    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 07-01-2015, 09:31 AM   #1456
Originally Posted by Dragonfueled View Post
I like using 3s. The 2400 geared 23/44 just isn't fun yet lol. I might try 3800 on 3s and see what happens
The 1410 is 2s limited
theboss13 is offline   Reply With Quote
Old 07-01-2015, 09:35 AM   #1457
Originally Posted by Hoese37 View Post
Id be interested to see how the 4x1.8 pistons will make the truck handle.
Try it, and let me know. haha
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 07-01-2015, 10:14 AM   #1458
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Castle says you can run the 3800 on 3s, just be sure to gear it correctly.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 07-01-2015, 06:09 PM   #1459
Trader Rating: 36 (100%+)
What is a good starting point as far as shock oil for the 1.5 pistons
mxturd is offline   Reply With Quote
Old 07-01-2015, 07:05 PM   #1460
35/30 30/27.5 27.5/25
Try those, see how it feels for you. 35/30 is a good start for me...I'm running 450/350 and want to soften it up just a hair.
Old 07-01-2015, 08:34 PM   #1461
Originally Posted by Barillms View Post
If anyone is looking for a tough body... The JConcepts Nissan Titan is a really good body. Reinforce the front clip with dry wall tape & shoe goo, and the rear corners. I have lots of hard crashes on mine, endos, cartwheels... You name it. It's holding up great.
My last body was the JConcepts Manta. It broke in 7 places in my first 2 races. It was BAD. JConcepts sent me this Titan for free, and its night & day stronger than the Manta. The bodies with more detail, more creases, more lines seem to be weaker than the more simplistic body designs. This is simply my opinion, but I do believe the added creases create weak points.
Thanks for the heads up. I have been using the JC high flow and it's beat up pretty bad. Where can I get more tips on how to reinforce it?? I hate getting breaks and cracks by the mounting holes.
Mark
Riflebuilder is offline   Reply With Quote
Old 07-01-2015, 08:57 PM   #1462
I'm running the castle 4 pole 3800 it is pretty fast an torque an low temp with a 14 tooth
Aswild is offline   Reply With Quote
Old 07-01-2015, 10:24 PM   #1463
JAE
Trader Rating: 28 (100%+)
Default Xerun 4000kv 3s
I'm getting conflicting info regarding a 3s setup with this motor/esc combo and low pinion. Is it a consensus 3s is too much on the 4000 kv at a low 11 tooth pinion?
JAE is offline   Reply With Quote
Old 07-01-2015, 10:40 PM   #1464
Hoese37's Avatar
Mark
Get some shoe goo and some fiber mesh drywall tape. Smear a layer of goo around the post holes, then lay the mesh in, and a final layer of goo on top of that. It also does help to not tighten the post mounts so tight that they don't wiggle. Keep them a bit loose and make sure the holes in the body are slightly bigger than the post.
HW rates the 4000 good for 3s, but running it at that voltage does seem to heat it up a bit from reports that ive seen. If youre that low on a pinion youre probably very undergeared.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 07-01-2015, 11:13 PM   #1465
Barillms's Avatar
Anyone running the CSI V Port Pistons? Blue or Red?
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 07-01-2015, 11:19 PM   #1466
Barillms's Avatar
There's 3 set up sheets available on Tekno's website. Most people seem to be running 35 front 25 rear. Just keep in mind Losi oil is slightly lighter than AE oil. For example, 32.5 Losi oil is 30 in Associated. Keep that in mind.
Also, one of the things I noticed from looking at the set up sheets was the droop the sponsored guys are running. They are all running 105 Front & 120 Rear which surprised me. That's limiting the down travel quite a bit
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 07-02-2015, 12:49 AM   #1467
Hoese37's Avatar
Its not very limiting. Droop is measured by measuring the length of the shock, and at full extension the rears are 122. So 2mm isnt that much at all.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 07-02-2015, 04:40 AM   #1468
Switched from Hobbywing SCT Xerun setup to a Tekin RX8 GEN 2 and Pro4 motor and it seems a good amount faster. Pretty excited to make it to the track Saturday!!!
Old 07-02-2015, 08:26 AM   #1469
which pro4 motor?
Old 07-02-2015, 10:05 AM   #1470
The smallest pinion that will fit on the split diff is a 14 tooth, which might work depending on how big your track is.
Tekno RC
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
