    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 06-28-2015, 06:11 PM   #1426
Originally Posted by Jvcaniggia View Post
Anyone have any opinion on the spectrum 6040 servo? I got a great deal a few weeks ago on a brand new 410.3 with a Tekin pro4/rx8 setup. Came with this servo. Bought a glitch buster as it was aittle noisy. The 23 tooth metal servo born looks a little small and seems to be angled upward. In any event, does anyone have any thoughts or recommendations with this servo?
I went with a ds 1313 /173oztrq ,team associated an u can send in your old hard wear an up grade for a deep discount I'm going to up grade to the ds 1015// Torque: 14.5 kg/cm (201.4 oz/in) @ 6V an i am going to get it for like 30 bucks plus my old servo ,castle does the same u can upgrade thru them too ,with moters an esc so they both have good programs, and the servo horn should lay flat an pearalale so it sounds like it is not hooked up correct i just orderd a new one for mine from feirce souluitons
Aswild is offline   Reply With Quote
Old 06-28-2015, 06:28 PM   #1427
youwish16's Avatar
Trader Rating: 19 (100%+)
Really? I dont see the DS1015 on the list for the exchange program? I have 2 old servos I would send in if I could get 2 DS1015s.
http://www.teamassociated.com/pdf/up...ge_program.pdf
Allen Krier
Tekno ET48, Protek 130T, Tekin 2050kv, Tekin RX8 Gen2 ESC, James Tires
Tekno EB48.4, Protek 100T, Tekin 2050kv, Tekin RX8 Gen2 ESC, James Tires
Tekno NB48.3, Protek 100T, Protek 100SS, Werks B2, Dynamite Pipe, James Tires
youwish16 is offline   Reply With Quote
Old 06-28-2015, 11:06 PM   #1428
Barillms's Avatar
I ordered a Savox 1258TG today. $59.99.
I hope it holds up. I crash alot lmao
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 06-29-2015, 05:53 AM   #1429
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I ran a 1258 in mine for quite a while with no problems. I think the drive train can over-power the servo under heavy cornering conditions though. My son has been running much more powerful servos with a bit more speed (Protek 150S for example) and I really like how his truck feels in regards to the steering.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 06-29-2015, 06:57 AM   #1430
Barillms's Avatar
Hmmm interesting. My last one I damaged by landing hard on the nose. This track had a rhythm section, that throws you 6-7' high. Small landing area, not very forgiving. I crashed alot one practice day, before I got the hang of it. It was hard on the truck.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 06-29-2015, 06:59 AM   #1431
I got the 1256TG for that reason, might be a bit too slow, I guess I'll see when I get everything together and runnin'
captain spauldi is offline   Reply With Quote
Old 06-29-2015, 07:40 AM   #1432
rjohn929's Avatar
Originally Posted by Barillms View Post
What's the best $60 Servo to put in these? I bought a Turnigy TS920 and its fast, but after 5 races & some hard landings... It's got slop in it already.
I don't know what Servo to buy? I'd like a .08 or .10 for $60. HiTec? Spectrum? Savox?
Was this from user error or abuse?
Just messing with you man.
SCT410.3, SCT410, ET48, SCTE 1.0, SC10 4x4, SC10, B44.1, B44.2, Yeti, Yeti XL, Wraith, SCX10 JK, Gold pan/repro, Worlds Car/repro, Rival, Emaxx, Tmaxx, assorted Ofna's, 6 Big Bears, MERV, 3DR Solo, DMG DRIII, Vanquish, Avante, mixed bag of crawlers/scalers and the list goes on and on and..........
rjohn929 is offline   Reply With Quote
Old 06-29-2015, 07:53 AM   #1433
youwish16's Avatar
I've used a 1258TG in my buggy for almost 2 years with no issues. I recently moved it to my SCT410. It's still going strong.
Allen Krier
Old 06-29-2015, 08:50 AM   #1434
Just call them thats what I did ,the guy i spoke to was nic
Old 06-29-2015, 09:05 AM   #1435
Hoese37's Avatar
That's a helicopter Servo man. Lol
No difference from a "surface" servo. Heli/cyclic just means they are super fast.
I don't understand why the hell they do that? It's ridiculous.
All about application. They try to get a length that works in many different vehicles. My 1015's fit perfect in my nitro buggy and Truggy, but were about an inch short in the Tekno.
Originally Posted by theboss13 View Post
While it has great speed and torque ratings for car racing it IS a helicopter servo..... It says it in the name.....while I do think it would work well in this car..... It is a heli servo
Doesn't matter. Hitec makes servos for robotics, but also recommends them for 1/8 steering servos.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-29-2015, 09:05 AM   #1436
Moderator
bds81175's Avatar
I had a 1256 as well. It was just too slow for what I was used to.
Tekno RC
Old 06-29-2015, 10:59 AM   #1437
Shawn_S's Avatar
Trader Rating: 18 (100%+)
I run a BK Servos BLS-8001 in my EB. It's a cyclic air servo, but yea, there's generally no difference, other than it comes with as nice long lead so you don't need to use an extension. Best servo I've ever had, and I've had most of the high end servos.
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 06-29-2015, 12:42 PM   #1438
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I have this in my EB48 and its been great for going on 2 seasons now. The price is right and its pleanty strong.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 06-29-2015, 04:46 PM   #1439
Also i have a printed out sheet an it has it on there,thats weird
Old 06-29-2015, 05:18 PM   #1440
Close but no 1015.
Whosold is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
