    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree24Likes
Old 08-30-2016, 07:39 PM   #1846
Has anyone tried a laydown kit for a b5m or t5m laydown kit in an sc5m?
Juicebox315 is offline   Reply With Quote
Old 08-30-2016, 09:23 PM   #1847
55Guy's Avatar
Trader Rating: 54 (100%+)
Default 5m with lay down
I have seen a couple at our track. I and looking for a Anders Lind laydown transmission to run in mine on a carpet track.
Have any of you tried running the shorter B5M shocks on your SC5M on the carpet. I tried on a carpet off road not terrible but need to try different springs and maybe mount on inside hole on a arm.
55Guy is offline   Reply With Quote
Old 08-31-2016, 04:59 AM   #1848
I just put the ACRC 3 gear box in mine. It seemed to help out a good bit for moving weight bias forward. Our track is usually high grip tacky clay, but when I tested it, the track was a little dryer and didn't have quite as much grip. Even then, the truck felt great. I'm excited to see what I can get out of the truck now.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-31-2016, 06:10 AM   #1849
Trader Rating: 17 (100%+)
I have the ACRC 3 gear in mine too. I run on Carpet. I had to put Gray springs on the front and heavier oil in the front shocks but now it runs times not that far off from my B5m with a Yokomo YZ-2 Laydown Trans
Scott R is offline   Reply With Quote
Old 08-31-2016, 10:12 PM   #1850
Trader Rating: 15 (100%+)
Originally Posted by Matt Trimmings View Post
matt,
you are the man. Thank you!
radioctrlhead is offline   Reply With Quote
Old 08-31-2016, 11:38 PM   #1851
aeRayls's Avatar
Originally Posted by radioctrlhead View Post
where can i find replacement drive shaft/dowel pins for this car? I would like to replace just the drive pins and not the entire shaft.
Are you wanting to replace the pin at the bone end that's pressed in or the pin that goes through the bone to axle?
aeRayls is offline   Reply With Quote
Old 09-01-2016, 05:20 PM   #1852
Pin thats pressed in. Now i'm starting to think the link Matt sent was the axle pin thats NOT pressed in?
Old 09-01-2016, 05:27 PM   #1853
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
I now think you are referring to the pin that goes into the outdrive....correct?
Those are not replaceable on AE cars....and most other 1/10 cars as well.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-02-2016, 08:03 AM   #1854
jkas10's Avatar
Trader Rating: 121 (100%+)
Which wheels are for this truck? There are too many different SC wheels being made these days. LOL
I'm looking specifically for the correct AKA wheel. Thanks
jkas10 is offline   Reply With Quote
Old 09-02-2016, 08:29 AM   #1855
shucks. I know TLR had them. They may be a standard dowel pin that I can find anywhere.
Matt are you racing at LRH Hobbies Labor Day? should be a good time.
Old 09-02-2016, 08:51 AM   #1856
chris c's Avatar
Trader Rating: 60 (100%+)
They need to be a 3mm offset 12mm hex...for any wheel you get..
https://www.amainhobbies.com/aka-12mm-hex-cyclone-short-course-wheels-black-2-sc5m-aka23005/p215313
chris c is offline   Reply With Quote
Old 09-04-2016, 07:46 PM   #1857
Super Moderator
I've never seen them on any TLR / Losi / AE 1/10 vehicle...only on 1/8 stuff.
I will not be. I was down at ocrc on friday / saturday.
Old 09-06-2016, 01:43 PM   #1858
Can anyone give me info on cutting the front chassis brace and cradle?
What did you notice when you cut them and maybe even a picture?
atvracer9m is offline   Reply With Quote
Old 09-06-2016, 01:59 PM   #1859
Super Moderator
Info is just a couple pages back.
Old 09-06-2016, 02:40 PM   #1860
This truck was so dialed at the LRH race last night. I loved it. I slammed it per Ryan cavaleri's SRS set up and it was hooked on the track. The grip levels last night at the track were extremely high so slicks were the tire of choice. Enjoying this truck very much over my tlr 22 sct 2.0 which i am still sad to say is gone, but not forgotten.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
