    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 – V2 Adjustable Hinge Pin Brace “A” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 – V2 Adjustable Hinge Pin Brace “C” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B – HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 – Hinge Pins (inner, front/rear)
TKR5516 – Front Suspension Arms and TKR5515 – Rear Suspension Arms
TKR5542 – Spindle Carriers - TKR5541B Spindles
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 03-23-2015, 09:20 PM   #91
TheCore's Avatar
Trader Rating: 45 (100%+)
the j concepts f250 body might do what you're looking for
TheCore is offline   Reply With Quote
Old 03-23-2015, 09:30 PM   #92
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I agree.................this body jumps very well due to the angled cut outs in the rear, it acts like a wing. I just picked up another one.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 03-23-2015, 10:17 PM   #93
Wow, that is pretty much exactly what I had in mind. I think I'll be ordering one of those to try.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 03-24-2015, 01:52 AM   #94
nanoverse's Avatar
The longest lasting body I have owned. Whole year worth of racing.
The only thing I don't like is the side portrutions because tires rub against it. The body would be perfect with more clearance on the sides and the ass little shorter for the Tekno.
HB E817 | HB D815e | HB D413
Hitec Lynx 4s
nanoverse is offline   Reply With Quote
Old 03-24-2015, 05:42 AM   #95
Mikeand22's Avatar
Trader Rating: 25 (100%+)
I was wondering if anyone was using shorty packs in their SCT's or using standard size packs? Thanks
Mikeand22 is offline   Reply With Quote
Old 03-24-2015, 05:46 AM   #96
TheCore's Avatar
i have one painted up and ready to go too. i've been really digging the evo body this year, but threw one of these into the pile i painted over the winter to see if i can tell the difference..
Old 03-24-2015, 05:51 AM   #97
Motorman007's Avatar
Trader Rating: 78 (100%+)
Anyone have a photo of a truck with a wing please?
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 03-24-2015, 06:03 AM   #98
nanoverse's Avatar
It was Neumann or Hönigl at a EOS-race who used one with a Durango. But they disallowed it or something.
Don't know what the the comment by Mathew was to imply. That the nose down issue (which I never had) is remedied by a wing?
If Tekno would have thought that a better balance is achieved by putting the battery back they would have changed it in the .3. It was one of the first things I checked when they had pics out.
Also what's interesting is that the new setup sheet has lower rate springs again (thank god).
Hitec Lynx 4s
Old 03-24-2015, 07:18 AM   #99
I believe a wing could make a big difference as long as it's positioned in the air stream. The first time I took my D413 to the track I didn't have the wing cut out so I dropped it on the track and took off without it. It was nosing over very similar to what my SCT410 does if I try to drive it "normal". As soon as I put the wing on that went away.
I had never really thought much about the wings on my buggies before that. Pretty much just installed them when I built the kits and then forgot about them.
-Chris
Hot Bodies D413
AE B5M, T5M
Old 03-24-2015, 07:36 AM   #100
Jtipsy's Avatar
I ran a wing a few times at the track on my sct410 with the evo body was better, went through entire truck freed up my suspension and changed over to delrin inserts single oring and delrin pistons and the truck was 100 different truck. Make sure your suspension is free moving. Helped me a ton.
Joseph Tuepker
Jtipsy is offline   Reply With Quote
Old 03-24-2015, 07:54 AM   #101
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
... If Tekno would have thought that a better balance is achieved by putting the battery back they would have changed it in the .3. It was one of the first things I checked when they had pics out.
If referring specifically to the nose down problem, Tekno may not necessarily change the battery tray if the mod doesn't cost you anything to do versus them redoing the mold for the battery tray.
Tekno reps themselves will mention modifying the battery tray concerning the nose down issue to move the battery back to help with the problem.
Part of it also could be relative to how often its seen, and who knows, maybe this new suspension geometry will help things as to me, its more of an issue on tracks where the common fixes cause traction issues due to the stiffness of the springs.
But if tekno ever decides to revise the tray so you can have that full range, i'll get it.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-24-2015, 09:05 AM   #102
Thanks for the insight sir.
Old 03-24-2015, 09:08 AM   #103
Do the wing needs to be straight up and down like the 2nd photo? or a angle?
Old 03-24-2015, 10:35 AM   #104
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
I'm currently running shorties, but my truck weighs just under 6lbs RTR.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 03-24-2015, 10:38 AM   #105
lford's Avatar
+1 on the JC F250 body I have been using it since it came out. Very durable and the rear wing really makes a difference.
lford is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
