    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 06-10-2015, 01:39 PM   #1096
Originally Posted by apatz01 View Post
I'm about to order this kit and was wondering if anyone knew of build sheets or could help me. I'm extremely new to this hobby and have never built a kit. What parts could you recommend. I get discounts with tekin and Tekno both. Any help would be appreciated.
I'm also fairly new to the hobby and just finished my 410.3 build. I was very impressed with the instruction and had no issues with the build. The only upgrades I did right away was the the aluminium servo horn and air guards. I'm running the stock wheel hexes and have had no issues. Just be careful not to over tighten them.
If you get a discount on tekin I would say go with the rx8 prohd 4300 combo.
Horby32 is offline   Reply With Quote
Old 06-10-2015, 01:44 PM   #1097
I can't seem to find instructions on how to measure droop. Hoping someone can run me through the procedure.
Thx guys
Old 06-10-2015, 02:03 PM   #1098
Hoese37's Avatar
The way the Tekno setups measure it is by the length of the shock when extended from the lower bolt to the upper nut.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-10-2015, 02:28 PM   #1099
Carter Flotron's Avatar
Thx guys
Just so there isn't confusion, it's the center of the shock standoff/nut to the center of the lower shock screw. Not the ends of each.
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 06-10-2015, 03:31 PM   #1100
This is what I'm look at right now
Hw pro sct
Tekin pro4 4300kv
Savox sc 1256tg
Also getting a 13,15,17 pinion gear
How's that look
apatz01 is offline   Reply With Quote
Old 06-10-2015, 03:36 PM   #1101
Lowe's48's Avatar
Hw pro sct
Tekin pro4 4300kv
Savox sc 1256tg
How's that look
If anyone looking for a Tekin Rx8 gen2 used 4 times pls pm me.
Lowe's48 is offline   Reply With Quote
Old 06-10-2015, 04:00 PM   #1102
celt's Avatar
As others have stated, download and read the manual.
Develop strong forearm muscles, the SCT410.3 is a beast of a kit. It's not like any 1/10 scale kit you're likely to ever see.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 06-10-2015, 04:02 PM   #1103
Hw pro sct
Tekin pro4 4300kv
Savox sc 1256tg
How's that look
If you are getting the HW SCT Pro get the 3656SD 4000kv HW motor or the 4700kv if you want to go totally nuts with the power. 18 pinion on the 4000kv.
Tijuana_Taxi is offline   Reply With Quote
Old 06-10-2015, 04:07 PM   #1104
TheCore's Avatar
Trader Rating: 45 (100%+)
Originally Posted by celt View Post
Develop strong forearm muscles...
one of these helps alot
TheCore is offline   Reply With Quote
Old 06-10-2015, 04:36 PM   #1105
Correct me if I'm wrong but I was told the tekin motor would be better that the hobby wing
Old 06-10-2015, 04:37 PM   #1106
Can confirm. The ladies get a little weirded out when you look like Popeye.
Old 06-10-2015, 04:45 PM   #1107
There is nothing wrong with either motor but personally I run a HW, for the money I don't believe they can be beat. I also have a Tekin but it sits in my box as a spare.
Old 06-10-2015, 04:49 PM   #1108
Thanks sorry for the noob questions but I'm a complete noob. Just don't want to spend money twice because of a name
Old 06-10-2015, 04:56 PM   #1109
Hw pro sct
Tekin pro4 4300kv
Savox sc 1256tg
How's that look
Don't order the 13t pinion It won't fit, tekno confirmed the smallest that will fit is the 14t
Old 06-10-2015, 05:00 PM   #1110
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
The Hobbywing 4000Kv motor is quite versatile in the truck. Works great on small and large tracks when geared appropriately and runs very cool.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
