    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 06-26-2015, 07:39 PM   #1396
Hoese37's Avatar
Originally Posted by HSV427 View Post
The truck has plenty of power with a 2s system if your planning a 4s system you may want to seriously consider beefing up the drive train as tekno specifically designed the .3 to be very light and run 2s, there is no way the plastic spur and diffs will handle the power and torque of a 4s, i would consider 3s to be the maximum for the truckin its current form just my opinion based on the damage i have seen a 4s do to the stock drive train.
Spur and diffs are the same as found in the EB 1/8 buggy. There is no adverse effects to running the truck on 4s. Many have done so in the past running the Pro4 1850 motor. Makes for a really efficient setup.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-26-2015, 07:44 PM   #1397
Hoese37's Avatar
Originally Posted by Jvcaniggia View Post
Thx - Maybe I'll just buy this roller and swap out to air guards. Like my 410.3 so much I'm going to find another to run 3s-4s just to practice on with a 3000kv motor. What are your thoughts on that roller? there is another one too just built never used on Ebay...
Truck looks pretty standard. Not in too rough of a condition. The rear most screws are starting to wear it looks like, so if you were racing it probably replace the chassis after the season. Thatd be my only issue I see. But if youre bashing, no real big deal.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-26-2015, 08:38 PM   #1398
JAE
Trader Rating: 28 (100%+)
Thanks for the advice. Just getting back into it. Have a bid on this one too but can't pay more than 220 http://m.ebay.com/itm/121684651208?_....c100408.m2460
JAE is online now   Reply With Quote
Old 06-26-2015, 10:33 PM   #1399
So what are yall running ride height wise as I went to set mine to 25-24 and I could only get the front down to 25.5 or 26... Both front and rears are on the inside on the towers and outside on the arms....
theboss13 is offline   Reply With Quote
Old 06-26-2015, 10:45 PM   #1400
Hoese37's Avatar
Your springs will need to break in a bit, and then they will settle. That will give you the ride height you want. Until then, just run as low as you can get it.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-27-2015, 05:09 AM   #1401
[QUOTE=theboss13;14070112]
Originally Posted by Hoese37 View Post
No need to worry about the towers. The rear is now 5MM thick, and the front has lost the recesses for the stand off. So there is now more beef in the towers which will reduce breakage.
Ok I called castle and talked to them and they stated that a vehicle like the tekno is what the sidewinder sct is made for....they told me 6.5 and the tekno weighs 6.2 with rx8 and sct motor....... And it is much less with normal electronics...... And as for the motor the man I talked to said it was basically a 550 rotor stuffed in to a 540 can as roar did not like the power the 550 made and so to get around it they stuffed it in a 540 can which there where no rules for in 4wd sct as it was considered too weak to drive a 4x4..... I'm giving it a shot tomorrow and we shall see..... Hopefully it works as claimed lol
I got the sct pro 3800 kv so what did he say that would be a good combo the 3800 with sidewinder
Aswild is offline   Reply With Quote
Old 06-27-2015, 05:10 AM   #1402
Aswild: About to place my last bid. Looking at $220 for the new SCT410 partially assembled. The other used one has 15hrs left on Ebay and was going to bid $200. I think those are great deals compared to the quality of the durango. your thoughts?
Man good luck thats a great deal half off ,an with some extras let use no what happens
Old 06-27-2015, 05:12 AM   #1403
Ordered these from Omni models. They new nerf guards do not have the same hole placement. Further, even if you drill new ones, this this doesn't fit. the holes would be too close to the edge and they would crack to the side. Does anyone know who makes Air Guards? Preferably Carbon Fiber (can't find hot laps anymore)?
Below doesn't fit
http://www.ebay.com/itm/NEW-Tekno-R-...6#ht_952wt_834
U can get them from feirce solutions for a lot cheapie an he is a sponsor here i would get from him,he is always on forum too
Old 06-27-2015, 05:14 AM   #1404
Even tho they are flimsy, they are located in a spot where not much stress is placed on them. I had them on my original truck for 2 years with zero issues.
I put the carbon fiber vinyl on mine and on the bottom of truck does that count?
Old 06-27-2015, 07:44 AM   #1405
[QUOTE=Aswild;14070652]
Yeah we talked about the 3800 1410 with the sidewinder SCT esc..... I have a race today so I will let yall know if it lasts
Old 06-27-2015, 07:45 AM   #1406
Ok thanks!
Old 06-27-2015, 10:28 AM   #1407
Anyone end a rear shock tower yet? 3 packs in and mine is bent forward.
Dragonfueled is offline   Reply With Quote
Old 06-27-2015, 01:43 PM   #1408
Default Servo Saver Setup
I installed the servo saver as the manual says (nut three full turns open). In my opinion this setup is rather soft. How is your experience/setup? Can i close the saver completely or will this lead to a damage of the steering? I'm not really worried about the servo, as it is quite strong (Team Orion VDS2-HV2607).
T5M / B6 / F6 / RC8B3e
Uhudler is offline   Reply With Quote
Old 06-27-2015, 02:11 PM   #1409
[QUOTE=theboss13;14070753]
Ok I can confirm that the sidewinder sct is plenty powerful and will not overheat..... I ran in thick clay after some rain and it still didn't overheat...... It's also plenty smooth....... And I have a buddy running a 410 with tekin and I actually was a hair faster......
Old 06-27-2015, 02:34 PM   #1410
Yeah. There has been some posts about that and about using the cf ones or if there is enough interest, M2C would probably make some 7075 alum ones.
qstorm777 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
