    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 04-25-2015, 01:41 PM   #541
Trader Rating: 32 (100%+)
Originally Posted by trojanjoe1 View Post
so how do you go about selling on this site. just received my 410.3 , but might sell it now. also picked up the new b5m lite. n trying to figure out which I want to keep now.
If sell your 410.3 i am interested but let me know how much you gonna sell.
raved007 is offline   Reply With Quote
Old 04-25-2015, 02:13 PM   #542
[/URL][/URL]
Here is a pic of my 410.3 withe the esc posts turned toward the servo
ba4ma is offline   Reply With Quote
Old 04-25-2015, 02:33 PM   #543
Originally Posted by losi b View Post
I've been trying to place an order on the AMAIN site for 2 days and I get an error that says "This web page has a redirect loop. Too many redirects". Does anyone know what's going on with this?
Thanks Core. Has anyone ever experienced this before?
losi b is offline   Reply With Quote
Old 04-25-2015, 02:35 PM   #544
mkl
for what it's worth, I would copy the set up Guch has Tekin recommends the motor wires lead toward the pinion shaft side of the motor to take the stress of the solder tabs. With the wires running toward the "front" of the the solder tabs are better supported by the fiberglass support.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 04-25-2015, 02:51 PM   #545
I will bro. Leaning towards the bm5 lite..... Bring me back to 1991 n my very 1st rc kit, rc10 1990 version...
trojanjoe1 is offline   Reply With Quote
Old 04-25-2015, 03:17 PM   #546
Jordan Anderson's Avatar
Originally Posted by Guch View Post
Orion your layout looks good to me. Keep it. Here is a pic of another layout like yours with wires. I copied it and am very happy with the lack of wire clutter I see in other cars.
Wow, talk about clean wiring! Very nice!
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-25-2015, 03:48 PM   #547
Anyone know what parts besides hubs,wing,wing mounts, body mounts that it takes to convert this truck to a buggy?
Old 04-25-2015, 04:20 PM   #548
tmgkbass's Avatar
Trader Rating: 48 (100%+)
Does anyone know who has this truck in stock ??? Was hoping to have this kit before the start of outdoor racing season next week.
Ofna X3 Sabre, Losi 8ight T 4.0
Os spec2, Novarossi P5 , Byrons
tmgkbass is offline   Reply With Quote
Old 04-25-2015, 04:34 PM   #549
Unless you already have the truck just buy the eb48sl. This is a buggy based off the truck. No need to convert. Otherwise tekno makes a conversion kit that will give you an idea of all the parts required.
crash n go is offline   Reply With Quote
Old 04-25-2015, 04:36 PM   #550
I already have the truck.
Old 04-25-2015, 04:47 PM   #551
If your truck is still new you would be better off selling and buying the SL kit. Tower has them in stock now. But for reference the conversion kit is tkr5003.
Old 04-25-2015, 07:38 PM   #552
leisure hours raceway has 3 of them
Mdavidson217 is offline   Reply With Quote
Old 04-26-2015, 07:10 AM   #553
RickSlick's Avatar
Default Pinion gear size?
Starting my build of the 401.3 and saw I need a pinion gear. I run on outdoor clay and the track is average size with only one long straight, several jumps and turns, probably the average layout for an RC clay track.
What size pinion would you all recommend? I am interested more in preserving motor temps than outright blazing speeds. Motor using is the Hobbywing SCT pro
Thanks, Rick
I do this so I can tell women that I am a "Race Car Driver"
Sponsored by: The women who think I am a Race Car Driver
RickSlick is offline   Reply With Quote
Old 04-26-2015, 07:58 AM   #554
FastPete's Avatar
Trader Rating: 44 (100%+)
Thanks, Rick
Hi Rick
What Motor? 4000, 4700? More than likely a 15-16 is a good start.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 04-26-2015, 08:42 AM   #555
Trader Rating: 19 (100%+)
You may find this of helpful. If you already have a lightened chassis. ... I think you can select the drop down and ad additional .3 items.
http://www.fiercercsolutions.com/Tekno-SCT410-Basic-Upgrade-kit-to-4103-specs-FRC005.htm
Brandon Powell is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
