    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 04-29-2015, 04:22 AM   #601
Stock setup till I have tried it out and see how she handles, stock is probably not far off for most anyway I would imagine.
justingt5 is offline   Reply With Quote
Old 04-29-2015, 05:34 AM   #602
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I put yellow fronts on mine, I was running at a loose track and wanted a little less steering.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-29-2015, 05:36 AM   #603
nanoverse's Avatar
Why is the front so hard when the rear is really soft? Was the stock setup made for what conditions? Also it's impossible to get stock front height with stock springs.
First front plastic brace snapped from friend when the .1 would just have continued. Now with the pills much bigger the front brace will get a beating.
nanoverse is offline   Reply With Quote
Old 04-29-2015, 11:57 AM   #604
Orion_2kTC's Avatar
Orion_2kTC is offline   Reply With Quote
Old 04-29-2015, 01:33 PM   #605
Jordan Anderson's Avatar
For the most part, I've been really impressed with how most of the parts seem very "heavy duty" on this truck so far. Overall, it has a very 1/8 feel to it (arms, chassis, shocks) compared to other 1/10 cars.
That said, the CVA couplers sure seem tiny. Also, the new '4mm' camber links and 4mm rod ends sure look small when compared to a 5mm Lunsford link with the old SCT410 5mm rod ends.
Guess we'll see how the new parts hold up once more of these hit the dirt.
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-29-2015, 02:54 PM   #606
lala4fire's Avatar
AMAIN HAS sct410.3 in stock. Hurry while they last
Associated FT SC10.2 SCB/ tekin rs/gen2 10.5
Associated B6/ tekin rs 2/gen3 8.5 B5 rear motor
Tekno EB48.4/tekin rx8 2/gen2 1900kv
Tekno NB48.4/ Alpha Dragon III
HB D413/tekin rsx/gen3 6.5
lala4fire is offline   Reply With Quote
Old 04-29-2015, 03:21 PM   #607
Trader Rating: 19 (100%+)
tower is showing instock: limited quantities too. Better mean my back order is going to get fulfilled!
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-29-2015, 03:57 PM   #608
If you had backordered when they had the -$60 code, you can cancel it and buy it again now with the -$70 code.
PetRock is offline   Reply With Quote
Old 04-29-2015, 03:58 PM   #609
Hoese37's Avatar
Originally Posted by ba4ma View Post
What shock spring combos are some of you guys running?
I ran the stock Green/Black and it worked great. Some have already been testing with good results grey springs.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 04-29-2015, 04:15 PM   #610
I'm afraid if I do that it will delay my order even further.
Old 04-29-2015, 06:05 PM   #611
Trader Rating: 32 (100%+)
I just got one in towerhobbies with $70.00 OFF . Now status in towerhobbies early May.
raved007 is offline   Reply With Quote
Old 04-29-2015, 09:56 PM   #612
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
heck if they had been in stock last week could have gotten E-cash too.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 04-30-2015, 04:42 AM   #613
From what I have read there are plans for CVD`s in the near future. The new rear hubs description say compatible with CVD`s and universals. As far as the smaller links I don't think there is going to be a problem.
Old 04-30-2015, 09:02 AM   #614
Orion_2kTC's Avatar
I'm thinking of giving Proline or AKA tires/wheels a shot. I had to grind the ribs of my JConcepts +3 Hazards so they wouldn't rub on the rear suspension. Did anyone notice a grind/rub with AKA or Proline wheels?
Old 04-30-2015, 09:04 AM   #615
They won't rub if you get the wheels for Losi SCTE. I have all three plus the DE Racing on my Tekno SCT.
qstorm777 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
