    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree84Likes
Old 04-26-2015, 08:08 AM   #556
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Originally Posted by Brandon Powell View Post
You may find this of helpful. If you already have a lightened chassis. ... I think you can select the drop down and ad additional .3 items.
http://www.fiercercsolutions.com/Tek...ecs-FRC005.htm
for the extra items in the drop down, how do you select more than one item?
great option by the way, very nice touch Pete!
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 04-26-2015, 08:28 AM   #557
Trader Rating: 19 (100%+)
I know the goal was to give a package discount on the base change of the geometry. I was unable to select more than 1 when I tested it. Maybe Pete can chime in and explain....
Brandon Powell is offline   Reply With Quote
Old 04-26-2015, 08:51 AM   #558
I may take advantage of this. Nice to see someone taking care of the V1 guys. How long will this upgrade package be available? I really would like to hear some reviews on how the new geometry changes the way this truck handles, before I make the changes.
red100076 is offline   Reply With Quote
Old 04-26-2015, 09:15 AM   #559
Guch's Avatar
When will we see a .3 machined gun metal anodize or carbon fiber version of the shock towers? I have the v1 front 5mm carbon one and have broke two of the rear 4mm carbon ones. I switched to the machined rear one and have found it to hold up the best. Is there a .3 5mm carbon rear tower coming? My rear v1 carbon towers always break at the two unused holes in the middle of the tower.
22 3.0,Orion R10/DPS 7.5,Orion 4600 shorty, Airtronics M12,Spektrum S6270
SCT410.3,RX8.2/Pro4 4600,XP DS1015,SMC 7200
If guns are ever outlawed, then I'll be an outlaw!
Guch is offline   Reply With Quote
Old 04-26-2015, 09:23 AM   #560
Tech Legend
Cain's Avatar
Originally Posted by Guch View Post
When will we see a machined gun metal anodize version of the shock towers?
assuming the future EB48 (EB48.3?) uses the same towers, I wouldn't be surprised it comes out closer to them.
M2C is making a version of there 17mm hexes for the bigger axle setup that the SCT410.3 uses
Old 04-26-2015, 11:29 AM   #561
FastPete's Avatar
Trader Rating: 44 (100%+)
Thanks for the questions. The software I use for my site you cant pick more than one of each from the drop down.. But shouldn't need to the way it was figured, the outdrives are three sets of two, etc. Anything that needed more than one package was figured out that way. Now if I missed something highly possible Please fell free to let me know.
The sprit of the upgrade isn't to get a bunch of spares discounted. This is for someone upgrading.
Now if you see something I missed please let me know. I am a reasonable guy, if theres something you need extra at the same time, feel free to PM me or shoot me a email and we can discuss
How long will this go on. Well I have no plans to end it anytime soon. Some people are in to deep with their 410 (Like Me).
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 04-26-2015, 11:30 AM   #562
FastPete's Avatar
Towers will be coming in the future.
Old 04-26-2015, 11:51 AM   #563
Orion_2kTC's Avatar
I appreciate the comment, but I decided to keep the ESC orientation as is. I have to redo the bullet connectors but here's the final product.
Orion_2kTC is offline   Reply With Quote
Old 04-26-2015, 01:20 PM   #564
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Just finished!
Took a short testdrive in the backyard, very impressive power of the Tenshock 4600kv! Should try this in my old SC10 4x4, maybe changes it into a rocket. (used the LRP X12L 5.5 and 4.5 until now)
Car rolls very smooth, gear mesh in the diffs are perfekt, hope to test it on the next-by clay-track.
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 04-26-2015, 02:39 PM   #565
lala4fire's Avatar
Turn the battery around to run shorter battery wires.
Associated FT SC10.2 SCB/ tekin rs/gen2 10.5
Associated B6/ tekin rs 2/gen3 8.5 B5 rear motor
Tekno EB48.4/tekin rx8 2/gen2 1900kv
Tekno NB48.4/ Alpha Dragon III
HB D413/tekin rsx/gen3 6.5
lala4fire is offline   Reply With Quote
Old 04-26-2015, 03:43 PM   #566
Tech Legend
Cain's Avatar
I personally don't like to run the connector ports in the forward position due to issues some lipos had with impact damage affecting the wiring inside the pack. Some batteries are more prone to this from lawn darting. That doesn't mean if you land butt end all the time you won't have problems, but I recall issues in that configuration so run my in the same orientation.
Old 04-26-2015, 04:10 PM   #567
Good tip right there. I didn't think of that. Thank you sir!
Tekno eb48.2
Tekno sct410.3
one8updragracer is offline   Reply With Quote
Old 04-26-2015, 04:51 PM   #568
Trader Rating: 32 (100%+)
Do you guy prefer inboard battery connector or dean? I'm thinking inboard too because i got my first experience landing hard my SCT410 and it was disconnected battery.
raved007 is offline   Reply With Quote
Old 04-26-2015, 04:52 PM   #569
Originally Posted by raved007 View Post
Do you guy prefer inboard battery connector or dean? I'm thinking inboard too because i got my first experience landing hard my SCT410 and it was disconnected battery dean connected.
I go against the flow and use traxxas connectors
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-26-2015, 05:23 PM   #570
cpt_RedBeard's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to cpt_RedBeard
+1 Traxxas are the only connectors I've never had fail or come unplugged
Tekin | AKA | PT RC Racing Oils
cpt_RedBeard is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
