    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree24Likes
Old 08-04-2016, 03:42 PM   #1801
You'll need: chassis, cradle, a-arms, shock towers, shocks, body mounts, body, wheel hexes, turnbuckles, bumpers, side guards, plus a few screws here and there.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-04-2016, 08:06 PM   #1802
Nat Maniac's Avatar
Cheers
From the associated website....
Designed to win
The RC10SC5M Team Kit features a high-performance, no-compromise dedicated mid-motor designed chassis, configured specifically for short course. The RC10SC5M Team Kit shares nearly 90% of the parts as the B5M and T5M Team Kits, making it easier than ever to run multiple classes at the same time.
They must have been counting the screws!! LOL
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 08-04-2016, 08:11 PM   #1803
aeRayls's Avatar
Originally Posted by Nat Maniac View Post
Cheers
Designed to win
It says 90% of the T5 as well... Which is very true
aeRayls is offline   Reply With Quote
Old 08-04-2016, 08:38 PM   #1804
Cheers
Designed to win
90% is probably accurate when you think bearings, screws, ball ends, etc... It sounds good but really the replacement parts such as arms are unique to the buggy and truck, of course. either way, its a really fun to drive and durable SCT.
hsp-sandiego is offline   Reply With Quote
Old 08-06-2016, 06:36 PM   #1805
Thanks for the help everyone this is what I ended up doing. Cut the chassis, had to tighten the diff just a smidge, went from a green to a kyosho red front spring, and added another 2mm spacers under the front ball stud. The truck is hooked up now, race tomorrow will have to see how it ends up, at least I have a chance now.
Rass79 is offline   Reply With Quote
Old 08-12-2016, 10:37 AM   #1806
In the name of brotherly love here. I need a little more power. We are both running Tacon 3650 3500kv 10T motors. So I would like a little more oomph out of mine. I do not need to go light speed, but faster than he goes would be nice. One of the guys at the track said to get a sensored motor. OK would it be just another 10.5T or would a 11.5, 12.5, 9.5, 8.5 motor have a little more get up and go?
We had a great night last night. We both have truck that are doing very well. They buggies guys I was running with were impressed at well the trucks were flying around the track. Brothers truck has the 3 gear tranny, I have sway bars. Mine handles just a touch better and his flies a touch better. I can stick the inside line and hold it better then he can, but he can fly through the triples batter then I can. So each has it plus's and minus's.
I just need to do the 3 gear and get a bit better motor.
Thanks.
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 08-12-2016, 11:13 AM   #1807
Thanks.
Buzz.
8.5 works well. I have ran a reedy 7.5 as well. I ran smoother and more consistent laps with the Tekin 8.5. running a Tekin Gen2 RS controller. great combo and setup with hotwire on a PC. Your sig. says "really southern ca." - guessing you run at sdrc...? Here is my sc5m... if you see me there sometime.
-Harry
Old 08-12-2016, 02:21 PM   #1808
Yes I run at SDRC. We are there on Thursday night most of the time. We may call it racing, but more of a crash course in getting around the track. We have a good time.
I will look at those combos.
Buzz.
Old 08-13-2016, 07:00 AM   #1809
Yanks213x's Avatar
I'm trying to get aluminum rear clamping hex. What size 8.5mm? Thank you.
Yanks213x is offline   Reply With Quote
Old 08-13-2016, 07:36 AM   #1810
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
That is correct.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-15-2016, 12:02 PM   #1811
rimracker's Avatar
Trader Rating: 14 (100%+)
I asked about using a B6 gear diff in a SC5 a few days ago, like most people figured, it fit. I took some measurements, the B6 diff is a hair wider. I also took a measurement with the alum spacers on. In case anyone else was wondering.
Ball diff pic #1, gear diff #2, gear diff with spacers #3
Offical Team Associated SC5M Thread-img_1475.jpg   Offical Team Associated SC5M Thread-img_1476.jpg   Offical Team Associated SC5M Thread-img_1477.jpg
rimracker is offline   Reply With Quote
Old 08-15-2016, 12:39 PM   #1812
Cool - Are you running on clay, and if so, how do you like the gear diff vs. ball diff. thanks.
Old 08-15-2016, 05:55 PM   #1813
rimracker's Avatar
My local track went turf. Just finished the build, looking to run it Wednesday.
Old 08-16-2016, 12:45 AM   #1814
Hasi's Avatar
I run on clay. Used the gear diff with the black asso grease in it like I did in my SC10 which worked well, but I don't like it in my SC5m. Car has less on-power-traction cause the diff is locked too much. Could be better using diff oil instead of grease but since I have none and the ball diff works very fine, I haven't tested it.
So I prefer the ball diff over the gear diff in my SC5m, gear case is the 4-gear.
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
Old 08-17-2016, 09:02 PM   #1815
I may be doing something wrong here, but this is my 3rd set of big bores that leak like a stuck pig. I have tried cranking on them like the Hulk, just enough to snug up the tops and just about everything in between. Do they just leak or am I doing it wrong?
Picked up a CHEAP!!!!!! sensored 8.5 setup. 120amp ESC and a 4620kv 8.5 motor. Will see how well it works. I got burned on the Viper, so hard to spend that much on a setup.
Other than the shocks leaking, this truck is very fun to drive. Brother and I were cranking the laps by last week. Both got some 25 flat laps in.
Non of the shops around have the black or silver springs. Looks like I will have to order them.
Buzz.
