    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 06-22-2015, 06:43 AM   #1291
Originally Posted by bds81175 View Post
I ran a Castle MMP in my SCTE for 2 years with no issues running a Tekin 4000Kv 4 pole 540 motor. The Losi is almost as heavy as the Tekno. I'm not a huge fan of Castle products (chinsy quality and pathetic BEC's) but I think it will do in a pinch. Just remember, running these vehicles with no current limiting and wide open throttle usually results in higher temps, more wheel spin, and slower lap times. Being able to pass someone on the straight is totally useless if they return the favor and blow you away through the infield. Also, if the ESC fan quits working, it needs to be dealt with promptly. Running without the fan will cook the ESC pretty easily.
Cool thanks!!
theboss13 is offline   Reply With Quote
Old 06-22-2015, 07:05 AM   #1292
Got most of my SCT410.3 built over the weekend, how is everyone building their shocks? Recommended way is vented, I've never built shocks as vented or emulsion, just the traditional way w/the bladder.
captain spauldi is offline   Reply With Quote
Old 06-22-2015, 07:15 AM   #1293
Originally Posted by MattP View Post
I tried a castle sct combo and cooked the esc on the second track visit. Castle recommends it to be used in light scts only. The 3800 castle motor was not a good choice for a Tekno. I ended up going to a rx8 with a pro4 4600 and it was a massive difference. The tekin was more powerful all around and both esc and motor ran cooler than the castle setup did. The hobbywing sct pro and hobbywing 4000 is a awesome combo also that's cheaper than the Tekin.
What did u set up the esc at do u recall?
Aswild is offline   Reply With Quote
Old 06-22-2015, 07:18 AM   #1294
I did vented but made it so i can use them as emulsion later on whe i want to try that style
Old 06-22-2015, 07:41 AM   #1295
Stupid question time: Are those clear fins mounted on top of the nerf bars part of the kit or something extra? What are they called?
Noize is offline   Reply With Quote
Old 06-22-2015, 07:46 AM   #1296
Suspended
Trader Rating: 440 (99%+)
The castle esc I used was straight factory settings. All I did was calibrate it to my spektrum radio. I geared it properly also and constantly kept a check on temps but the esc still croaked. Might have just been a defective unit from the factory IDK. Once I went hobbywing I never looked back. I use Hobbywing sct pro and xerun sensored 150A and rx8 escs with good luck so far.
MattP is offline   Reply With Quote
Old 06-22-2015, 07:46 AM   #1297
They are called air guards.... They are extra
Old 06-22-2015, 07:47 AM   #1298
Suspended
They are tekno air guards. They are not included. Less than $10 new I believe.
Old 06-22-2015, 08:38 AM   #1299
Does anyone know how each of these effects the truck? I've built emulsion and bladder but never vented.
Old 06-22-2015, 08:53 AM   #1300
Thanks guys.
Old 06-22-2015, 08:57 AM   #1301
Any suggestions on what body works good on the .3. Was thinking proline evo sc.
iibauti is offline   Reply With Quote
Old 06-22-2015, 10:56 AM   #1302
Need help please. I just got my kit the is the absolute first time building a rc in general. I'm at the front shock build but I made a mistake I was going for the vented build and drilled the vent for the top of the cap right but drilled the bleeder where it's supposed to be for the emulsion build. So my question is am I screwed or can I put the screw in and drill the other hole. If I can use that as my bleeder where do I find the oring for the bleeder screw. Also I saw a link somewhere of a step-by-step shock build for these could some one point me in the right direction please and thank you
apatz01 is offline   Reply With Quote
Old 06-22-2015, 11:35 AM   #1303
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Myself, and many others, use the emulsion hole as the bleeder hole so that we have the option to build the shocks either way. You are totally ok to just leave that hole unplugged and not drill the other one. Or you could plug it with the included screws and drill the other one.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 06-22-2015, 12:05 PM   #1304
Thanks and just so I'm understanding you right I will leave both the vent on top and the bleeder hole open right
Old 06-22-2015, 12:06 PM   #1305
Just the one on top would be my suggestion if you already drilled that hole.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
