    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 05-23-2015, 09:46 PM   #916
Guch's Avatar
Originally Posted by Hoese37 View Post
Judging by the sponsors, Id guess its Sean Ramos.
Yep, your correct. Another local racer comfirmed. Thanks
22 3.0,Orion R10/DPS 7.5,Orion 4600 shorty, Airtronics M12,Spektrum S6270
SCT410.3,RX8.2/Pro4 4600,XP DS1015,SMC 7200
If guns are ever outlawed, then I'll be an outlaw!
Guch is offline   Reply With Quote
Old 05-24-2015, 12:38 AM   #917
HSV427's Avatar
Trader Rating: 22 (96%+)
Does any one no if the tekin pro4 4600kv 540 can motor would push this sct around ok or should i get the pro4 hd 4300kv 550 can. If someone has tried both please weigh in your advise or anyones for that matter would be greatly appreciated. TIA
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 05-24-2015, 06:36 AM   #918
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
The 4600 is more than enough and much easier on drive train and batteries. My son runs the Hobbywing 4000 in his turned down just a titch (he's a pretty good driver) and I was running the Viper 4500 in mine when I was still in the class. The Viper was a beast. For many moons, I ran the Tekin Pro4 4000 with good success. The 4300 HD is not ROAR legal if that matters to you.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 05-24-2015, 07:43 AM   #919
Dan.J's Avatar
Trader Rating: 21 (100%+)
I posted in the EB48SL thread but as I'm building 410.3 too thought I would put it here as well being both threads seem to get different visitors,
In the process of putting my EB48sl and 410.3 together at the same time, these are my first Tekno builds other then helping buddies on occasion. Anyway all 4 front and rear diffs seem to want to go in the housings with only one shim on the gear side of housing for best mesh, both on gear side and it is too tight and one on each side doesn't feel right either, once in the housing and tightened up they feel pretty smooth for being new so I'm guessing I'm OK? Both center diffs feel crunchy when fully tight, back off screws just a touch (like half turn) and they both free up......normal? Also noticed when the droop screws are put in the arms all the way that it tightened up the hinge pins on the arms and had to ream the arms some more to get free movement. Just looking for some clarification that I'm going about everything in the right way being my first Tekno's. The kits seem quality and I'm happy so far just trying to learn them. Thanks
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 05-24-2015, 09:38 AM   #920
Everything you just posted is pretty normal for the Tekno kits.I have a 410,410.3,and eb48sl and on my rear and front diffs on my 410 I had to put one shim on each side.On my 410.3 and eb48sl both shims went right in on the gear side with no problems.
ba4ma is offline   Reply With Quote
Old 05-24-2015, 04:04 PM   #921
Orion_2kTC's Avatar
This weekend I noticed that when I'm at a hard steering point my wheels are rubbing so I had to back off my EPA to make sure it didn't. Everything appears tight but I lost a TON of steering since I had to make such drastic changes to my EPA. What can I look for that may fix this?
Orion_2kTC is offline   Reply With Quote
Old 05-24-2015, 04:49 PM   #922
FastPete's Avatar
Trader Rating: 44 (100%+)
What wheels? Rubbing the arms? Pics
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-24-2015, 04:51 PM   #923
Hoese37's Avatar
Preferred the 540 over the 550. You get better runtime, more top end, and don't ruin your batteries.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 05-24-2015, 06:48 PM   #924
Orion_2kTC's Avatar
Yeah rubbing the arms. I can't post pics right now but I will when I can
Old 05-24-2015, 09:33 PM   #925
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Set your steering stops so they barely miss rubbing the arms.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 05-25-2015, 08:02 AM   #926
Do you guys think the new truck is that much better than the old one?
Danny "Ricky Bobby" Reddish
Owner of The Onionpatch Raceway
Whooo Hoooo
reddishdsb is offline   Reply With Quote
Old 05-25-2015, 12:34 PM   #927
edonsohc's Avatar
I've got two races in the new .3 truck. truck is great in box stock form. took the tq and win at our local Friday racing track. went to a bigger event on a bigger 1/8 track and truck was just as good. was running in 2nd place when my hw sct pro went into thermal. its done this a few times now. esc is not hot. hottest temp I could find on it was 103. anyone else have this issue? I'm running the 4700 motor with a 16t pinion. motor is coming off at 140 max. usually only 130F. fan is working on the esc too. really bummed about the esc. I thought it was made for applications like this? oh, and battery is a brand new smc 7200.
the first version truck was good box stock. this one is better box stock. my .02
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
Old 05-25-2015, 12:40 PM   #928
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
are you sure its thermaling?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 05-25-2015, 01:30 PM   #929
It is not thermalling, the LVC is coming on tok soon. The latest software fixes that. It also makes it so when LVC does hit, you can still crawl out of the way instead of a sitting duck.
Everybody79x is offline   Reply With Quote
Old 05-25-2015, 04:49 PM   #930
edonsohc's Avatar
was a slow blinking green led. I believe that is thermal.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Importnites187
