    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree18Likes
Old 06-11-2016, 06:27 PM   #1651
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
You might be driving through the suspension and chassis slapping the jump face.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 06-12-2016, 07:27 AM   #1652
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by hotrodjb96 View Post
I'm having an issue with nose diving hard on jumps. I have a lot of weight in the rear. Both Brass mounts and rear battery position. Have gray front and green rear springs. Shock oil? This was in 17.5 race today, not as bad with a mod 8.5 because I can drive it better and juice it at take off. Thoughts are appreciated, thanks
remove the drag brake or stay on the gas. If you try to scrub it like a buggy, it will nose down hard.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-12-2016, 11:43 AM   #1653
Originally Posted by loopedeloop View Post
Quick question Ray
The front springs you are using, are they the #91637 or #91329
I brought the FT med spring assortment but it has #91329 which seems softer and is shorter than the white spring that came with the kit
There are now truck and buggy specific Springs, I believe the white that come with the kit of the truck are rated at 4.05 pounds. I have seen people using the purple buggy front Springs (which are rated stiffer than the truck front gray ones) with the 9mm cups
shdwboxn is offline   Reply With Quote
Old 06-12-2016, 11:46 AM   #1654
I don't run any drag brake and I tried wide open, lift a little then gas it. Same results. Almost like the back springs are sending the ass up after take off. Pretty strange acting
hotrodjb96 is offline   Reply With Quote
Old 06-12-2016, 12:13 PM   #1655
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
with green rear springs, this would be my guess.
RC*PHREAK is offline   Reply With Quote
Old 06-12-2016, 01:25 PM   #1656
Too soft? I'll try some others and see what happens. Rear ride height is 25mm so that's probably what is happening. Thanks
Old 06-12-2016, 09:12 PM   #1657
loopedeloop's Avatar
Awesome, Thanks
I have ordered 3 sets of the truck springs incl. gray as I dont have the ppl ones
cheers
loopedeloop is offline   Reply With Quote
Old 06-13-2016, 08:24 AM   #1658
Tested some sway bars this weekend on the sc5m. I suggest running the if you are on higher grip. I custom made both my front and rear bars using 1.6mm piano wire.
Old 06-13-2016, 08:33 AM   #1659
Super Moderator
Trader Rating: 17 (100%+)
In case you guys didn't notice it, I've created the Wiki for this thread. (Actually Wildcat did as a test for me ) Similar to the old '1st page' posts, but now it appears at the top of every page.
Anyone can edit it, but just keep in mind that EVERY edit is recorded and we can see who did it. Abusing it will result in a forum ban.
My suggestion is that if you have a new item you want to post on the Wiki and aren't sure if you should, just post it in the normal part of the thread and ask. If you see a majority in agreement, post it.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-14-2016, 06:15 PM   #1660
I just opened the box tonight. Will start the build tomorrow or this weekend.
I have been abusing a SC10.2 for the last two years. I have it setup pretty well. Handles almost as good as my brothers sc5m.
I do not race, but my brother and I go to SDRC every Thursday and crash into each other, we call it racing. We have a good time. So I need to be faster, better than my brother. You know brotherly love and all.
I bought a set of these for my SC10.2 and was wondering inf any one is using them on the SC5m? I never put them in as I broke the chassis again and just ordered the SC5m.
https://www.amainhobbies.com/vrp-12m...h1.5v2/p450916
Does the sway bar kit ASC91535 fit this truck?
https://www.amainhobbies.com/team-as...c91535/p275291
I have a good selection of springs from the old truck. grey, yellow, white, blue, red.
Looking to be faster then he is, so any help would be appreciated.
Thanks..
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 06-14-2016, 08:41 PM   #1661
Thanks..
Buzz.
yes that is the correct sway bar
Old 06-15-2016, 08:55 AM   #1662
If you want to hand make sway bars for the sc5m, there are some pictures here:
https://www.facebook.com/photo.php?f...type=3&theater
Old 06-15-2016, 10:44 AM   #1663
Thanks. As long as my truck is faster than my brothers, I am happy.
When ever we make a change or buy something that improves the truck, we call it the super secret. He does not know I have the new SC5m. I broke the frame on my old truck, told him I am using the parts from my 2 old trucks to make one complete truck. He wont notice what under the old body, so when I blow his doors off, he will wonder why
Thanks.
Buzz.
Old 06-15-2016, 03:52 PM   #1664
Any one having a problem with the rear in braking loose at the entry and mild of the corner. Im running cavs setup with a front say bar.
Deerek761 is offline   Reply With Quote
Old 06-15-2016, 09:12 PM   #1665
Trader Rating: 16 (100%+)
Any ran a 22 sct 2.0 and can compare?
jjones922 is offline   Reply With Quote
