    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Offical Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Like Tree24Likes
Old 04-27-2016, 10:53 AM   #1531
I think that I need to lengthen the rear hub link setting. Right now I have it the two hole hub insert (B) and I have it set in A location. I am wondering if I need to either move it out to the B location on the B Insert or Install the A insert and put it in the A location. That should help with the rear coming loose on the corner exit when on power right?
Jade67 is offline   Reply With Quote
Old 04-27-2016, 09:54 PM   #1532
Like to switch my rear hexes to aluminium. Which ones do I need? There are so many different offsets available...The manual lists in the kit stock setup sheets 8.5mm in the rear and 6 in the front?
man1ac is offline   Reply With Quote
Old 04-28-2016, 05:18 AM   #1533
Flip boy's Avatar
What type of track are you on? I don't run all the brass in back, that could be why it steps out on you. Green truck rears gray fronts 26 rear ride height 27 front body off. 8.5 hexes rear, i just run the stock front axles because the hexes are flaky from a manufacturing stand point.
Flip boy is offline   Reply With Quote
Old 04-28-2016, 09:57 AM   #1534
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Jade687, have you tried the 30 kickup bulkhead in the front?
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-28-2016, 10:32 AM   #1535
No I have not
Old 04-29-2016, 03:19 AM   #1536
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Jade67
Take the weight out of the front
mount shorty inline with wire end forward
mount esc centered in front of battery
3/4 oz weight on both side of shorty at rear of battery area
-1 to -1.5 rear camber
30 degree front bulkhead
drop ride height 1mm or 2mm
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 04-29-2016, 06:27 AM   #1537
Cridd's Avatar
Trader Rating: 16 (100%+)
Jade 67
This truck has a ton of steering. Make sure your radio steering is turned down. If I turn mine up to 100 it will swap the ass end. I have mine around 60 and can turn up or down as needed. Check your weight bias on a scale and make changes for your nose up and down issues.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-29-2016, 01:34 PM   #1538
Thank you for the advice... Here is an update from Yesterday night at the track:
I took the added weight out of the front end and lengthen the rear camber links. Lengthening the rear camber links helped out a TON. The car feels much more planted now. Ride height is still set at 27fr/25rr but I am going to drop it down a little more because it would traction roll going into the sweeper at the end of the straight. I also am going to turn down the drag brake on the ESC. I realized that it was up rather high, I normally run very little if any at all so I wasn't even thinking about it until I let someone else drive the truck.
Again thank you for the suggestions, I am going to try a couple of the things that were recommended. I am not sure I will do the inline setup as I didn't care for it with my B5M's. I know that they are two different animals but with the changes I made last night it is much better.
Old 05-01-2016, 01:37 PM   #1539
I just bought the truck and really want to keep it light. I found a servo that weighs 38.5G and puts out 191 0z-in at .14 seconds. Its the MKS-HV747. Is there any reason this will not work. Anyone know of a lighter servo that would work?
Cabledawg is offline   Reply With Quote
Old 05-03-2016, 09:17 AM   #1540
55Guy's Avatar
Trader Rating: 54 (100%+)
Default set up sheet for carpet track
Dose any one have of know where i might get some set up sheets for a in door carpet track with lots of traction. I need to try to get my sc5m to quit rolling in corners so bad.
55Guy is offline   Reply With Quote
Old 05-03-2016, 10:31 AM   #1541
sanderson373's Avatar
Add limiters to yur shocks and go up in fluid and either electrical tape or dremel down the first 2or 3 rows of pins on the inside and outside of yur tire. You jus have to play with it. I also went up to 10k in the diff I might go up more but I'm running an 8.5t
Rc8b3e
B4.2, B5M,B44.3, t5m, SC5M, B5M Lite
Extreme Hobby Shop in Spring Hill,TN
Slash 4x4, tekno 410, slash 2wd, blue eagle, radicator
85' goldpan, rc10 worlds car, losi xx4
sanderson373 is offline   Reply With Quote
Old 05-03-2016, 07:02 PM   #1542
55Guy's Avatar
Default sc5m
Thanks I was trying a 6.5 motor but will be putting my 9.5 back in. do people try shorter shocks or any other way to lower ride height
Old 05-03-2016, 09:22 PM   #1543
I just picked up a really nice T5M, what would I need in order to convert it to an SC5M? Thanks for any input.
Nissanguy8 is offline   Reply With Quote
Old 05-04-2016, 12:16 AM   #1544
Go on Ebay and get an S and a C. You will have to find a way to get rid of that T though.
Old 05-04-2016, 08:22 AM   #1545
aeRayls's Avatar
Chassis
Side guards
Front and rear bumpers
Body mounts
Front axles
Center cradle
1 really long screw to go through the rear bumber. Plus some assorted other screws
aeRayls is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
