Pre mounted tires???
I got a good deal on some factory pre mounted tires from AKA for my 1/8 E-buggy, and 2wd buggy. I was able to get these cheaper than buying tires wheels and foams separately then mounting them. Should I do any extra glueing, or is there anything I should do before running them?
I have some tires specifically for indoor clay and some for outdoor, what are your thoughts on putting holes in tires? I have a tire punch, which obviously I can’t use now, so should I drill a couple of holes in the tires?
The AKA premounts I bought had holes punched in them.
Nothing wrong with premounts! Always check the gluing before using though
DIY Nylon Belted Tyres
Does anyone else glue in a nylon mesh to stop the Tyre turning into "pizza cutters"?, i find i get more control,longer life and even treadwear across the whole width of the Tyre. Cheers
The tape in the photo is the same stuff used when your plaster boarding a house ,i think you guys call it "drywalling". By "goop" do you mean ShoeGoo? as i found it did'nt seem flexible.
