    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 06-26-2016, 06:22 PM   #1696
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by rvrslt1 View Post
I cant keep the nose of my truck down when jumping. What am I doing wrong? I have no issue with the B5M or T5M. SC5M is good the rest of the track but cant get it to jump worth a CRAP!
first off, short course do not fly as well at buggy or ST. More people have issues with the sc5m nosing down. I have not heard of anyone with issues nosing up. It is probably how you jump it. And if it is a long big air jump, it is even harder. If you nose up on short jumps, you are probably on the throttle too long and accelerating up the face of the jump. But without driving your truck myself, that is about all i can suggest. Find a local driver that is good and have them run a few laps. And get their feedback.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-28-2016, 04:34 AM   #1697
twindad98's Avatar
Trader Rating: 16 (100%+)
Default jumping
I agree this truck is very sensitive to throttle inputs. I bought this truck after I had been running a b5m for a while and I didn't like it at first. It took a little while to get it to fly right. Most of the problem was my throttle but now I love the way it jumps.
TLR 22 3.0
TLR 22-4
TLR 22T 2.0
RC8.2e
Sticky Kicks RC - Voodoo Racing Cells - Dialed Hobbies
twindad98 is offline   Reply With Quote
Old 06-28-2016, 05:48 AM   #1698
Make sure the body air vents are trimmed too. You could just be parasailing.
boucher is offline   Reply With Quote
Old 06-29-2016, 03:25 PM   #1699
Originally Posted by Wardog41 View Post
anybody try the walliebuilds sway bar
I made my own. I am sure the wallie build one is good.
Old 06-29-2016, 03:39 PM   #1700
loopedeloop's Avatar
I made mine from a b5m rear. Works good
loopedeloop is offline   Reply With Quote
Old 06-29-2016, 07:40 PM   #1701
I got my B5m set in the mail today. I mounted it up front sort of like the pictures a few pages back. I now have them front and rear. Only took a couple extra screws and ball links. Works like it was made for it.
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 06-30-2016, 01:10 AM   #1702
Cridd's Avatar
It have it, it is great.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-30-2016, 10:59 AM   #1703
Trader Rating: 76 (100%+)
Do you have any problems with the arms breaking? I see he's drilling a hole for the ballstud so that the bar will connect to the arm, and I was wondering if that creates a weak point?
MUDVAYNE is offline   Reply With Quote
Old 06-30-2016, 11:00 AM   #1704
nah, I broke a front arm this week....but not at the ball stud hole. on the hinge pin like normal. Think the hinge pin will still be the break point.
Old 06-30-2016, 11:08 AM   #1705
Ok thanks. I run on an outdoor asphalt track in a rally class with no jumps. I ran what I thought was a stiffer setup and won my main by lapping the field (this truck is awesome! lol) but I was told to go even stiffer. I currently have 80 weight oil in the front with a gray spring and 60 in the back, 1.5 pistons. I'm going to see how the truck reacts to these changes and then I'll determine if I still need a sway bar. I'm thinking probably so but I don't to throw a lot of changes at it all at once.
Old 06-30-2016, 11:26 AM   #1706
Had another run with my SC5M, the guys fixed some broken clay (dry, wet, dry, extreme wet and extreme dry really messed it up). So we got sections which have good grip, like flat dried clay (good grip at my measures ) and loose stuff which makes it even hart to drive straight.
The SC5M didnt handle that well, kinda back to my problem loosing the rear when entering fast corners. I didnt want to do any tuning, cause my money is on the B5M and B6 someday. But at the moment I am just loosing confidence in the truck and think of selling it
Current setup is:
>front shocks 35wt and grey spring
>rear shocks 30wt and green spring
>ball diff just opened a notch, any more closed and its shut for good
> Hole Shots front and rear, standard plastic rims
> shorty at rear position
So its either sell it or make it the way I like it.
Thinking of adding brass c and d, increase rear toe to 3,5 (which wont help me just for acceleration?) Any more suggestions? I even think of trying to switch to gear diff with 5k...
@ Ray: you suggested 1.7 and 37,5wt for rear?
man1ac is offline   Reply With Quote
Old 06-30-2016, 12:49 PM   #1707
Any body in search of a fast ARTR. Check out the classifieds.
faron5M is offline   Reply With Quote
Old 06-30-2016, 06:35 PM   #1708
Cridd's Avatar
Current setup is:
Try turning down your dual rate on the steering so it doesn't turn as far. I have mine around 70. If I was at 100 it would wash on on the ass end, too much steering.
Chris
B6D / T5M / SC5M
Old 06-30-2016, 06:35 PM   #1709
Cridd's Avatar
I have not broke any arms.
Chris
B6D / T5M / SC5M
Old 06-30-2016, 06:53 PM   #1710
I lowered my Dr also and used stop gap screws
