    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 05-27-2015, 10:33 AM   #961
FastPete's Avatar
Trader Rating: 44 (100%+)
Great job. And great looking rides.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-27-2015, 11:27 AM   #962
Originally Posted by kyleman7 View Post
for a 1/8 motor you will need the regular non-lcg style motor mount insert
Good to know thx
Horby32 is offline   Reply With Quote
Old 05-27-2015, 12:56 PM   #963
Lowe's48's Avatar
😆thx
Lowe's48 is offline   Reply With Quote
Old 05-27-2015, 02:11 PM   #964
Lowe's48's Avatar
Here you go you video hungry people! ! Starting on the pole is a .3
Enjoy...
https://www.youtube.com/watch?v=WgzbwdcUQSs
Old 05-27-2015, 06:12 PM   #965
Terra Rover's Avatar
Anyone have any issues with gear mesh? I put a 15t mod1 pinion in my new SCT410.3 and couldn't get a close gear mesh. I thought that it might be the motor getting in the way of the mount, so I shimmed the motor a little and that did not help. The mesh is so loose that I stripped out the spur gear. Almost seems that either the kit needs to be have a 17t pinion or higher or I have a machining issue with my mount.
Steven "GUNZ" Taylor
Tekno SCT410.3, Team Associated RC10B5M, Airtronics MT-4
Terra Rover is offline   Reply With Quote
Old 05-27-2015, 06:52 PM   #966
Dan.J's Avatar
Trader Rating: 21 (100%+)
Taking my time and building a 410.3 and EB48sl at the same time in my free time(which is minimal right now) I am about 75% built on both kits, impressed with the fitment and builds in general so far, these are my first Tekno builds. Nice job on the kits TeknoRc.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 05-27-2015, 08:29 PM   #967
TheCore's Avatar
Trader Rating: 45 (100%+)
what motor are you using ?
TheCore is offline   Reply With Quote
Old 05-28-2015, 03:14 AM   #968
justpoet's Avatar
Trader Rating: 16 (100%+)
I'm running a 16t on mine with no issue, and it can definitely go to no play at all with that size on it. A 15t should work no problem, and some are running 14t as well, though I believe they may have the normal lightened motor mount instead of the LCG one.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 05-28-2015, 03:20 AM   #969
justpoet's Avatar
I spent some time on the weekend shaking the SCT410.3 down and comparing it to my original SCT410, then working on setup. Out of the box it is better than the original was out of the box, but not as good (to me) as my old setup was. The box stock setup is VERY stable under heavy braking, but has TONS of on power steering. Some folks will love that, but I like to turn on brake and have stability on throttle. I've been working on the setup a bit, and while I don't think it is quite there yet, it is getting close. To show some of what it can do, here's the SCT410.3, starting on the pole in yellow. There were certainly a few purposeful crashes in there, such as going tumbling at the end of the straight, as I was trying to push past the limits to find where they were compared to the old truck (in that case, how much can I cary into and through the corner). Anyway, here's tonight's race video of where the performance is now (medium bite indoor damp dirt/clay mix, packed).
+ YouTube Video
Old 05-28-2015, 04:49 AM   #970
I am using the HobbyWing 4000kv 4-pole XERUN SCT motor.
Old 05-28-2015, 05:19 AM   #971
TheCore's Avatar
are the cooling fins rubbing the chassis ?
the lcg mount says it's not compatible with motors over 36mm in diameter, the hw 3656 motors are 38mm at the fins.
Old 05-28-2015, 06:01 AM   #972
Originally Posted by TheCore View Post
they don't go all the way thru, only half the length of the set screw. they've held great so far, altho the truck hasn't seen much abuse. the screws have a tendency to pull out (based on having them on my slash 4x4s) which is why i made a couple spares. the tekno plastic isn't as flexible as the proline plastic so they should hold better.
i don't remember if the set screws are 2.5 or 3mm. i probably just dug thru my bit box for something that was a tad smaller than the screw, then marked it at 1/2 the length for depth.
Shark's original post at rcshortcourse when he used the proline caps.
lol, my badlands... <3
I used the apoxy. In a tube an put some in each hole then put the post in ,it's like it was made like that no issuies
Aswild is offline   Reply With Quote
Old 05-28-2015, 06:18 AM   #973
I have put a 13T on an i have a 3800 kv 4 pole an i have it pushed all the way down an the mesh is paper gap but it does not go any further either, so I will have to see how this works and go with a deferent pinion later if this is to small ,i did look down the side of the can were the brace holds the center diff an i can see a hair of lite so i no it's not touching ,,
Old 05-28-2015, 06:19 AM   #974
I have a brand new kit I would be willing to sell. PM me if interested.
jb19 is offline   Reply With Quote
Old 05-28-2015, 06:49 AM   #975
I have the same motor and my first run I had the 15T on it and meshed it with room to spare on the complete stock mount. Not sure what might be wrong? Can you post a picture?
louie8269 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
