    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 06-27-2015, 04:29 PM   #1411
Hoese37's Avatar
Originally Posted by Dragonfueled View Post
Anyone end a rear shock tower yet? 3 packs in and mine is bent forward.
That will happen if you land on the back end and lid a lot. The towers are just stamped aluminum, nothing too special. Im sure if the demand was warranted to Tekno, they would get the machined towers made for the truck, but then youd be adding about $50 to the cost of the kit. The kit materials are there to make it more cost effective.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-27-2015, 04:40 PM   #1412
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
how thick are the stamped towers? To be honest when I had the OG 410 it looked like you could darn near put two towers together and just bolt up if the other bolts were long enough.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 06-27-2015, 04:44 PM   #1413
Hoese37's Avatar
Same thickness as the original. 4mm.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-27-2015, 07:33 PM   #1414
Barillms's Avatar
What's the best $60 Servo to put in these? I bought a Turnigy TS920 and its fast, but after 5 races & some hard landings... It's got slop in it already.
I don't know what Servo to buy? I'd like a .08 or .10 for $60. HiTec? Spectrum? Savox?
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 06-27-2015, 08:31 PM   #1415
Trader Rating: 32 (100%+)
I order this in hobbyking great servo. I have also KO PROPO i feel same faster.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
raved007 is offline   Reply With Quote
Old 06-28-2015, 01:08 AM   #1416
Idk if it would have enough torque for you in one of these but the spektrum s6040 fits your speed and price specs...
theboss13 is offline   Reply With Quote
Old 06-28-2015, 07:51 AM   #1417
Tech Legend
Cain's Avatar
not sure if amain has any discounts right now, but I have heard that the Protek 130T servo is good and its specs look fast and high torque.
Old 06-28-2015, 09:43 AM   #1418
That's what I put in mine and I really liked it.... But be warned you must get a servo extension to run it....the wire is waaayyyyy to short
Old 06-28-2015, 11:21 AM   #1419
JAE
Trader Rating: 28 (100%+)
Anyone have any opinion on the spectrum 6040 servo? I got a great deal a few weeks ago on a brand new 410.3 with a Tekin pro4/rx8 setup. Came with this servo. Bought a glitch buster as it was aittle noisy. The 23 tooth metal servo born looks a little small and seems to be angled upward. In any event, does anyone have any thoughts or recommendations with this servo?
JAE is offline   Reply With Quote
Old 06-28-2015, 12:48 PM   #1420
Originally Posted by qstorm777 View Post
Yeah. There has been some posts about that and about using the cf ones or if there is enough interest, M2C would probably make some 7075 alum ones.
Just bought teknos carbon rear tower. I know that won't bend lol
Dragonfueled is offline   Reply With Quote
Old 06-28-2015, 02:10 PM   #1421
Barillms's Avatar
That's a helicopter Servo man. Lol
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 06-28-2015, 02:11 PM   #1422
Barillms's Avatar
I don't understand why the hell they do that? It's ridiculous.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 06-28-2015, 03:43 PM   #1423
LOL that's not i have installed in my tekno sct410.3 if you don't trust me never mind.
Old 06-28-2015, 04:07 PM   #1424
Idk... All I know is that I was lucky I had one deep in my box so I could run.....it's a good servo... It's the most quiet servo I've had.... It doesn't chirp at all.....
Old 06-28-2015, 04:11 PM   #1425
While it has great speed and torque ratings for car racing it IS a helicopter servo..... It says it in the name.....while I do think it would work well in this car..... It is a heli servo
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
