    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 03-19-2015, 09:38 PM   #46
You know if i ever find time i might have to try that
mikeinsocal is offline   Reply With Quote
Old 03-20-2015, 06:52 AM   #47
So will Tekno offer a complete .3 update kit? I'm not a hardcore racer but I like to try to stay up to date on my trucks.
Exojoe is offline   Reply With Quote
Old 03-20-2015, 08:27 AM   #48
cpt_RedBeard's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to cpt_RedBeard
Originally Posted by TheCore View Post
if the front and rear hubs are replaced then the arms will need to be replaced as well due to the new hub length ?
it also appears different rod ends are also used and all the link lengths are different than the original, are the new rod ends needed as well and how would this relate relate to the geometry of the 1st gen towers ?
i can see this being a problem as time goes on and various parts get upgraded and others don't and people saying their trucks are out of whack when they're build assumingly correct.
example.. i'm not willing to replace my carbon towers, but would like the new arms and hubs what are my new link lengths and what locations become the "box stock" starting points ?
The new rear arms are 4mm longer. The new hubs are designed to accommodate that. As for the front I'm not sure, but I wouldn't mix and match, because the Tekno design team did the homework and designed this new package to be with out a doubt better. If it wasn't it wouldn't of made it this far in the process.
The rod are different. If memory serves me correctly one set of them is longer than the old ones, but its a stretch to remember I may not be correct. I do know the ends are straight now, but the old ones would still work. Again, if it wasn't better it would have been scrapped in the process.
The last two paragraphs I can't answer, sorry.
Originally Posted by jmkalt View Post
So, in a nutshell, regarding the new suspension geometry, how will the new truck drive compared to the old one? In other words, what does the change do to the handling?
Better!
But seriously the new geometry provides a more efficient suspension stroke. The new truck's design promotes greater corner speed and better overall suspension performance (lands like its on a pillow).
Tekin | AKA | PT RC Racing Oils
cpt_RedBeard is offline   Reply With Quote
Old 03-20-2015, 08:45 AM   #49
Motorman007's Avatar
Trader Rating: 78 (100%+)
Better!
Thanx Cpt.
I say buy new. sell the old model or give it to your kid. if you don't have a kid use it as a loner for the track for a new person.
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 03-20-2015, 09:56 AM   #50
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
hmm, I wouldn't be surprised they don't personally.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-20-2015, 10:31 AM   #51
Can someone post Tower Hobbies coupon code please?
losi b is offline   Reply With Quote
Old 03-20-2015, 10:55 AM   #52
014JA SAVE $10 on a $49.00 order 31-Mar-2015
014JB SAVE $15 on a $79.00 order 31-Mar-2015
014JC SAVE $25 on a $149.00 order 31-Mar-2015
014JD SAVE $35 on a $225.00 order 31-Mar-2015
014JE SAVE $45 on a $289.00 order 31-Mar-2015
014JF SAVE $60 on a $379.00 order 31-Mar-2015
014JG SAVE $75 on a $475.00 order 31-Mar-2015
014JJ SAVE $115 on a $719.00 order 31-Mar-2015
014JK SAVE $130 on a $799.00 order 31-Mar-2015
Old 03-20-2015, 11:03 AM   #53
Tech Legend
Cain's Avatar
thats the one I have. Some members though get even better ones. You may want to check your member account you can see it there.
Old 03-20-2015, 11:16 AM   #54
jmackani's Avatar
Trader Rating: 14 (100%+)
Maybe I am the only that thinks this, but the biggest advantage this truck brought to the game was the added weight. I never had issues with bumps and I have run on quite a few large rough outdoor tracks. The nose down issue is inherent in just about every 4wd sct. Lighter weight is only going to help on the high traction type tracks coming out of the corners. If the tires are spinning, it's not going to help much. I have been running Tyler Herwigs setup from the ROAR Nats for over a year and the truck has been great if people are looking for ideas on shocks and diffs.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 03-20-2015, 11:21 AM   #55
Jakesterama's Avatar
Trader Rating: 67 (100%+)
You can always add weight (and in the exact areas you want it). It is hard to add lightness.
Just preordered mine!! Can't wait. Class seems to be big in Central MN, and growing, with a couple of really fast guys running it.
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 03-20-2015, 11:30 AM   #56
510YA SAVE $80 on a $500.00 order 31-Mar-2015
510YB SAVE $100 on a $625.00 order 31-Mar-2015
510YC SAVE $120 on a $750.00 order 31-Mar-2015
510YD SAVE $160 on a 1000.00 order 31-Mar-2015
510YE SAVE $180 on a 1125.00 order 31-Mar-2015
510YF SAVE $200 on a 1250.00 order 31-Mar-2015
510YG SAVE $240 on a 1400.00 order 31-Mar-2015
510YH SAVE $280 on a 1650.00 order 31-Mar-2015
510YJ SAVE $320 on a 1760.00 order 31-Mar-2015
510YK SAVE $360 on a 2100.00 order 31-Mar-2015
510YL SAVE $400 on a 2350.00 order 31-Mar-2015
510YM SAVE $600 on a 3500.00 order 31-Mar-2015
Old 03-20-2015, 11:48 AM   #57
jmackani's Avatar
Partially true. The weight reduction in the drivetrain components is not a simple add weight change. This does really affect the power delivery and with the high powered motors today, lighter in the drive train is not always better when it comes to being usable.
Old 03-20-2015, 11:55 AM   #58
Tech Legend
Cain's Avatar
for the me the kicker on the V1 was that out here, areas of the track guys could punch it on consistently over jumps, Iwould get a bad nose down situation, and the truck didn't feel consistent on traction relative to what I did for nose down attitude.
However, I will say I don't get to race much, so my tuning time comes in these windows with the track being over 1.5 hrs away.
This year though should be interesting as the guy who cleaned up last year now has tekno vehicles
Old 03-20-2015, 11:59 AM   #59
jmackani's Avatar
Push control (tekin) in the speed controller is the simpliest fix for the nose down issue. A lot of guys chase this problem with springs but I believe it's more related to the mod 1 gears. I have run just about every 4wd SCT and the only one that did not show this characteristic was a durango that I switched to 48 pitch gears. When running the mod 1 the truck did the same as all the others.
Old 03-20-2015, 12:03 PM   #60
Push control?
i have a viper what setting is that?
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
