    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 08-01-2016, 10:18 AM   #1771
sduffy77's Avatar
Trader Rating: 17 (100%+)
Originally Posted by RC Juice View Post
I took my SC5M out for the first run last week. Overall I'm very happy with how it drives but am going back and forth on the ride height. I see by reading through this thread and from most setups online that almost everybody runs lower ride heights than the kit setup, to get even close to those I have to run the collars up enough that that the springs have some freeplay in them which I of course don't want (I'm using the middle spring cups, and gray front, white rear springs). These ride heights are also far from the kit setup of "bones and front arms level. I didn't mess with ride height too much last week and plan on doing more experimenting this week, but the truck did feel a little "lazy" coming off jumps like the suspension was just sacking out on the jump face and not preloading. Is the kit setup for ride height just that far off for everyone?
I'm running 29 front / 27 rear with the gray front / white springs as well on a bumpy outdoor track with some descent jumps and it feels pretty good. When in doubt, listen to Cav.
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 08-01-2016, 11:52 AM   #1772
RC Juice's Avatar
Trader Rating: 140 (100%+)
Thanks for the replies guys. I guess what is throwing me off is that I have not seen any setup sheet or anybody mention running anything other than the 5mm cups and I just don't see the way to get the ride height right without the springs clanking around. I guess I just need to make the changes that work for me, but I just feel like I'm missing something here. Is anybody running the smaller spring cups?
RC Juice is offline   Reply With Quote
Old 08-01-2016, 11:57 AM   #1773
Default ride height
yeah, depends on outdoor or indoor / traction. according the Cavilleri's setup sheets, he ran 30/28 at Hot Rod (small/medium outdoor - i have run there quite a few times), although as low as 25/23 Indoor last year at Nationals.
Too high and you are traction rolling, Too high and you're driving a bus.
hsp-sandiego is offline   Reply With Quote
Old 08-02-2016, 04:06 AM   #1774
sduffy77's Avatar
Are you using the original springs? They're shorter than the new "truck" springs. Use the tallest spring cup if you need to however I believe I'm running the +5 front and rear.
Here's a chart that shows the old springs and the new springs:
https://www.dropbox.com/s/i79db158h5...Chart.png?dl=0
yep, that's why I kept the suspension somewhat stiff to prevent the body roll and so it doesn't chassis slap the jumps and landers.
Old 08-02-2016, 04:41 PM   #1775
Thanks for the parts list. I will be ordering them. Have to stay one step a head of my brother.
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 08-03-2016, 06:54 AM   #1776
rimracker's Avatar
Trader Rating: 14 (100%+)
Does anyone know if the B6 gear diff fits in the SC5?
rimracker is offline   Reply With Quote
Old 08-03-2016, 07:14 AM   #1777
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
sure...since is the same diff as the 5 series
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-03-2016, 07:23 AM   #1778
Trader Rating: 16 (100%+)
Are your sure? They have different part numbers.
B6 Gear Diff - ASC91703
B5 Gear Diff - ASC91461
Scott R is offline   Reply With Quote
Old 08-03-2016, 07:25 AM   #1779
I don't think that's accurate. The B6 can use B5 diffs with shimming, so that probably means that the B6 diffs are wider than the B5's and thus, won't fit. I could be wrong about the 6 series gear diff though. But the 5 series diff (#91461) fits no problem.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-03-2016, 07:28 AM   #1780
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
B6 BALL diffs are different (wider). The B6 gear diff is the same width as the B5 gear diff. The main difference I believe is the B6 version comes with an aluminum outer cap.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-03-2016, 07:45 AM   #1781
the b6 gear diff comes with the option alum cover.....hence the new part number
Old 08-03-2016, 07:54 AM   #1782
There are other differences too, the B6 diff gas different shims and 2 o rings that the b5 doesn't
Offical Team Associated SC5M Thread-picture-1.jpg   Offical Team Associated SC5M Thread-picture-2.png
Old 08-03-2016, 08:20 AM   #1783
the big black shims are for the b6 tranny. no needed for the b5. the rest is just updates. look at the outdrive and diff case part numbers....they are the same....since those are the "fitment" pieces.
Old 08-03-2016, 08:29 AM   #1784
cool - I was thinking about getting a gear diff as this the rc my young boys also drive. Sounds like it would be smart to get the B6 version - with the aluminum cap and all of the included shims.
Old 08-03-2016, 10:02 AM   #1785
I just put a b5 gear diff in my sc5m this morning.
