    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 07-08-2016, 08:29 AM   #1741
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
Originally Posted by blvdbuzzard View Post
I have mine setup per the manual. Same shock settings, same oil, the included springs. What settings can I change to lower it? If I left it off the ground, just set it down I get about 10-12mm sag. That is a guess, have not measured it.
If I can lower it and make it faster, that means I will be that much faster than my brother, that is a good thing. You know, brotherly love and all.
Buzz.
the ride height you see posted in setup sheets is after the truck has been dropped from about 10-12 inches or so. so try dropping it 10-12 inches and then measure. to adjust ride height, you twist the collars on the shocks. twist them up to lower ride height, and screw them down to raise it.
RC*PHREAK is offline   Reply With Quote
Old 07-08-2016, 11:00 AM   #1742
I did the drop form about a foot. Was 32-33mm. I will try again and see what it is. I have the collars adjusted with just enough pressure to keep the springs from moving. So they are about 1/8 from the top so zero pre load on the springs. I am using the stock white springs. Get a set of softer springs? I have the ones from my SC10.2, blue, grey, red and yellow.
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 07-08-2016, 11:08 AM   #1743
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I dont know what track you are on. But even when I ran outdoors, I never went over 30mm in the front or 28 in the rear for sct. I am at 22/20 now because I run on high grip clay. I used limiters to shorten my droop and ran the collars up to lower mine. I would ask a local fast guy how much ride height they are running.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-08-2016, 12:44 PM   #1744
Trader Rating: 14 (100%+)
What batteries and electronics is everyone using for there truck?
chrisw is offline   Reply With Quote
Old 07-08-2016, 11:29 PM   #1745
I use a Reedy 7.5T, Nosram Comet HD ESC and Batteries whatever there is from Hobbyking. Servo a 1015.
man1ac is offline   Reply With Quote
Old 07-10-2016, 04:07 PM   #1746
What would u recommend on spur and pinion running a 13.5 in the sc5m on a tight indoor clay track
Tlr 22 3.0 17.5 stock
Toro electronics
Orion batteries
Futaba 4pks
Lt hopkins is offline   Reply With Quote
Old 07-11-2016, 01:09 AM   #1747
Hasi's Avatar
I use:
- SkyRC Ares pro Competition 13.5t
- LRP SXX TC-Spec
- Futaba S9352hv
- Yuki Modell Brainergy 2s1p 6000mAh 45C Saddle
Started gearing at 24/78, but went down to 21/78 (9.66:1) to handle the temperatures. Was at 87C with 24t and 23t pinion, 21t pinion lowered tempts to 76C.
Clay outdoor track - you can see our track in this video from our last years night race (6 hours full race time in teams of 3-4 persons). Layout changed a bit this year but dimensions stayed the same.
Link: Langstreckenrennen beim IG Racing Team Hamm
Ran my SC5m completely box stock with setup per manual this weekend - except for the body, used a Proline Flo-Tek Ford F-150 Raptor SVT.
Pic with my B5r attached.
Tires: HotBodies MegaBite (pink) (#61742)
Inserts: HPI SC Tire Inserts (soft) (#103335)
Car was really dialed, no need to change anything. Tended to slightly get away with the rear in really dusty turns at full throttle, but not uncontrollably. Just needed a small correction per steering wheel in this cases - really like it this way.
Ran the ball diff with the 4-gear tranny, but wanted to try the gear diff. Build it with the Asso Black Grease as I did with my SC10's, no diff oil used. Worked fine for the SC10 but not for the SC5m - the rear started wanting to overtake my front. Will continue to use the ball diff as it works perfect for our dry loose conditions.
Offical Team Associated SC5M Thread-2016-06-28_asso_sc5m-3171.jpg   Offical Team Associated SC5M Thread-2016-06-28_asso_sc5m-3176.jpg   Offical Team Associated SC5M Thread-2016-06-28_asso_sc5m-3174.jpg
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage, Tamiya Mercedes Arocs 8x4
Hasi is offline   Reply With Quote
Old 07-11-2016, 12:07 PM   #1748
I'm using the following:
17.5 Killshot Maxilla
Tekin RS Gen2 Spec esc
Futaba S9452 servo
Trinity White Carbon 5000mah 100c shorty
SC5M, SC10.2 FT
HPI WR8 flux,HPI Bullet flux
RC10 T4.2 FT
SC10 4x4
RC10T Team Truck,RC10
Fastz28 is offline   Reply With Quote
Old 07-11-2016, 02:08 PM   #1749
If you are looking for aluminum bell cranks, avid has them at reduced pricing. I have these in my sc5m.
http://www.avidrc.com/product/5/acce...cessories.html
Old 07-15-2016, 10:37 AM   #1750
Yanks213x's Avatar
I just built this kit to the manual and the rear shock springs rub up against the turnbuckle. I have an idea how to fix it but wanted to see if anyone else had this issue?
B6D (more like a b6) - Reedy 17.5 SS Mach 3, SC5M
Island Raceway and Hobby - Long Island
Support your local hobby shop!!
Yanks213x is offline   Reply With Quote
Old 07-15-2016, 10:43 AM   #1751
Trader Rating: 15 (100%+)
Originally Posted by Yanks213x View Post
I just built this kit to the manual and the rear shock springs rub up against the turnbuckle. I have no idea how to fix it ... has anyone else had this issue?
Left and right rear hub swapped?
Scott R is online now   Reply With Quote
Old 07-17-2016, 04:22 PM   #1752
Trader Rating: 18 (100%+)
Will the transmission handle a 3800 castle system.
Tas4 is offline   Reply With Quote
Old 07-19-2016, 03:01 AM   #1753
jbob's Avatar
Default Sidewinder SCT/1410 1Y 3800KV motor with 3.2mm shaft combo
Yes and it is on sale..$113.00ish
jbob is offline   Reply With Quote
Old 07-19-2016, 06:25 AM   #1754
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
If you are going to be racing I would strongly advise against a sensorless 4 pole system for a 2wd short course truck. Too powerful and not enough low RPM feel for racing. For bashing it would be awesome.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 07-19-2016, 05:58 PM   #1755
I am going to race it on a dirt oval and it just seems the 4 pole stuff has more torque
