    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 06-21-2015, 12:46 PM   #1246
Hoese37's Avatar
Originally Posted by MattP View Post
I see a lot are changing springs. Is the stock setup that far off? I'm fixing to build a new 410.3 for a buddy and want a decent starting point for him. I read about the stock springs not allowing for proper ride height. I was planning on compressing the springs overnight before assembly to allow them to be softer than stock. Any tips?
At this point I can get the front to 27mm with the kit springs. Might wanna pick up a set that is softer for the front, and firmer in the rear. Pinks all around would be a good choice.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-21-2015, 01:05 PM   #1247
Suspended
Trader Rating: 440 (99%+)
If I go with pink springs front and rear with the stock pistons what would be a good shock oil setup to start with? 35/30?
MattP is offline   Reply With Quote
Old 06-21-2015, 01:46 PM   #1248
Ahh just realized that tekno actually makes the Pistons I didn't know that. So less holes for bigger jumps more holes for smaller jumps I'm assuming
Dragonfueled is offline   Reply With Quote
Old 06-21-2015, 02:24 PM   #1249
Hoese37's Avatar
Theres a bit more to it than that. Its more about matching the pistons to the oil to the track. You need to look at piston surface area. The more area, the more pack.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-21-2015, 02:28 PM   #1250
Originally Posted by Cain View Post
+1 you change the pistons for the pack. the 10 x 1.2 pistons I never felt like I got enough pack from the version 1 and sounds like its still the case.
I would expect that the 10x1.2 pistons have more pack than the 6x1.5. Nearly the same free area and smaller holes => higher velocity of the fluid at same velocity of the piston => more pack. Am i wrong?
I would use the 6x1.5 on bumpy and/or low grip tracks (maybe the 6x1.6) and the 10x1,2 on smooth and/or high grip tracks.
T5M / B6 / F6 / RC8B3e
Uhudler is offline   Reply With Quote
Old 06-21-2015, 02:37 PM   #1251
Hoese37's Avatar
Surface area shown here is that of the holes. More area, less pack.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-21-2015, 03:05 PM   #1252
I'd give them a rebuild. should be smoother now.
Hey, does anyone know of a company that makes heatshrink tubing in the colors that tekno uses for spring designation? Got some truggy springs here and tekno's method of putting paint on the springs is hard for me to see at times since they are silver and it rubs off too. wouldn't mind using tubing instead like AE on the 1/10 stuff and Durango do for quick identification.
Cain i use finger nail polish on the rings to compress the spring an it also for how many times i turned it
Aswild is offline   Reply With Quote
Old 06-21-2015, 03:08 PM   #1253
Originally Posted by theboss13 View Post
Ok so I am looking at purchasing one of these as I currently have a pro4 enduro that I was given to get into the class. I had a few questions though, Would a castle 540 3800 4 pole 1410 motor and sct esc be enough power for this car? I saw the gearing chart and it said this Kv but I didn't know if it was for a 550. Also what servo would you recommend for it? I am looking for something On the cheaper side. Also would (with the aforementioned combo) a 5500 mah battery last 10 minutes? Lastly are there any problem areas with this car? This part may have been mentioned already but I did not see it.
Robby
I got the sct pro mamba combo there is a guy on here right now that has one for 160 including program cards i would jump all over. That
Old 06-21-2015, 03:17 PM   #1254
Originally Posted by Riflebuilder View Post
I'm running the Hobby wing Xerun SCT combo right now and I started having problems with the truck shutting down halfway in the race. I lowered the max voltage to setting 1 and it's still doing it. I just bought a Castle BEC to see if that will fix it, but been too wet lately. I ordered a RX8 Gen 2, I will try that.
Rifle there is some great deals to be had on here i thinks for the money of the rx8 u could get a better unit i have the sct mamba an it is great so far i just hooked it up to the cumputer and adjusted an man it really screens now ,an i striped the plastic servo horn out now after turning up the power ,do u build rifles buy chance as well
Old 06-21-2015, 03:54 PM   #1255
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
anyone using a staggered piston setup on this vehicle? (8 x 1.2 front / 8 x 1.3 rear for example)
Also, I heard a rumor about a special tekno clamping wrench with spots for 17mm and 12mm hex, ball ends, and shock shafts? Anyone heard of this?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 06-21-2015, 04:03 PM   #1256
What's a good servo for this car??
theboss13 is offline   Reply With Quote
Old 06-21-2015, 04:21 PM   #1257
Hoese37's Avatar
You mean this guy on the bottom? Nope nothing of the sort lol.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-21-2015, 04:21 PM   #1258
Tech Legend
Cain's Avatar
hitec servos are good like the HS7955TG, especially on 7.4V
Old 06-21-2015, 04:22 PM   #1259
Tech Legend
Cain's Avatar
yup! never went into the link all the way to see that lol
Old 06-21-2015, 04:24 PM   #1260
Hoese37's Avatar
Anything with 200oz and about .10 or less.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Tags
sct410, sct410.3, short course, short course 4x4, tekno
