    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 06-20-2015, 03:08 PM   #1231
Will the robotronics heavy duty servo arm work with this kit?
theboss13 is offline   Reply With Quote
Old 06-20-2015, 03:19 PM   #1232
Hoese37's Avatar
It will work, but youll need to shim the steering rod up on the servo saver end. The HB mount is a good one if youre on a budget. http://www.amain.com/rc-cars/hot-bod...s67169/p148908
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-20-2015, 07:28 PM   #1233
Originally Posted by ba4ma View Post
Hobbywing recently had a firmware update for their esc's that was supposed to help with this issue.i don't know if you are aware of this or not,but you might want to look into it.
Ok, great. Didn't know that. I will look it up and see how to do it. I'm almost done with the BEC install. I wonder if I should try that first strictly for troubleshooting sake.
Riflebuilder is offline   Reply With Quote
Old 06-20-2015, 07:53 PM   #1234
Trader Rating: 70 (100%+)
Default Countersunk holes?
Am I correct in assuming the screws going into te steering tubes, should be countersunk?
As you can see neither one is countersunk - just want to confirm before i contact Tekno.
Krafcik is offline   Reply With Quote
Old 06-20-2015, 08:11 PM   #1235
Yes, they are supposed to be countersunk.
ba4ma is offline   Reply With Quote
Old 06-20-2015, 08:13 PM   #1236
I would try the firmware update first.
Old 06-20-2015, 10:00 PM   #1237
Suspended
Trader Rating: 440 (99%+)
I see a lot are changing springs. Is the stock setup that far off? I'm fixing to build a new 410.3 for a buddy and want a decent starting point for him. I read about the stock springs not allowing for proper ride height. I was planning on compressing the springs overnight before assembly to allow them to be softer than stock. Any tips?
MattP is offline   Reply With Quote
Old 06-21-2015, 05:59 AM   #1238
I did buy the 6 x 1.6 pistons which allow for more resistance with the oil and piston, I'm running grey front with black springs and have 30 in the front and 27.5 in the rear. Been liking his set up for my track. 100'x200', bumpy, hard packed with dusty. Tight and technical. I wanted to have higher speed turning with chassis roll and this setup seems to work well. So I am afraid you will probably have to buy springs at least and play with different shock oil weights Pistons would come next.
Old 06-21-2015, 06:54 AM   #1239
Dan.J's Avatar
Trader Rating: 21 (100%+)
The stock setup is pretty decent on high grip indoor stuff, rear of truck is soft but seem's to work, I wen't to 27.5wt oil in rear as the stock weight is REALLY light. I'm using pink springs in front as the stock greens were a bit too stiff for me ( I STILL cant get proper ride height in front with no preload) Only changes I have made is a little heavier rear oil/Pink front springs/went out one hole from stock on the front tower/moved the rear hubs forward with the 2 big shims in rear and the single little shim in front.Truck is pretty good at this point but I feel it would be REALLY good if I could get the ride height right in front, guess I'm going to have to match up and pick out springs from another company to get things right as I have the same issue with my eb48sl but worse on that one cause its front and rear to high LOL
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 06-21-2015, 07:15 AM   #1240
Suspended
Thanks guys. I'll pick up some extra springs and oils.
Old 06-21-2015, 08:16 AM   #1241
What advantage does changing pistons have over thicker or thinner oils? Wouldnt an oil weight change be the same thing?
Dragonfueled is offline   Reply With Quote
Old 06-21-2015, 10:18 AM   #1242
Dragonfueled,
I'm pretty new as well and to be honest I bought them because a few people recommended them. Some complaints that are out there is how soft the suspension is. I think that with less oil flow with medium weight oil it handles better than more flow with heavier oil. I'm just playing around with different things and I truly do not know what the end effect is with the two. I know its working well for me and I had a few drivers run my truck at the last race and they were impressed with how well it was driving.
Mark
Old 06-21-2015, 11:00 AM   #1243
So what Pistons do you recommend? I'm building a basher so a little more dampening might be good.
Allready have allumimum hinge pin braces and diff pins. Just got alluminum servo horn.Trying to get all my basher parts before I build it.
Old 06-21-2015, 12:41 PM   #1244
Hoese37's Avatar
Oil changes how fast the piston moves through it. Piston effects how much pack there is in the shock. If you run a heavier oil, you may get enough the shocks firm enough for big jumps, but little bumps will upset the truck. Changing the piston will give you the pack for big jumps, but still allow low speed handling.
8x1.3 or 6x1.5 depending where you will run your shocks on the arm. Inner mount 8 hole, outer mount 6 hole.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-21-2015, 12:45 PM   #1245
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
+1 you change the pistons for the pack. the 10 x 1.2 pistons I never felt like I got enough pack from the version 1 and sounds like its still the case.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is online now   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
