    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 06-12-2015, 10:19 PM   #1141
youwish16's Avatar
Trader Rating: 19 (100%+)
Originally Posted by ktacket1 View Post
True that Jimmy Johnson.
Jimmie Johnson**
Allen Krier
Tekno ET48, Protek 130T, Tekin 2050kv, Tekin RX8 Gen2 ESC, James Tires
Tekno EB48.4, Protek 100T, Tekin 2050kv, Tekin RX8 Gen2 ESC, James Tires
Tekno NB48.3, Protek 100T, Protek 100SS, Werks B2, Dynamite Pipe, James Tires
youwish16 is offline   Reply With Quote
Old 06-13-2015, 01:46 AM   #1142
HSV427's Avatar
Trader Rating: 22 (96%+)
Originally Posted by Horby32 View Post
Finished building my kit and have put 4 packs through it so far. The only issue I'm having is the loose rear end. It seems to be very nervous in the high speed sections. I'm running on medium/large outdoor tracks.
Everything is stock except for the shock oil (25r 35f) vented
Where should I start on tuning?
I was thinking of starting with the easiest to change
1) camber links
2)adjusting my toe and camber
3) moving rear Hubs
4) thinking about going to pink springs all around
This will be my first attempt at tuning so any input would be appreciated
Thanks guys
As most people on here have mentioned to calm down the rear end i stood the shocks up 1 hole on the rear tower, mover the rear hubs all the way forward, and went 30w oil in the rear and now this thing is so planted even on a very loose and loamy track, try these few changes and i think you will be pleasantly surprised at the transformation.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 06-13-2015, 06:01 PM   #1143
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I always did run short wheelbase on my Tekno vehicles.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 06-13-2015, 08:47 PM   #1144
Dan.J's Avatar
Trader Rating: 21 (100%+)
Ran mine tonight with kit setup except changed out front springs to pink, still is couple MM higher in front than I want but truck was good.....not great but good. IMO the kit setup is REALLY close on medium sized/high bite indoor stuff, don't think its going to take to much to get it right where I want it. First race with this truck and finished 4th with 10 in the class, some pretty fast guys there too so all in all happy with the truck.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 06-14-2015, 10:13 AM   #1145
Hoese37's Avatar
1) camber links
3) moving rear Hubs
Thanks guys
Easiest thing to change is taking out the rear and center brace. Worked wonders on the V1 truck.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-14-2015, 07:23 PM   #1146
Barillms's Avatar
I built a 2nd one today. Took 8-9 hours, by hand, no power tools. Went well, no missing parts. Everything was spot on again. He went with the HobbyWing SCT Pro 4000kv combo... It's quite a nice set up. Works best paired with an 18t pinion I'm told. Ride height was again way off. 33mm with no battery. 28-29 with a battery.
Honestly, I wouldn't even bother using the oil that comes with the shocks... It's just way too thin. The back shocks will be almost unusable set up by the book. It's sooo insanely soft, I don't get it. Definitely not set up for outdoors. Not at all.
Great kit, but weird suspension set up.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 06-14-2015, 07:24 PM   #1147
Barillms's Avatar
I took out my rear brace, not sure I noticed anything. What exactly is this supposed to do?
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 06-14-2015, 08:24 PM   #1148
Dan.J's Avatar
Give more flex in the chassis, should increase rear grip. As far as the kit setup goes......I can see where it may be wrong for big outdoor stuff but its pretty darn close on indoor high bite. I used the kit oils and stock setup in rear and was surprised how well it worked. I went with pink springs up front which was better for me but I'm still higher in front than I want and am still confused why some can get low up front and others cant, and yes my stuff is very free and working right and been ran plenty to "settle" the springs and I have squeezed the shit out of them before installing My EB48sl with kit setup still is sitting to high front and rear as well
Old 06-14-2015, 08:44 PM   #1149
looking for a small pin tire to use on my sct410.3. holeshots work during the day, the outdoor track gets tacky, loamy after sunset.
Brandon Powell is offline   Reply With Quote
Old 06-14-2015, 08:53 PM   #1150
FastPete's Avatar
Trader Rating: 44 (100%+)
Gridirons I heard work well.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 06-15-2015, 01:31 AM   #1151
Hoese37's Avatar
City Blocks or Goosebumps.
Not sure how often you need to be reminded that the kit setup was made for smaller high grip indoor tracks. This would explain the "weird shock setup".
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-15-2015, 05:51 AM   #1152
The caliber sc2.0
Aswild is offline   Reply With Quote
Old 06-15-2015, 08:39 AM   #1153
It is weird that some are still sitting high. I prob ran mine 4 weekends before I remembered to recheck the ride height and this time I was able to get the ride height. Initially thought I wasn't then remembered I didn't have the battery installed.
Finally got pinks on it all around then motor blew out on me 1st heat this weekend. Oh well, it lasted 2.5 years so no complaints.
qstorm777 is offline   Reply With Quote
Old 06-15-2015, 08:57 AM   #1154
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Is there a driver setup out now that is truly for big 1/8 tracks that is loose in conditions and rough?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 06-15-2015, 10:48 AM   #1155
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Originally Posted by qstorm777 View Post
I've been looking at that motor for a while. However, I have a Tekin esc. I really want the data logging, especially the temps, but it seems like when i mix brands, the motor log data may not be correct. Do you know if the RX8 Gen2 accurately displays this motor's data?
Also, I'm wondering what kind of run times it will get? I have a tekin 4300 pro4 hd with 18 tooth pinion, 6000mah smc battery and I can finish a 10min main with no problems. Believe I had about 3.6V per cell left. Please let me know if you have any info on that.
Thanks.
Used the motor with the Tekin Rx8v2 last weekend. Pinion 14, about 28C, sunny, outside, short, high grip carpet track, runtime: 6min, motor is getting hotter than the other ones, about 50C-60C. Used about 2500mah (fast drivers took about 4000mah.
I do not knew about the logging function of the controller, bougt it from a friend. Have to do some research for that.
This was the first time of a full race weekend with the car. Reduced the back toe-in for better landing after high jumps. (Car overcorrected direktion on landings wich were not perfectly straigt.)
Jumps are still a bit difficult, but with absolutly no breaking or reducing power while flying, it was ok.
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
