Like Tree1Likes
Old 10-29-2015, 01:38 PM   #151
bring it on's Avatar
All the little stuff has been fixed and ready for battle tomorrow night...
Toro ESC - SkyRc - Caster Racing USA - Pr Racing USA - Gens Ace - Ares Motors - Highest Servos - Radiopost
Thanks to my sponsor at crpplus.com
bring it on is offline   Reply With Quote
Old 10-31-2015, 06:46 PM   #152
3rd place finish last might...
Old 11-02-2015, 03:18 PM   #153
well after all my testing I did last Friday the friend/customer I did this for decided he wanted a brand new one to build so I worked out a deal for my V4 buggy back and sent him a new one.. I'm working on putting mine back together now.. stay tune for pics
Old 11-02-2015, 03:42 PM   #154
OK, just installed a new servo, these servo's are amazing. even when over steered they make no noise...
Old 11-04-2015, 03:20 PM   #155
I just noticed I have a front stripped wheels when it came a little lose in the main... So I'm trying to boil my stripped wheel and we will see what happens... Also going through my shocks and putting my CRP race bladders back in them.. I have to be ready for this Sunday's race
Old 11-16-2015, 10:03 AM   #156
Had a great time last weekend racing my V4, Took 4th place in the A main..
Old 11-16-2015, 11:58 AM   #157
scott54's Avatar
Hello everyone, looking forward to hearing more about this interesting 4wd. Any specific parts anyone would recommend to have on hand as a backup outside of the norm? If I pull the trigger, I'd obviously grab some arms and shock towers, but anything else?
TLR Racing - ARCS Speedway - B-Fast Racing - Dialed RC - G-Force
scott54 is offline   Reply With Quote
Old 11-16-2015, 04:19 PM   #158
Just got done changing up my rear shock setup... Went back to the CRP race shock bladders, 1.7mm 2 hole pistons, 32.5w oil and 2mm shock limiters inside..
Old 11-16-2015, 04:41 PM   #159
I will let someone like Jeff, Freddy or someone else answer this for you...
Old 11-16-2015, 05:18 PM   #160
This car is pretty nasty as in killer out of the box. I'd recommend arms and maybe a spur or 2 just to have if needed. So far the car is very durable and with all the factory aluminum you should be in great shape. Hope this helps
Caster Racing Team Manager/[email protected]
Team Caster Racing USA-Proline-Reds Racing-Leadfinger RC-Boom RC-Cleanwerkz,crpplus.com...casterracingparts.com
Freddy Marsh is offline   Reply With Quote
Old 11-18-2015, 08:12 AM   #161
Hey Scott my name is Chris and I am in the process of building the S10BS V4 CRP Race Edition. The build is going well and if I have a question Rick has been more than happy to answer my questions quickly. Like others may be telling you, pick up arms, spur gear and being a team kit you will need to have your own choice of shock oil and diff fluid. Be sure to pick up some black grease for diffs and a bottle of thread lock for the alum pcs. The way the packing is done is super cool and keeps everything separated till you are ready to use or build that section. The parts are a nice fit and may require some prepping depending on how you build a kit. The team seems to work together to help bring the best setups. The car is easy to drive and jumps perfect leaving you time to make air adjustments if needed. If you are looking to BE DIFFERENT this is a awesome kit. I am happy I made the change to Caster Racing and like I said Rick is hands on and very easy to work with. Have any specific questions just ask.
lifer74 is offline   Reply With Quote
Old 11-19-2015, 09:49 AM   #162
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
Hey scott, you will love the car and find it to be very durable . The only parts that are worth having in my opinion are the carbon towers , make sure to get the one with the updated rear wing mount, modded rpm arms from crpplus.com they will not break, some extra hub bearings, spur gears, screws for the gear diffs they are small so might as well have some extras, ball studs and ball cups, hinge pins, suspension mount inserts and finally some spare diff gears (the bevel gears inside, never had a failure but good to have a spare set). The car is practically bullet proof once the rpm arms are fitted. The stock arms are great but ive had some snap in very cold weather .
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 11-19-2015, 03:06 PM   #163
Those responds sound about right...
Old 11-20-2015, 10:02 AM   #164
All done and ready for racing tonight...
Old 11-21-2015, 10:45 AM   #165
3rd place finish last night with my new V4 buggy..
