Old 09-30-2016, 01:33 PM   #1887
I just received the hexes I ordered for the front hex conversion. I ordered the axles, 7mm and 8.5mm hexes. When I put the hex up to the stock axles and look at the distance from the hub to the hex flange on the stock axle; the 7mm looks a bit shorter and the 8.5mm looks for be a hair longer. Which hexes is everyone using to achieve as close to stock measurements and geometry? Or, are there shims used with the 7mm?
Any help is appreciated!
freezeframe007 is offline   Reply With Quote
Old 10-03-2016, 12:59 PM   #1888
sduffy77's Avatar
Trader Rating: 18 (100%+)
We're having a 2 hour endurance race in a few weeks and I'm looking for some input on the best way to swap out the battery as quickly as possible. If anyone has any experience doing this in an Sc5m I'd love to hear it.
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 10-03-2016, 10:38 PM   #1889
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
You may be able to mod a B4/T4 battery strap to fit with the thumb screw type releases.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 10-04-2016, 05:29 AM   #1890
Trader Rating: 17 (100%+)
Slot the side rails on the Chassis Brace and use a Velcro Strap on the top of the battery, and tape your foam spacers directly to the batteries
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Scott R is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
